Home » Language IDEs » Java Development Tools (JDT) » Accessing the latest jdt.core.dom.CompilationUnit from completion context
Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #773016] Sat, 31 December 2011 02:42 Go to next message
Hi JDT,
for code completion I need access to the latest known compilation unit AST. The java content assist context provides access to the jdt.core.ICompilationUnit only. Is there a simple way to access the latest jdt.core.dom.CompilationUnit ?
My current approach registers a JavaElementChanged listener that stores the latest ElementDelta or uses ISharedASTProvider if no previous version could be found. See http://git.eclipse.org/c/recommenders/org.eclipse.recommenders.git/tree/plugins/org.eclipse.recommenders.rcp/src/org/eclipse/recommenders/internal/rcp/providers/CachingAstProvider.java for the implementation details.
Is there a smarter way to do that? Does it make sense to make the latest jdt.core.dom.CompilationUnit accessible from completion context? Maybe inside the CoreContext? This would allow me to get rid of my cache completely.
Marcel
Re: Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #773020 is a reply to message #773016] Sat, 31 December 2011 02:58 Go to previous messageGo to next message
I just stumbled over the reconcile operations in ICompilationUnit. Using
final CompilationUnit reconcile = jCtx.getCompilationUnit().reconcile(AST.JLS4, true, true, null, null);
seems to work (at least on my first experiments). Is this the way to go?
Will it work if auto build is turned of?
BTW: I've trouble to understand what exactly reconcile() does.
Does it internally trigger the compilation process for the given compilation unit's editor representation and broadcast this as JavaElementChanged event?
Does calling it several times in a row result in a new event every time? Or only on change?
Is this a very costly operation then (say, more than 50 ms)?
Sorry for all these questions. I may figure them out on my own. But I'm asking these questions to be sure that I don't miss an important situation.
Thanks again. Marcel
Re: Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #773624 is a reply to message #773020] Mon, 02 January 2012 00:37 Go to previous messageGo to next message
Marcel Bruch wrote on Sat, 31 December 2011 02:58
It will work. However, reconcile works only on the working copy.
Yes, it does and it makes the working copy consistent with the underlying resource, updates the Java model and if requested and notifies the java model listeners, produces AST (which is what you need) and reports problems if required. And reconcile happens even if the auto-build is turned off.
Once reconciled, the subsequent calls are no-op. So, shouldn't be a problem, really.
No problem.
Re: Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #773639 is a reply to message #773624] Mon, 02 January 2012 01:38 Go to previous messageGo to next message
Great information. Thank you!
Re: Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #775592 is a reply to message #773624] Fri, 06 January 2012 05:18 Go to previous messageGo to next message
> It will work.
Well, it depends how you define "works" ;-).
The reconciler only kicks in afer some quiet time. If your completion
proposal computer kicks in before (which is likely to happen when typing
code and using content assist) then you would either use an outdated AST
or have to wait for the AST (which would be the same as asking the
shared AST provider with the WAIT_ACTIVE_ONLY flag) or create it
yourself (could be an option if you don't need a fully resolved AST).
The general rule is not to use an AST for content assist.
Also note that the AST from the reconciler and the one used/created by
content assist aren't the same. See also https://bugs.eclipse.org/110181.
Dani
> problem, really.
>> situation.
> No problem.
Re: Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #775659 is a reply to message #775592] Fri, 06 January 2012 08:25 Go to previous messageGo to next message
>> It will work.
does "or have to wait" mean that I'll have to wait if no ast has been
build _before_? For instance, if code completion is triggered the first
time immediately in an editor?
> or create it
I'm relying on (i) all statements and all bindings inside the enclosing
method and (ii) all declared methods and types of the compilation unit.
Will a slim parser be faster than the reconcile operation? I might be
interested in a full AST to do larger analyses. I can live with slightly
outdated ASTs (at least I think I could).
Any alternatives you can propose? Compiler AST? I need something that
allows me do some analysis.
I'm not sure I got all details in this bug. Is it resolving the binding
for the enclosing method only?
Marcel
Re: Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #775680 is a reply to message #775659] Fri, 06 January 2012 09:05 Go to previous messageGo to next message
>>>> Using
>>>> to go?
>>> It will work.
> first time immediately in an editor?
Yes, and also if one types and quickly invokes Ctrl+Space. This might
block content assist (and hence the UI) for several seconds.
>> or create it
> enclosing method and (ii) all declared methods and types of the
> compilation unit.
Oops! ;-)
I guess so, because you could probably reduce the scope which you need
to scan (not sure).
> I might be interested in a full AST to do larger analyses. I can live
> with slightly outdated ASTs (at least I think I could).
If the user ends up with an unpredictable UI, I'd say "no".
1. Compute the requested data on a faster/smarter way.
2. Try to figure out whether JDT Core could give you the pieces you need
(but this will most likely not be the full internal AST used by content
assist).
> binding for the enclosing method only?
It returns a Java element but the internal AST would have more info AFAIK.
Dani
> Marcel
Re: Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #775753 is a reply to message #775680] Fri, 06 January 2012 11:25 Go to previous messageGo to next message
Marcel, The InternalExtendedCompletionContext has the CU AST node - org.eclipse.jdt.internal.codeassist.InternalExtendedCompletionContext.compilationUnitDeclaration . Don't you have access to the extended context?
Re: Accessing the latest jdt.core.dom.CompilationUnit from completion context [message #775818 is a reply to message #775753] Fri, 06 January 2012 13:19 Go to previous message
Ah, well. Wouldn't call it "access" so far... The fields are protected and private:
 public Optional<InternalExtendedCompletionContext> getExtendedContext() {
        try {
            final Field ctxField = coreContext.getClass().getDeclaredField("extendedContext");
            ctxField.setAccessible(true);
            final InternalExtendedCompletionContext extendedContext = cast(ctxField.get(coreContext));
            final Field cuField = extendedContext.getClass().getDeclaredField("compilationUnitDeclaration");
            cuField.setAccessible(true);
            final CompilationUnitDeclaration cu = cast(cuField.get(extendedContext));
            return fromNullable(extendedContext);
        } catch (final Exception e) {
            throw throwUnhandledException(e);
Anyway, this cu does not contain statements in the enclosing method. I'm currently using an ASTVisitor to collect all method calls that get executed on the variable code completion was triggered on. Without these statements it's a bit hard to make any valuable recommendations Smile
Is there a fast way to create a complete AST of the enclosing method?
[Updated on: Fri, 06 January 2012 13:20] by Moderator
Previous Topic:Create fully-featured IJavaCompletionProposal from IMethod
Next Topic:Defining key shortcut for completion engine via extension point
Current Time: Fri Jul 25 18:22:29 EDT 2025
Powered by FUDForum. Page generated in 0.07315 seconds
