Home » Eclipse Projects » Eclipse 4 » e4 update site for eclipse 4.2 releases/built/integrations
e4 update site for eclipse 4.2 releases/built/integrations [message #760824] Mon, 05 December 2011 06:41 Go to next message
If I attempt to install e4 0.11 Updates - http://download.eclipse.org/e4/updates/0.11, this does not work.
If I attempt to use http://download.eclipse.org/e4/updates/0.12 no groups/artifacts can be found.
Is there a site that I can use?
Re: e4 update site for eclipse 4.2 releases/built/integrations [message #761108 is a reply to message #760824] Mon, 05 December 2011 17:57 Go to previous messageGo to next message
If you're trying to install 4.2, you should use
http://download.eclipse.org/eclipse/updates/4.2-I-builds
Though I find I need to also specify the following too:
http://download.eclipse.org/e4/updates/0.12-I-builds
http://download.eclipse.org/eclipse/updates/3.8-I-builds
Re: e4 update site for eclipse 4.2 releases/built/integrations [message #770333 is a reply to message #760824] Fri, 23 December 2011 18:58 Go to previous messageGo to next message
Never mind. All I needed to do was post my stupid question and the answer revealed itself. Embarrassed
[Updated on: Fri, 23 December 2011 19:11] by Moderator
Re: e4 update site for eclipse 4.2 releases/built/integrations [message #770481 is a reply to message #770333] Sat, 24 December 2011 06:18 Go to previous message
If you tell us what you are trying to develop we might help you better.
If you download the Eclipse 4.2 SDK [1] you should have fairly all you
need. If you want to develop e4 applications you should install the e4
tools from the e4-updatesite [2].
Tom
[1]http://download.eclipse.org/eclipse/downloads/
[2]http://download.eclipse.org/e4/downloads/
Am 24.12.11 00:58, schrieb Missing name Mising name:
> After a few months of neglect my development setup for e4 ceased to
> function. After wasting too many hours trying to repair it I'm now
> trying to setup again with a current version one but can't seem to find
> anything that works. I'm sure it doesn't help that I'm more than a
> little unclear on what the different pieces are that I need. Is there
> such a thing as an all in one download for this? If not, is there any
> sort of halfway current tutorial on how to setup for e4 dev? Seems most
> every link I find is a dead end.
Previous Topic:Limit child count of a PartSashContainer
Next Topic:EMF version for e4 4.2M4?
Current Time: Sun Jul 27 11:13:42 EDT 2025
Powered by FUDForum. Page generated in 0.04022 seconds
