Home » Modeling » GMF (Graphical Modeling Framework) » Connections to elements in collapsed compartments
Connections to elements in collapsed compartments [message #75235] |
Tue, 07 November 2006 08:17  |
Originally posted by: tobk.gmx.de
can you tell me if the following problem [1] is already solved? The request
was posted about half a year ago.
It's about connections with source or target feature being child of a
collapsed compartment. It would be nice, if those connections would be
reconnected to the collapsed compartment. Currently such connections just
disappear.
Could you give me a short advice or reference how to do this manually? I
think I'd have to override the
ResizableCompartmentEditPolicy.getResizeCommand and return a
CompositeCommand with the super-command and some reorientConnectionCommands
for all the children's connections. But how can I just reorient the
connection's view, without changing it's source/target features?
tobias
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=142270
Re: Connections to elements in collapsed compartments [message #75472 is a reply to message #75235] |
Tue, 07 November 2006 11:48   |
Originally posted by: vcciubot.uwaterloo.ca
Hi Tobias,
You have to modify the canonical connection policy in two places.
Assuming this policy is not installed on the collapsed compartment.
My best experience is with a single canonical connection policy and
disabled view creation command in GraphicalNodeEditPolicy - to avoid
duplication of edges.
Note however that some of useful methods are final or private in the base
class so you will end up with some form of code duplication:
protected EditPart getTargetEditPartFor(EObject connection) {
EObject tel;
EditPart tep;
tel = getTargetElement(connection);
tep = getEditPartFor(tel, connection);
return tep;
protected EditPart getSourceEditPartFor(EObject connection) {
EObject sel;
EditPart sep;
sel = getSourceElement(connection);
sep = getEditPartFor(sel, connection);
return sep;
So basically, check the edit part that super returns and see whether its
parent/ancestor view is collapsed, if so return some other ShapeNode edit
part.
You also have to invalidate these edges when the compartments are expanded:
`extend '
final protected List cleanCanonicalSemanticChildren(Collection
viewChildren, Collection semanticChildren)
Here's an example:
protected List cleanCanonicalSemanticChildren(Collection viewChildren, Collection semanticChildren) {
List orphaned = super.cleanCanonicalSemanticChildren(viewChildren, semanticChildren);
//certain connections might be invalid because of the position of the port border items
for (Object child : viewChildren) {
Edge edge = (Edge) child;
EObject connection = edge.getElement();
View src = edge.getSource();
View dst = edge.getTarget();
EditPart srcEditPart = (EditPart) getHost().getViewer().getEditPartRegistry().get(src);
EditPart dstEditPart = (EditPart) getHost().getViewer().getEditPartRegistry().get(dst);
if (srcEditPart != getSourceEditPartFor(connection) || dstEditPart != getTargetEditPartFor(connection))
if (orphaned.contains(edge) == false)
orphaned.add(edge);
return orphaned;
On Tue, 07 Nov 2006 14:17:04 +0100, tobias wrote:
> Hello,
> disappear.
> tobias
Re: Connections to elements in collapsed compartments [message #77132 is a reply to message #75472] |
Mon, 13 November 2006 07:08   |
Finally found time to try this... but it does not work yet.
Maybe I'm misunderstood you and did something wrong:
- I created a class extending CanonicalConnectionEditPolicy
- I implemented the getSource/TargetElement methods
- I changed the getSource/TargetEditPartFor methods so they return the
parent edit part's parent edit part, if the parent edit part's figure is
not extended
- I installed this edit policy on the
[ContainerElement]CompartmentEditPolicy
- I tried with CanonicalRole, ConnectionRole and RefreshConnectionsRole
- I did not yet change that one final method and the GraphicalNodesRole,
since - if I understood you right - these do only change/delete duplicate
and badly positioned connections
However, the getSource/TargetEditPartFor-method are not even called when I
expand/collapse the compartment...
Could you please tell me where I made a mistake?
thanks,
tobias
Vlad Ciubotariu wrote:
> Hi Tobias,
> EObject tel;
> EditPart tep;
> return tep;
> EObject sel;
> EditPart sep;
> return sep;
> part.
> expanded:
> `extend '
> Here's an example:
> semanticChildren);
> border items
> getHost().getViewer().getEditPartRegistry().get(src); EditPart dstEditPart
> getTargetEditPartFor(connection)) if (orphaned.contains(edge) == false)
> orphaned.add(edge);
> return orphaned;
>> Hello,
>> request was posted about half a year ago.
>> disappear.
>> reorientConnectionCommands for all the children's connections. But how
>> can I just reorient the connection's view, without changing it's
>> Thanks,
>> tobias
Re: Connections to elements in collapsed compartments [message #77165 is a reply to message #77132] |
Mon, 13 November 2006 10:04   |
You should have one CanononicalConnection policy per diagram. That's how
the generated code works, too.
You have to modify that policy to return different edit parts depending on
whether the containing compartment is collapsed or not. That policy must
refresh whenever a compartment is collapsed or extended.
You have to handle that event (DrawerStyle) in a subclass of
ResizeableCompartmentEditPart:
protected void handleNotificationEvent(Notification event ) {
Object feature = event.getFeature();
if (NotationPackage.eINSTANCE.getRatio_Value().equals(feature)
|| event.getOldValue()instanceof Ratio
|| event.getNewValue() instanceof Ratio)
refreshRatio();
else if (NotationPackage.eINSTANCE.getDrawerStyle_Collapsed().equals (feature)){
setCollapsed(event.getNewBooleanValue(), true);
this.getFigure().revalidate();
} else if (NotationPackage.eINSTANCE.getTitleStyle_ShowTitle().equals( feature))
setShowCompartmentTitle(event.getNewBooleanValue());
else if (NotationPackage.eINSTANCE.getFontStyle_FontColor().equals(f eature)){
Integer c = (Integer) event.getNewValue();
setFontColor(DiagramColorRegistry.getInstance().getColor(c)) ;
else if (NotationPackage.eINSTANCE.getFontStyle_FontHeight().equals( feature) ||
NotationPackage.eINSTANCE.getFontStyle_FontName().equals(fea ture) ||
NotationPackage.eINSTANCE.getFontStyle_Bold().equals(feature ) ||
NotationPackage.eINSTANCE.getFontStyle_Italic().equals(featu re)) {
refreshFont();
} else
super.handleNotificationEvent(event);
That's where you have to refresh the CanonicalConnection policy.
Note: you can't have this canonical policy installed on the compartment
being collapsed:
public boolean isEnabled() {
// if the editing domain is null then there is no point in enabling the edit policy
// the editing domain could be null because the view is detached or if the host is detached
if ( TransactionUtil.getEditingDomain((EObject)getHost().getModel ())==null){
return false;
DrawerStyle dstyle = (DrawerStyle) ((View)host().getModel()).getStyle(NotationPackage.eINSTANCE .getDrawerStyle());
boolean isCollapsed = dstyle == null ? false : dstyle.isCollapsed();
if ( isCollapsed ) {
return false;
CanonicalStyle style = getCanonicalStyle();
boolean enabled = _enabled && ((View)host().getModel()).isVisible();
return style == null
? enabled
: style.isCanonical() && enabled;
> not extended
> thanks,
> tobias
>> Hi Tobias,
>> EObject tel;
>> EditPart tep;
>> return tep;
>> EObject sel;
>> EditPart sep;
>> return sep;
>> part.
>> expanded:
>> `extend '
>> Here's an example:
>> semanticChildren);
>> border items
>> orphaned.add(edge);
>> return orphaned;
>>> Hello,
>>> disappear.
>>> Thanks,
>>> tobias
Re: Connections to elements in collapsed compartments [message #77247 is a reply to message #77165] |
Mon, 13 November 2006 14:24   |
Thank you for all your help, Vlad, but I'm still not so sure whether I'm on
the right way...
Here again what I did now (and which shows no results):
I finally found the one CanonicalConnectionEditPolicy (the given name is a
little bit irritating...) and added the following (and nothing more):
protected EObject getSourceElement(EObject relationship) {
EObject source= null;
if (relationship instanceof [ConnectionType]) {
source= (([ConnectionType]relationship).getSource();
[other connection types...]
return source;
(accordingly for target)
EditPart editPart= super.getSourceEditPartFor(connection);
return getEditPartToAttachTo(editPart);
(same for target)
private EditPart getEditPartToAttachTo(EditPart editPart) {
EditPart parent= editPart.getParent();
if (parent instanceof ResizableCompartmentEditPart) {
ResizableCompartmentEditPart cep= (ResizableCompartmentEditPart) parent;
if (! cep.getCompartmentFigure().isExpanded()) {
return parent.getParent(); //since the compartmenteditpart is also
contained in the parent element's edit part
return editPart;
Further I added your handleNotificationEvent-snipplet to the
ResizableCompartmentEditPart that all this fuss is about.
Nothing more. Especially I did not install any additional EditPolicys to
that or another EditPart (except for the usual GraphicalNodeEditPolicy with
that one line removed to avoid duplicate edges). I did not yet regard the
given improvement for removing too many edges, since there is nothing to
remove yet.
When minimizing the Compartment none of the above shown methods is entered
(according to debugging) and the connection just disappears.
Please, could you tell me what _exactly_ to do in which file? I know this
must sound really stupid, but sometimes I'm having trouble looking behind
all the things happening (and happening not) in GMF "behind my back". ^^;;
I'd really appreciate your help in this issue.
tobias
> refreshRatio();
> else if
> this.getFigure().revalidate(); } else if
> setShowCompartmentTitle(event.getNewBooleanValue()); else if
> setFontColor(DiagramColorRegistry.getInstance().getColor(c)) ; }
> else if
> refreshFont();
> } else
> being collapsed:
> enabling the edit policy // the editing domain could be null
> because the view is detached or if the host is detached if (
> return false;
> return false;
> ? enabled
>> not extended
>> I expand/collapse the compartment...
>> thanks,
>> tobias
>>> Hi Tobias,
>>> base class so you will end up with some form of code duplication:
>>> EObject tel;
>>> EditPart tep;
>>> return tep;
>>> EObject sel;
>>> EditPart sep;
>>> return sep;
>>> edit part.
>>> expanded:
>>> `extend '
>>> Here's an example:
>>> semanticChildren);
>>> port border items
>>> orphaned.add(edge);
>>> return orphaned;
>>>> Hello,
>>>> just disappear.
>>>> I think I'd have to override the
>>>> Thanks,
>>>> tobias
Re: Connections to elements in collapsed compartments [message #77263 is a reply to message #77247] |
Mon, 13 November 2006 15:16   |
You're right, those methods don't get called in the generated policy.
In my case I directly subclass CanonicalConnectionEditPolicy. In my setup
all the connections in the model are owned by the top level element of the
diagram.
The new policy has to override all the abstract methods that you inherit
(plus the ones that we talked about):
abstract protected List getSemanticConnectionsList();
* Return the supplied relationship's source element
* @param relationship semantic connection
* @return EObject the source EObject
abstract protected EObject getSourceElement(EObject relationship);
* Return the supplied relationship's target element.
* @return EObject the target EObject
abstract protected EObject getTargetElement(EObject relationship);
plus this one, which by default returns an emtpy list.
protected List getSemanticChildrenList()
You also have to override this other one:
* Manages all connections of the diagram.
protected Collection getConnectionViews() {
Diagram diagram = (Diagram) getHost().getModel();
return diagram.getEdges();
I will send you by email the contents of my policy.
vlad
> the right way...
> return source;
> @Override
> (same for target)
> return editPart;
> remove yet.
> tobias
>> refreshRatio();
>> else if
>> else if
>> refreshFont();
>> } else
>> being collapsed:
>> return false;
>> return false;
>> ? enabled
>>> not extended
>>> thanks,
>>> tobias
>>>> Hi Tobias,
>>>> EObject tel;
>>>> EditPart tep;
>>>> return tep;
>>>> EObject sel;
>>>> EditPart sep;
>>>> return sep;
>>>> edit part.
>>>> expanded:
>>>> `extend '
>>>> Here's an example:
>>>> semanticChildren);
>>>> port border items
>>>> orphaned.add(edge);
>>>> return orphaned;
>>>>> Hello,
>>>>> just disappear.
>>>>> Thanks,
>>>>> tobias
Re: Connections to elements in collapsed compartments [message #77359 is a reply to message #77263] |
Tue, 14 November 2006 05:28   |
Hello Vlad,
finally some progress:
I really forgot to implement the getSemanticConnections method...
Now I implemented it and all the methods are called - unfortunately only
when I close and reopen the diagram. If the compartment was collapsed when
I saved the diagram, there is an additional connection view attached to the
parent node, which stays in place when I expand/collapse the compartment,
leading to a second edge. So in fact the collapse/extend behavior is
exactly the same, just with an additional edge to the parent node if the
node was collapsed when the diagram was opened.
My getSemanticConnectionsList return a list with the connections and my
getSemanticChildrenList returns all the nodes (generator-default). Adding
the connections to he list showed no difference. My getConnectionViews is
just like yours. The implementation of the other methods did not change
since my last post.
I think the error must be somewhere else, e.g. in the refreshing/event
handling, since it works fine when closing/reopening.
As I said I copied your handleNotificationEvent method in my
ResizableCompartmentEditPart and it is called and branches correctly when I
collapse the compartment, too. However, the methods implemented in the
CanonicalConnectionEditPolicy are not called...
BTW, how did you override the cleanCanonicalChildrenMethod? I can not do
so...
tobias
> diagram.
> vlad
Re: Connections to elements in collapsed compartments [message #77427 is a reply to message #77359] |
Tue, 14 November 2006 10:05   |
You have to call a refresh explicitly. From the compartment editPart, do
smth like this:
EditPart diagramEditPart = this.getViewer().getContents();
policy = (B2CanonicalConnectionEditPolicy) diagramEditPart
.getEditPolicy(Bluenose2EditPolicyRoles.CANONICAL_CONNECTION _ROLE);
policy.refresh();
substituting with your appropriate choices.
If refresh still doesn't do anything, let me know. The refresh might not
work right away if the policy is temporarily disabled by a
ToggleCanonicalModeCommand. But it should be done, at the end of the
current command.
For more on this look at the gmf GraphicalEditPart#disableCanonicalFor.
> so...
I couldn't either so that's how I ended up copy & pasting the canonical
policies in my own code. If you do that the best way is to install a
canonical policy on the canonical role that only synchs the children. And
then install the customized one on a different role, other than
CANONICAL_ROLE.
In cleanCanonical you have to remove the stale diagram edge, and add
the connection corresponding to that edge back to the connection list
- it's in the code I sent you.
So basically, if you make sure the refresh works, and find some way to
override cleanCanononicalChildren() then the whole thing should work. My
implementation does smth similar and it works fine.
vlad
Re: Connections to elements in collapsed compartments [message #77736 is a reply to message #77427] |
Wed, 15 November 2006 07:02   |
I made the refresh and all my methods _would_ get called if the
cleanCanononicalChildren() method did not remove all the edges from the
semantic children list. The refresh is called before the views attached to
the inner node were deleted, so all of them had a view and did not need to
be refreshed... isn't this kinda strange behaviour?
Further the behavior seems to be more or less random! In the current
configuration, sometimes it works at least when closing and reopening a
diagram. And then, five minutes later, without having changed anything
noteworthy, it doesn't work anymore even when closing and reopening the
diagram... this might be due to the fact that when opening a diagram with a
collapsed compartment, for a very short time the connection can be seen
pointing to some point inside the compartment (where the inner node was
located), and then disappears (see above pararaph)
I tried to Copy-Paste the whole Canonical(Connection)EditPolicy in my own
project for adapting the cleanCanononicalChildren() in some way, but after
doing so there were some severe problems with the editor resulting in the
inability to draw any diagram elements. Maybe caused by a failed casting to
the 'real' Canonical(Connection)EditPolicy somewhere in the code...
Whew, if I knew this would be so much effort... I think I'll put this
problem on the heap and focus on something else for now. Thank you for all
your help and incredible patience. :-)
tobias
PS.: Your mail did not arrive here. Maybe my eMail-providers Spam-protection
got it...
>> I collapse the compartment, too. However, the methods implemented in the
> smth like this:
> policy.refresh();
> current command.
>> so...
> CANONICAL_ROLE.
> vlad
Re: Connections to elements in collapsed compartments [message #77956 is a reply to message #77736] |
Wed, 15 November 2006 12:27   |
I think those views aren't deleted, their edit parts are hidden.
This won't work. Split it in two. One policy derived from the gmf
CanonicalEditPolicy handles only the semanticChildren and is installed on
the canonical role.
The copy pasted one, since it won't be a gmf canonical policy anymore,
installed it on some other role eg. My_Canonical_Role and have it refresh
connections only. Finally, in the one method similarly:
semanticChildren);
if (orphaned.contains(edge) == false) {
orphaned.add(edge);
semanticChildren.add(edge.getElement());
return orphaned;
> tobias
> got it...
>> smth like this:
>> policy.refresh();
>> current command.
>>> so...
>> CANONICAL_ROLE.
>> vlad
Re: Connections to elements in collapsed compartments [message #78024 is a reply to message #77956] |
Wed, 15 November 2006 16:01   |
Right, you wrote this before. Sorry, I somehow lost the view on this. Ok, so
I'll give it one last try... tomorrow. ;-)
Again, thank you for all your help. I'll let you know if it works.
tobias
>> to the inner node were deleted, so all of them had a view and did not
>> need to be refreshed... isn't this kinda strange behaviour?
>> a collapsed compartment, for a very short time the connection can be seen
>> after doing so there were some severe problems with the editor resulting
>> in the inability to draw any diagram elements. Maybe caused by a failed
>> casting to the 'real' Canonical(Connection)EditPolicy somewhere in the
>> code...
> the canonical role.
> semanticChildren);
> orphaned.add(edge);
> return orphaned;
>> all your help and incredible patience. :-)
>> tobias
>> Spam-protection got it...
>>>> when I collapse the compartment, too. However, the methods implemented
>>>> in the CanonicalConnectionEditPolicy are not called...
>>> smth like this:
>>> policy.refresh();
>>> current command.
>>>> do so...
>>> And then install the customized one on a different role, other than
>>> CANONICAL_ROLE.
>>> vlad
Re: Connections to elements in collapsed compartments [message #78403 is a reply to message #78024] |
Fri, 17 November 2006 06:43   |
It still doesn't work. I must be doing something terribly wrong...
Could you please try to send me that file again? Please try this adress:
tobias.kuester [at] t-online.de to avoid the spam catcher.
I now restored the generated canonicalconnectioneditpolicy and created a new
one. The getSemanticConnections returns an empty list, so this one should
not mess with the connections, right?
Then I copied that Policy [1], made it extend copies of the parent edit
policies and added all the customizations, including the overridden
cleanCanonicalSemanticChildren. I added a conditon, to add the edge's
elements only then to semanticChildren (where it has been removed from
earlier) if it is not already contained in there.
However, while the refreshing seems to work, the edges connected to the
container do not disappear (and by this grow more and more).
I even tried to advice the refreshSemanticConnections to remove all the
edges (skipping the cleanCanSemChildren) and then create new Connections
for all the semantic connections. No luck.
What makes me wonder most is that the diagram is fine and all the duplicate
edges gone, when I close and reopen it. Can't I somehow just fake a
close-reopen cycle?
tobias
[1] I also tried to create a new one from scratch, which behaved even
worse...
> so I'll give it one last try... tomorrow. ;-)
> tobias
>>> with a collapsed compartment, for a very short time the connection can
>>> be seen pointing to some point inside the compartment (where the inner
>>> node was located), and then disappears (see above pararaph)
>>> own project for adapting the cleanCanononicalChildren() in some way, but
>>> code...
>> the canonical role.
>> semanticChildren);
>> orphaned.add(edge);
>> return orphaned;
>>> tobias
>>>> do smth like this:
>>>> policy.refresh();
>>>> not work right away if the policy is temporarily disabled by a
>>>> current command.
>>>>> do so...
>>>> CANONICAL_ROLE.
>>>> My implementation does smth similar and it works fine.
>>>> vlad
Current Time: Sun Sep 14 05:49:48 EDT 2025
Powered by FUDForum. Page generated in 0.17274 seconds
