Home » Language IDEs » C / C++ IDE (CDT) » CDT .cpp source file editor Popup menu help needed
CDT .cpp source file editor Popup menu help needed [message #77056] Thu, 24 July 2003 18:09 Go to next message
Hello I want to add a right click context menu items to the CDT C++ source
file editor.
I created an extension point like (I simplified it to protect company
information)
<extension point="org.eclipse.ui.popupMenus">
<!--popup menus for my addin-->
<viewerContribution id="com.xxx.Addin.CDTPopupActions"
targetID="#CompilationUnitEditorContext">
<action id="MyActionOnCppFile" label="Label DoSomething"
menubarPath="group.show" icon="path\morepath\mygif.gif" tooltip="a tooltip"
class="com.xxx.addin.interaction.MenuOnCDTEditor"/>
</viewerContribution>
</extension>
But its not showing up, when I open a cpp file and then right click on the
file.
I'm confused by a lot of the syntax
- is ViewerContribution id simply a unique ID I give to my menu item?
- Where do I find out details about what "#CompilationUnitEditorContext"
means and other defines, is this correct for CDT?
- Anything else I need to do, beyond adding this to my fragment, and
flushing out supporting the Java Interface?
- See anything glaringly wrong here?
Thanks for assistance here.
Re: CDT .cpp source file editor Popup menu help needed [message #77237 is a reply to message #77056] Mon, 28 July 2003 10:15 Go to previous messageGo to next message
I think that for CDT , you want targetID="CEditorContext".
That's the only thing I see wrong with your fragment, (as long as your class
MenuOnCDTEditor implements IEditorActionDelegate).
-Andrew
"Mike" <mboyersmith@rational.com> wrote in message
news:bfplc9$1l3$1@eclipse.org...
> file editor.
> information)
tooltip"
> </extension>
> file.
Re: CDT .cpp source file editor Popup menu help needed [message #77858 is a reply to message #77237] Mon, 04 August 2003 18:58 Go to previous message
Thanks Andrew,
that did it, appreciate the help here :D
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:bg3b0f$cot$1@eclipse.org...
class
> -Andrew
source
> > file editor.
> > information)
> tooltip"
> > </extension>
the
> > file.
Previous Topic:Control on loading a program
Next Topic:CDT for 3.0?
Current Time: Sat Oct 25 22:15:26 EDT 2025
Powered by FUDForum. Page generated in 0.06452 seconds
