Trouble with running java application [message #771035] |
Mon, 26 December 2011 00:03  |
I need help with compiling the code in eclipse. I have looked around the web and thought that classpath was the problem and fixed it but i am still getting this error...
Exception in thread "main" java.lang.NoClassDefFoundError: Driver
Caused by: java.lang.ClassNotFoundException: Driver
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
Can anyone help me understand further what I must do to solve this?
Re: Trouble with running java application [message #772332 is a reply to message #772122] |
Thu, 29 December 2011 09:34  |
On 2011.12.28 20:26, Donovan Ng wrote:
> Would like to ask further regarding your post..
> If I am missing a specific .class file for eclipse, how would I know
> which one is missing for me to place it on to eclipse?
> Any recommended ways? I apologize as I am don't normally use an IDE to
> compile my java files. Just wanted to try something new :) THanks!
Typically, you add .class files to Eclipse projects as JARs via Build
Path. You can hand-copy a .class file to a project, but then you have to
wire things up specially for that as dropping it into a subdirectory
with the .class files created by Eclipse compilation will also subject
it to being deleted, either by Eclipse (not necessarily) or ant (well,
the way I write it would delete it). In any case, it's not a very stable
proposition.
As I don't grok exactly what you're trying to do, nor do I think I've
done what you're doing, it's hard to give experienced or knowledgeable
advice.
Give more details in your reply if you wish to pursue this.
Best,
Russ
FUDForum. Page generated in 0.37569 seconds
