Home » Eclipse Projects » Eclipse Platform » How do I load multiple version of same plugin
How do I load multiple version of same plugin [message #771451] Tue, 27 December 2011 04:42 Go to next message
I want to load multiple version of an plugin in eclipse run time.
I have tried it by changing the plug-in name,ID and version. However it always loads the latest one.
Can anybody help me?
Re: How do I load multiple version of same plugin [message #774729 is a reply to message #771451] Wed, 04 January 2012 08:44 Go to previous message
You want to load multiple versions of a plugin ... and do what with them? What usecase are you trying to solve?
If the plugin is a singleton (anything with a plugin.xml, for example) you can only load one version.
If it is not a singleton, you need to 1) get the multiple bundles installed in your running app and visible to OSGi and then 2) somehow access them or start them, probably using OSGi services.
PW
Previous Topic:Eclipse does not save changes to run configurations. Any clue?
Next Topic:Disable plugins through ini file
Current Time: Sat Aug 30 19:05:24 EDT 2025
Powered by FUDForum. Page generated in 0.30231 seconds
