Home » Eclipse Projects » EclipseLink » Order by primary key as a associated entity.
Order by primary key as a associated entity. [message #769597] Thu, 22 December 2011 06:49 Go to next message
I have a question about ordering in JPA using EclipseLink. JPA 2.0 allows to define @Id to associated entity (as derived identity).
So I have entities like these:
@Table(name = "entity")
public class Entity {
@Id
@ManyToOne()
@JoinColumn(name = "AE_ID")
private AssociatedEntity associated;
@Table(name = "associated")
public class AssociatedEntity {
@Id
@Column(name = "AE_ID")
private String code;
Hibernate allows to use simething like this:
SELECT entity FROM ENTITY AS entity ORDER BY entity
which creates SQL like:
SELECT .... FROM entity t0 ORDER BY t0.AE_ID"
We know that JPA specification says that ORDER BY item must be a state_field_path_expression. Is in EclipseLink any posibility how to do the same (some hint or implementation specific resolution)?
Radek
Re: Order by primary key as a associated entity. [message #769760 is a reply to message #769597] Thu, 22 December 2011 11:35 Go to previous messageGo to next message
I do not think it is support, you could consider logging a bug or enhancement.
You could double map the relationship as a Basic as well to order by the id.
With EclipseLink you can also define a QueryKey for any column using a DescriptorCustomizer and use the query key with JPQL.
Re: Order by primary key as a associated entity. [message #769762 is a reply to message #769597] Thu, 22 December 2011 11:35 Go to previous messageGo to next message
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: Order by primary key as a associated entity. [message #774652 is a reply to message #769762] Wed, 04 January 2012 05:46 Go to previous messageGo to next message
first, thank you for your replay. I've tryed both your suggestions.
1) "You could double map the relationship as a Basic as well to order by the id"
Did you mean something like this?
@Id
@ManyToOne(optional = false, fetch = FetchType.LAZY)
@JoinColumn(name = "id_asoc")
private Asoc asoc;
@Column
private Long asocId;
If I do this I get problem with metadata. I expect that the method getIdClassAttributes get me asoc attribute but instead of it get me asocId. I've found that org.eclipse.persistence.internal.descriptorsObjectBuilder in the method initializePrimaryKey changes it. I don't know if it is correct.
final EntityType<? extends Object> entityType = entityManager.getMetamodel().entity(entityClass);
final Set<SingularAttribute> idClassAttributes = (Set) entityType.getIdClassAttributes();
2) "With EclipseLink you can also define a QueryKey for any column using a DescriptorCustomizer and use the query key with JPQL."
I need to build query by criteria API. Is there any posibilities hot to use query key with criteria API?
Re: Order by primary key as a associated entity. [message #777500 is a reply to message #774652] Tue, 10 January 2012 10:55 Go to previous message
For 1) you should use the same column
@Column(name="id_asoc", insertable=false, updateable=false)
For 2)
Yes you can use a query key with criteria.
Previous Topic:Where to define schema?
Next Topic:Erroneously duplicated @DiscriminatorValue - don't try this at home
Current Time: Thu Jul 24 23:15:15 EDT 2025
Powered by FUDForum. Page generated in 0.04057 seconds
