Home » Archived » BIRT » Get an IReportDocument from IRunAndRenderTask(Is it possible get an instance of IReportDocument from an IRunAndRenderTask)
Get an IReportDocument from IRunAndRenderTask [message #769684] Thu, 22 December 2011 09:30 Go to next message
I have an application that generates report in a given output format(e.g. : HTML, PDF, ...) using report engine API, to generate the report in the desired format i create an IRunAndRenderTask instance and then call the run() method, this generate the report in the desired format, and everything works fine .
Now i want to retrieve also the IReportDocument of the generation and save it in a collection for later use , is it possible ? How can i get an IReportDocument from an IRunAndRenderTask ?
I assume that should be possible since RunAndRenderTask should before generate an IReportDocument and then render it ...
Re: Get an IReportDocument from IRunAndRenderTask [message #769706 is a reply to message #769684] Thu, 22 December 2011 10:07 Go to previous messageGo to next message
Hi Alessio,
I'm doing something very similar to this and have implemented it using a combination IRunTask - to create the IReportDocument - and then (at a later date or immediately) use IRenderTask to produce the output. So the short anwser is "Yes, it is possible, but use IRunTask and IRenderTask instead of IRunAndRenderTask".
Examples are given here: http://eclipse.org/birt/phoenix/deploy/reportEngineAPI.php
In summary:
String path = "/tmp/BIRTrrdemo/";
// Init engine...
EngineConfig config = new EngineConfig();
Platform.startup( config );
ReportEngineFactory ref = new ReportEngineFactory();
IReportEngine engine = ref.createReportEngine( config );
// Open design
IReportRunnable design = engine.openReportDesign( path + "test.rptdesign" );
HashMap values = getDefaultParams( design, engine );
// Run task to create document...
IRunTask task = engine.createRunTask( design );
task.setParameterValues( values );
FileArchiveWriter faw = null;
faw = new FileArchiveWriter( path + "myDocumentFile.rptdocument" );
// Creates the file representation of the IReportDocument
task.run( faw );
// Could stop here and store the IReportDocument for rendering later...
// Now render...
System.out.println( "Read & render..." );
Map< ?, ? > nowt = new HashMap< Object, Object >();
FileArchiveReader far = null;
far = new FileArchiveReader( path + "myDocumentFile.rptdocument" );
// We got the IReportDocument now...
IReportDocument doc = engine.openReportDocument( null, far, nowt );
//... render it
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName( path + "myDocumentFile.html" );
IRenderTask render = engine.createRenderTask( doc );
render.setRenderOption( options );
render.render();
You'll notice that this all uses files. I'm trying to work out how the IReportDocument might end up being streamed direct to a database and you can read all about that here:
http://www.eclipse.org/forums/index.php/t/263628/
If you are so inclined... Smile
Re: Get an IReportDocument from IRunAndRenderTask [message #769758 is a reply to message #769706] Thu, 22 December 2011 11:34 Go to previous messageGo to next message
So, i have to split the process in two distinct phase :
First step : IRunTask
Second step : IRenderTask
The only thing unclear is that you save the report document into a file and then you load it again from that file, is not possible retrieving an object of IReportDocument directly without saving and loading a from file ?
Re: Get an IReportDocument from IRunAndRenderTask [message #769767 is a reply to message #769758] Thu, 22 December 2011 11:43 Go to previous messageGo to next message
I'm not sure why you'd want to do that? You'd either want to cache it somewhere for later or do the Run/Render using IRunAndRender?
Are you trying to alter the IReportDocument just after Run, and before Render - manipulating the data for example?
I guess you could implement your own IDocArchiveWriter that pipes to an IDocArchiveReader and do what you need in the middle. I've looked at those classes and that way lies madness so be warned! Smile
Re: Get an IReportDocument from IRunAndRenderTask [message #769774 is a reply to message #769767] Thu, 22 December 2011 11:51 Go to previous messageGo to next message
No, i want an object of an IReportDocument to store into a collection in memory, for example :
LinkedList<IReportDocument> listDocument = new LinkedList<>();
listDocument.add(aGeneratedDocument);
Is there a simple way to retrieve the IReportDocument instance ?
Re: Get an IReportDocument from IRunAndRenderTask [message #769792 is a reply to message #769774] Thu, 22 December 2011 12:10 Go to previous message
I don't know the answer I'm afraid but I would guess the answer to be "no, there is no simple way"... (I'm still confused as to why you'd want to hold on to the IReportDoc like that... Smile)
Looking at the source of the implementation of IRunAndRender (org.eclipse.birt.report.engine.api.impl.RunAndRenderTask I think) it makes no mention of IReportDocument... Could be hidden elsewhere of course!
Good luck!
Previous Topic:get report title and force a specific Locale
Next Topic:Where do I find BIRT Charting Programmer Reference or BIRT Programmer Reference?
Current Time: Sat Jul 26 23:38:06 EDT 2025
Powered by FUDForum. Page generated in 0.07470 seconds
