Home » Archived » BIRT » Column sum based on another column
Column sum based on another column [message #770678] Sat, 24 December 2011 20:52 Go to next message
I'm new to BIRT and am trying to create a balance sheet report which contains amount column and DB/CR column.
I need to calculate sum of Amount column based on DB/CR. i.e., i need to ADD the amount value if DB/CR column has DB and subtract amount value if DB/CR has CR.
the total has to be displayed at the end of the amount column.
Please help how to calculate the same
Re: Column sum based on another column [message #771600 is a reply to message #770678] Tue, 27 December 2011 13:07 Go to previous messageGo to next message
How do your DB/CR values come in? As positive and negative values?
Can you post a sample of what the data could look like?
Jason
On 12/24/2011 8:52 PM, Nagabhushan Bhushan wrote:
Re: Column sum based on another column [message #771655 is a reply to message #771600] Tue, 27 December 2011 16:09 Go to previous messageGo to next message
I've attached the sample of how the report should look like. I need to get the value of TOTAL that is calculated in the sample data.
The table is grouped based on the GLType and Ledger number and for each group of gltype, i need to display the total.
  • Attachment: Book1.xlsx
    (Size: 10.14KB, Downloaded 322 times)
Re: Column sum based on another column [message #772433 is a reply to message #771655] Thu, 29 December 2011 14:24 Go to previous message
I am not sure how you calculate your balance, but I dumped your data to
csv file and wrote a report off of it. If you look at the expression on
the aggregation element in the group footer you will see how I handle
the db vs cr field.
if(dataSetRow["DB / CR"] == "db"){
dataSetRow["Balance"];
}else{
dataSetRow["Balance"]*-1;
Jason
Previous Topic:Report parameters not retaining default value
Next Topic:How to calculate SUM cumulative times type of string?
Current Time: Sun Jul 27 09:37:57 EDT 2025
Powered by FUDForum. Page generated in 0.04060 seconds
