new version does not support older version [message #774239] |
Tue, 03 January 2012 10:16  |
Hello Everyone,
I updated the Birt when i downloaded the eclipse indigo.I am tryin to generate a report from a rpt design of version 3.2.22 using tocat server.I am getting an exception..
Error.DesignFileException.INVALID_XML - 1 errors found!
1.) ( line = 0, tag = null) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNSUPPORTED_VERSION, message : The report file of version "3.2.22" is invalid for it is greater than the latest supported one.)
The complete exception log is as follows
file:/C:/ApacheSoftwareFoundation/Tomcat5.5/webapps/printdocs/resources/Map_Template.rptdesign has error and can not be run.
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:260)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:304)
at org.eclipse.birt.report.engine.api.ReportEngine.openReportDesign(ReportEngine.java:126)
at src.beans.ReportBuilder.run(Unknown Source)
at servlet.PrintDocsServlet.doGet(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:868)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:663)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
Caused by: Error.DesignFileException.INVALID_XML - 1 errors found!
at org.eclipse.birt.report.model.parser.ModuleReader.readModule(ModuleReader.java:116)
at org.eclipse.birt.report.model.parser.DesignReader.read(DesignReader.java:88)
at org.eclipse.birt.report.model.core.DesignSessionImpl.openDesign(DesignSessionImpl.java:314)
at org.eclipse.birt.report.model.api.SessionHandleImpl.openDesign(SessionHandleImpl.java:294)
at org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:158)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255)
... 23 more
Caused by: org.eclipse.birt.report.model.parser.DesignParserException: The report file of version "3.2.22" is invalid for it is greater than the latest supported one.
at org.eclipse.birt.report.model.parser.ModuleState.parseAttrs(ModuleState.java:112)
at org.eclipse.birt.report.model.parser.ModuleParserHandler.startElement(ModuleParserHandler.java:257)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.birt.report.model.parser.ModuleReader.readModule(ModuleReader.java:94)
... 28 more
at org.eclipse.birt.report.model.parser.ModuleState.parseAttrs(ModuleState.java:109)
... 44 more
Any suggestion will be really helpful
Srikanth
FUDForum. Page generated in 0.30977 seconds
