Home » Modeling » EMF » [CDO] Notification#getOldValue always null?
[CDO] Notification#getOldValue always null? [message #769644] Thu, 22 December 2011 08:07 Go to next message
Hi All,
I'm observing that when I add an Adapter to an object and then somewhere
else change the change the value of a reference from one object to
another, that the notification that comes to my adapter always has
getOldValue() as null. Identifying the newValue and the notifier works fine.
I am observing the changed object as retrieved through a CDOView with:
view.options().addChangeSubscriptionPolicy(CDOAdapterPolicy.ALL);
I am setting the reference in a CDOTransaction in the same VM.
The adapters view has already loaded the object being adapted as well as
the old and new reference objects.
Is this expected? Perhaps this is something I need to configure? I need
the old value in order to perform some fine-grained updates on a JFace
Viewer.
Dan
Re: [CDO] Notification#getOldValue always null? [message #769653 is a reply to message #769644] Thu, 22 December 2011 08:27 Go to previous messageGo to next message
Does
CDOView.Options.setInvalidationPolicy(CDOInvalidationPolicy.RELAXED) help?
Tom
Am 22.12.11 14:07, schrieb Dan Pollitt:
> Hi All,
> fine.
> Viewer.
> Dan
Re: [CDO] Notification#getOldValue always null? [message #769660 is a reply to message #769653] Thu, 22 December 2011 08:46 Go to previous messageGo to next message
No - looks to behave in the same way. I also tried setting on the session:
((org.eclipse.emf.cdo.net4j.CDOSession.Options) session.options())
.setPassiveUpdateMode(PassiveUpdateMode.CHANGES);
That didn't seem to change the observed behaviour either.
I'm using org.eclipse.emf.cdo version 4.0.1.v20110831-1303
Dan
On 22/12/2011 13:27, Tom Schindl wrote:
> Does
> Tom
>> Hi All,
>> fine.
>> Viewer.
>> Thanks,
>> Dan
Re: [CDO] Notification#getOldValue always null? [message #772257 is a reply to message #769644] Thu, 29 December 2011 06:05 Go to previous messageGo to next message
Hi Dan,
Can you please submit a bugzilla?
Cheers
/Eike
http://www.esc-net.de
Am 22.12.2011 14:07, schrieb Dan Pollitt:
> Hi All,
> I'm observing that when I add an Adapter to an object and then somewhere else change the change the value of a
> reference from one object to another, that the notification that comes to my adapter always has getOldValue() as null.
> The adapters view has already loaded the object being adapted as well as the old and new reference objects.
> Is this expected? Perhaps this is something I need to configure? I need the old value in order to perform some
> fine-grained updates on a JFace Viewer.
> Dan
Re: [CDO] Notification#getOldValue always null? [message #774142 is a reply to message #772257] Tue, 03 January 2012 05:55 Go to previous message
Hi Eike,
Happy New Year, just to confirm I raised
https://bugs.eclipse.org/bugs/show_bug.cgi?id=367738 for this
Dan
On 29/12/2011 11:05, Eike Stepper wrote:
> Hi Dan,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi All,
>> somewhere else change the change the value of a reference from one
>> always has getOldValue() as null. Identifying the newValue and the
>> need the old value in order to perform some fine-grained updates on a
>> JFace Viewer.
>> Thanks,
>> Dan
Previous Topic:Trouble adding an EDatatype of an EAttribute
Next Topic:Using CDO in my RCP application
Current Time: Sun Jul 27 04:43:28 EDT 2025
Powered by FUDForum. Page generated in 0.03579 seconds
