Home » Modeling » TMF (Xtext) » What i need to use for get entities-attributes in a variable?(var=entity ... var.atributte ??)
| What i need to use for get entities-attributes in a variable? [message #771653] |
Tue, 27 December 2011 16:06  |
Hi, suposse in my DSL y load variables with entities in a cross reference some like :
module MODULE_NAME{
entity ENTITY_NAME {
int code,
text name
function FUNCTION_NAME(){
var VAR_NAME as MODULE_NAME.ENTITY_NAME ; // Working
var.code = 1 // How achieve this ?
One of my rules is :
VarDeclaration :
declaration='var' name='ID' ('as' type=[Entity|QualifiedName]) ('=' exp=Expression)?
Some suggestion about where i need to investigate?
Thanks and sorry for my lot of questions, read all the doc when you dont speak english is sometimes hard.
[Updated on: Wed, 28 December 2011 06:31] by Moderator
| Re: What i need to use for get entities-attributes in a variable? [message #773750 is a reply to message #771653] |
Mon, 02 January 2012 07:58   |
Hi, i finally get it. Now i am trying to replace the slash '/' by a dot '.'
This is my example code:
grammar org.example.domainmodel.Domainmodel with org.eclipse.xtext.common.Terminals
generate domainmodel "http://www.example.org/domainmodel/Domainmodel"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
ModuleDeclaration:
'module' name=QualifiedName '{'
(elements+=AbstractElement)*
AbstractElement:
Import |Entity | ModuleFunction;
QualifiedName:
ID ('.' ID)*;
Import:
'import' importedNamespace=QualifiedNameWithWildcard ';';
QualifiedNameWithWildcard:
QualifiedName '.*'?;
Type:
DataType | Entity;
DataType:
'int'
| 'STRING';
Entity:
'entity' name=ID
('extends' superType=[Entity])?
features+=Feature ((',' features+=Feature)*)?
Feature:
name=ID featureType=[Type];
VariableDeclaration:
name=ID 'as' variableType=[Entity] ('=' assignament=ID)?;
PathDefinition:
PathHead ('=' assignament=ID)?;
PathHead:
entity=[VariableDeclaration] (tail=PathTail)?;
PathTail:
'/' feature=[Feature] (pathTail=PathTail)?;
ModuleFunction:
'function' name=ID functionImplmenentation=FunctionImplementation;
FunctionImplementation:
parameterDeclaration=FunctionParametersDeclaration codeBlock=CodeBlock;
FunctionParametersDeclaration:
'(' (args+=ID (',' args+=ID)*)? ')';
CodeBlock:
'{' (statements+=Statement)* '}';
Statement:
(CallFunction | VariableDeclaration | PathDefinition) ';';
CallFunction:
ModuleFunctionCall //|
ModuleFunctionCall:
function=[ModuleFunction | QualifiedName] parametersInvocation=FunctionParametersInvocation;
FunctionParametersInvocation:
'(' args+=Expression ((',' args+=Expression)*)? ')';
Expression:
ID*;
And my scope provider :
IScope scope_PathTail_feature(final EObject context, EReference ref) {
EObject parent = context.eContainer();
if( parent instanceof PathHead ) {
return org.eclipse.xtext.scoping.Scopes.scopeFor(((PathHead) parent).getEntity().getVariableType().getFeatures());
if( parent instanceof PathTail ) {
Type type = ((PathTail) parent).getFeature().getFeatureType();
if(type instanceof Entity){
return org.eclipse.xtext.scoping.Scopes.scopeFor(((Entity)type).getFeatures() );
}else{
EList<Feature> features = (EList<Feature>) new ArrayList<Feature>();
return org.eclipse.xtext.scoping.Scopes.scopeFor(features);
// Fall-through? Probably a programmer error...
throw new RuntimeException("don't know how to compute scope for 'feature' of PathTail");
Reading this http://dslmeinte.wordpress.com/2010/12/08/getting-alternative-cross-references-to-work-with-existing-epackages/ a lot of times I understand that I need to change my code and use [ecore::EObject] in some places, maybe in the PathTail rule but what i have to do in the scope if i use [ecore::EObject] ?.
If i change :
PathTail:
to :
PathTail:
'.' feature=[ecore::EObject] (pathTail=PathTail)?;
I still having compile errors.
So, my conclusion is that the parser cant distinguish a 'module.function' / 'var.attribute', because if i replace the rule
ModuleFunctionCall:
to
ModuleFunctionCall:
function=[ModuleFunction] parametersInvocation=FunctionParametersInvocation;
I lost the qualifiedNames but i haven't problems with the '.' in the PathTail rule.
Sincerely i can't understand the example and the solution provided by Meinte,and I dont know how implement the solution in my case.
Can you guide me, anything will help me.
Thanks.
[Updated on: Mon, 02 January 2012 08:53] by Moderator
| Re: What i need to use for get entities-attributes in a variable? [message #784571 is a reply to message #771653] |
Fri, 27 January 2012 13:05   |
Hi again...
This is my test grammar :
grammar org.xtext.example.eal.Eal with org.eclipse.xtext.common.Terminals
generate eal "http://www.xtext.org/example/eal/Eal"
/*************** Module ***************/
ModuleModel:
('description' description=STRING)? ';'
(Entities+=Entity
| Functions+=UserFunction
| Imports+=Import)*
Import:
imp='import' importedNamespace=QualifiedNameWithWildcard ';' ;
QualifiedName:
ID ('.' ID)*;
/*************** Entity ***************/
Entity:
entity='entity' name=ID ('table' tableName=ID)? '{'
attributes+=Attribute ((',' attributes+=Attribute)?)*
Attribute:
(dataType=DataType | entityType=[Entity])
name=ID (identifier='identifier')? (discriminator='discriminator')?
(('column') columnId+=ID (',' columnId+=ID)* | ('attribute') attributeId+=ID (',' attributeId+=ID)*)?;
/************** Datatype **************/
DataType:
(date='date'
| bool='bool'
| time='time'
| int='int'
| numeric='numeric' '[' INT ',' INT ']'
| string='string' '[' INT ']'
| list='list' '<' entity=[Entity] '>'
/************ UserFunction ************/
UserFunction:
'function' name=ID implementation=FunctionImplementation;
functionParametersDeclaration=FunctionParametersDeclaration codeblock=Codeblock;
'(' (args+=ParameterDeclaration (',' args+=ParameterDeclaration)*)? ')';
Codeblock:
'{' (satements+=Statement)* '}'
ParameterDeclaration:
AbstractParameterDeclaration | ParameterDeclarationType
AbstractParameterDeclaration:
name=ID
ParameterDeclarationType:
name=ID 'as' type=[Entity]
/********** PathExpressions ***********/
QualifiedNameDefinition:
QualifiedNameHead
QualifiedNameHead:
ID (tail=QualifiedNameTail)?
QualifiedNameTail:
'.' attribute=[ecore::EObject ] (tail=QualifiedNameTail)?
/************* Variables **************/
AbstractVariableDeclaration | VariableDeclarationType
AbstractVariableDeclaration:
VariableDeclarationType:
'var' name=ID 'as' type=[Entity]
VariableAssignment:
VariableDeclaration ('=' expression=Expression)?
/************* Statement **************/
Statement:
VariableAssignment ';'
/************ Expression **************/
Expression:
(expression+=ExpAnd) ('||' expression+=ExpAnd)*;
ExpAnd:
(expAnd+=ExpComp)
('&&' expAnd+=ExpComp)*;
ExpComp:
(expComp+=ExpMasMenos)
('==' expComp+=ExpMasMenos
| 'like' expComp+=ExpMasMenos
| '!=' expComp+=ExpMasMenos
| '<' expComp+=ExpMasMenos
| '>' expComp+=ExpMasMenos
| '>=' expComp+=ExpMasMenos
| '<=' expComp+=ExpMasMenos)*;
ExpMasMenos:
(expMasMenos+=ExpMultDiv)
('+' expMasMenos+=ExpMultDiv
| '-' expMasMenos+=ExpMultDiv)*;
ExpMultDiv:
(expMultDiv+=ExpMenos)
('*' expMultDiv+=ExpMenos
| '/' expMultDiv+=ExpMenos
| '\\' expMultDiv+=ExpMenos
| '^' expMultDiv+=ExpMenos
| '%' expMultDiv+=ExpMenos)*;
ExpMenos:
'-' ExpNo
| ExpNo;
ExpNo:
'!' QualifiedNameDefinition
| QualifiedNameDefinition;
Maybe the rule names are incorrect, but this is my sample grammar so dont worry about that.
What i trying to get now, is, avoid a warning error :
How you can see, my grammar allows to declare in codeblocks (pseudocode) :
var NAME as [Entity] = Expression
So, when i :
NAME. //-> In the scope I get all the features of the Entity in the cross reference.
But, my grammar allows too to declare variables without a defined type.
So is correct to said :
And if "data" is a variable with type, I get the features of the entity but if "data" is a abstract variable, I want to allow everything. I.E.
function CalcPrice(){
variable = something.something // I get error because something.something is not a EObject
So, where I can avoid this error?, Validation? ScopeProvider?
The compiler is already done, so i dont need to know wich object is in the variable.variable,this is especific for a variable content assist.
Thanks, in advance.
Attachment: png.png
(Size: 13.22KB, Downloaded 174 times)
| Re: What i need to use for get entities-attributes in a variable? [message #784801 is a reply to message #784571] |
Fri, 27 January 2012 20:38   |
The grammar for expressions looks wrong - you are losing information.
As an example:
ExpMasMenos:
Will give you a list of ExpMultDiv instances in ExpMasMenos, but the '+'
and '-' operators are lost. And since the only data is QualifiedName
definition, everything is reduced to nested lists of symbols.
Is that all you want to get after parsing? If not, you need to address
this first before thinking about cross referencing. (Look at some of the
Expression examples).
- henrik
On 2012-27-01 19:06, Federico Sellanes wrote:
> Hi again... :)
> ModuleModel:
> (Entities+=Entity
> | Imports+=Import)*
> Import:
> QualifiedName:
> ID ('.' ID)*;
> Entity:
> Attribute:
> DataType:
> (date='date'
> | bool='bool'
> | time='time'
> | int='int'
> | list='list' '<' entity=[Entity]'>'
> UserFunction:
> Codeblock:
> name=ID
> QualifiedNameHead
> QualifiedNameHead:
> QualifiedNameTail:
> VariableAssignment:
> Statement:
> Expression:
> ExpAnd:
> (expAnd+=ExpComp)
> ExpComp:
> ExpMasMenos:
> ExpMultDiv:
> ExpMenos:
> '-' ExpNo
> | ExpNo;
> ExpNo:
> So, when i :
> variable = data.data
> Thanks, in advance.
| Re: What i need to use for get entities-attributes in a variable? [message #787647 is a reply to message #784801] |
Tue, 31 January 2012 15:45   |
Hi Henrik !! my battle continues...
First, thanks for your answer, I tried a lot of ways, and each of the options gives me and takes me different features, in the end I got nothing that work how I want. Now I changing my question in a different view...
I.E.
module Module{
function someFunction(){
//return something
module OtherModule {
entity Customer{
int code
function getSomething(){
var aux is Customer = Module.someFunction(); // 'var' ID 'is' [Entity] = [UserFunction]
var otherAux is Customer = data; // 'var' ID 'is' [Entity] = ID
aux.code = something ; // ID.attribute = ID
Basically, this are my use cases...
So the expression in the left of the '=' can be, an ID or a VariableDeclaration and, the expressions in the right of the '=', can be a "static" function call, an ID
or a variable.attribute.
Just like java, variable, static function call, variable intellisense, assignment... but with the difference that in my dsl i can declare a variable without indicate the type (like a scripting language).
This is possible in xtext?
I'm going crazy.
PD: I got the most of the use cases but when I have them I cannot get the static function call. All the cases together seems a nightmare for a dsl noob.
I got the intellisense in the MyDslProposalProvider and work really good.
So, as you would you?
Thanks for help me.
[Updated on: Tue, 31 January 2012 15:54] by Moderator
| Re: What i need to use for get entities-attributes in a variable? [message #787879 is a reply to message #787647] |
Tue, 31 January 2012 23:21  |
Constructing a grammar for an expression based language using parser
technology that is LL requires that you use a well known pattern to
establish the precedence of expressions.
Here is a snippet from one such grammar (the standard Expression example
is simpler - but follows the same principle).
As you can see, each rule starts with a rule-call to the rule with the
next higher precedence. It is followed by an optional (often repeated as
operators are cumulative e.g. 1 + 2 + 3 + 4). This optional part
rewrites the result. You see something like:
{be::BBinaryOpExpression.leftExpr=current}
which means "create an instance of BBinaryOpExpression, and assign its
leftExpression to what was just parsed/created (i.e. 'current'), then
proceed with the just created instance as 'current').
Using Lisp like notation to illustrate the result of parsing:
1 + 2 => (+ 1 2)
1 * 2 => (* 1 2)
1 + 2 + 3 => (+ (+ 1 2) 3)
1 + 2 * 3 => (+ 1 (* 2 3))
i.e. 1 + 2 results in one instance of BBinaryOpExpression where leftExpr
is a Literal '1', the functionName is '+', and the rightExpr is a
Literal '2'. (You have to work out the others yourself ;))
The chain of calls goes all the way down to the primary expressions -
i.e. where you find the Literals (numbers, strings, etc.) and the
primary constructs if/then/else, switch/case, definitions etc.
As an exercise, try to read the code and see how the above tree gets
constructed.
This is all following a formula. The formula is slightly different
depending on if they are left or right associative, if they are
cumulative or not etc.
The snippet below is from the Eclipse project b3 (and contains quite a
few things specific to b3). You can naturally look at the source of
that, or cloudsmith/geppetto which is for a language called Puppet (also
expression based), as last but not least the source for Xtend. As
mentioned earlier there is an Expression example that is a good starting
point.
Whatever you do, do not try to write the entire grammar at once. Start
with a very small subset and make sure that works before you proceed.
That way you have a much better chance of understanding which of you
constructs/rules are giving you problems - or (worst case) you are
dealing with a language that is difficult to parse (having overlapping
terminals, or require semantic predicates). A bonus is that it is easier
for others to help you :) - if you ask "here is my grammar, and when I
introduce this rule xxx to do yyy, I get the following problem". Looking
at snippets of your source language, and a semi-broken full grammar
requires quite a lot guess work by anyone who tries to help you.
And before you even start on the Expressions, make sure you have your
terminals (and keywords) figured out.
Here is the snippet...
Expression : AdditiveExpression ;
AdditiveExpression returns be::BExpression :
MultiplicativeExpression ({be::BBinaryOpExpression.leftExpr=current}
functionName=("+" | "-") rightExpr=MultiplicativeExpression)*
MultiplicativeExpression returns be::BExpression :
SetExpression ({be::BBinaryOpExpression.leftExpr=current}
functionName=("*" | "/" | "%") rightExpr=SetExpression)*
SetExpression returns be::BExpression:
UnaryOrInfixExpression ({be::BBinaryOpExpression.leftExpr=current}
functionName=".." rightExpr=UnaryOrInfixExpression)*
UnaryOrInfixExpression returns be::BExpression
: PostopExpression
| UnaryExpression
| PreopExpression
UnaryExpression returns be::BExpression : {be::BUnaryOpExpression}
functionName=("!" | "-") expr=InfixExpression
PreopExpression returns be::BExpression : {be::BUnaryPreOpExpression}
functionName=("++" | "--") expr=InfixExpression
PostopExpression returns be::BExpression :
InfixExpression ({be::BUnaryPostOpExpression.expr=current} functionName
// Note that grammar is lenient with optional elements to enable good CA
InfixExpression returns be::BExpression :
CallExpression (
({be::BCallFeature.funcExpr=current} "." (name=ID_or_KW (call ?=
"(" (parameterList = ParameterList)? ")")?)?)
| ({be::BAtExpression.objExpr=current} '[' (indexExpr=Expression)? ']' )
CallExpression returns be::BExpression :
PrimaryExpression ({be::BCallFunction.funcExpr=current}"("
(parameterList = ParameterList)? ")")*
PrimaryExpression returns be::BExpression
: FeatureCall
| ConstructorCallExpression
| Literal
| VariableValue
| PropertyValue
| ParanthesizedExpression
| IfExpression
| BlockExpression
| SwitchExpression
| ThrowExpression
| TryCatchExpression
Hope this gives some insight into writing an Expression based grammar.
- henrik
On 2012-31-01 21:45, Federico Sellanes wrote:
> Hi Henrik !! my battle continues... First, thanks for your answer, i
> different features, in the end i got nothing that work how i want. Now
> I'm changing my question in a different view...
> module name {
> entity Customer{
> int code
> var aux is Customer = Module.function(); // 'var' ID 'is' [Entity] =
> [UserFunction] var otherAux is Customer = data; // 'var' ID 'is'
> [Entity] = ID
Is this text in your source language?
> So the expression in the right of the '=' can be, an ID or a
> be, a "static" function call, an ID
> assignment...
Look at Xtend - yes it is possible to describe a Java like language.
> I'm going crazy.
Not good. Start from the beginning and do small steps. When learning to
juggle, don't start by trying to juggle a dozen live chainsaws. That is
just going to hurt...
> PD: I got the most of the use cases but when i have them i cannot get
> dsl noob.
You did not show the full grammar, so hard to tell how far you got on
the right track...
> Thanks for help me.
np - help us help you by being as concrete as possible - we can't guess
what your 'static function call' means in your language, nor what
problems you are running into when we don't see the grammar.
- henrik
Current Time: Sat Nov 01 14:44:32 EDT 2025
Powered by FUDForum. Page generated in 0.25566 seconds
