Home » Eclipse Projects » Rich Client Platform (RCP) » Enable handler based on active page in multi-page editor
Enable handler based on active page in multi-page editor [message #772471] Thu, 29 December 2011 16:32 Go to next message
Does anyone have an example of enabling a command handler based on the active page of a multi-page editor?
I can enable based on the overall editor via activeEditorId but can't figure out a way to discriminate between pages of the editor. I have tried activePartId in an expression as below, where each <value> in the <or> is a section or page that I want the handler enabled. The handler is still always inactive.
Thanks for reading my question and any help you can provide!
      <definition
            id="rewindPageActive">
         <with
               variable="activePartId">
            <or>
               <equals
                     value="editor.RedesignWireSection">
               </equals>
               <equals
                     value="editor.RedesignWindingSection">
               </equals>
               <equals
                     value="editor.RedesignElectricalSection">
               </equals>
               <equals
                     value="editor.RedesignDensitiesSection">
               </equals>
               <equals
                     value="editor.RedesignCoilsSection">
               </equals>
               <equals
                     value="editor.RedesignCircMilSection">
               </equals>
               <equals
                     value="editor.RewindMotor">
               </equals></or>
         </with>
      </definition>
Re: Enable handler based on active page in multi-page editor [message #774512 is a reply to message #772471] Tue, 03 January 2012 23:00 Go to previous message
Not sure but when you add editor pages in code, there has to be some method to add a listener I would imagine. Might want to look there. Might also be a method to override on the editor page that is called on focus or onVisible. - Duncan Krebs
Previous Topic:Workaround for TreeViewer bug
Next Topic:Dynamically create eclipse main menu item or global toolbar item
Current Time: Sat Jul 26 10:45:29 EDT 2025
Powered by FUDForum. Page generated in 0.07334 seconds
