Home » Archived » BIRT » Custom Chart Wizard previews data despite PREFERENCE_ENALBE_LIVE set to false
Custom Chart Wizard previews data despite PREFERENCE_ENALBE_LIVE set to false [message #365932] Thu, 13 November 2008 12:40 Go to next message
Hey,
We're using the built in Custom Chart Wizard and have disabled live data
preview with the following code:
ChartReportItemUIActivator.getDefault().getPluginPreferences ().setValue(
ChartReportItemUIActivator.PREFERENCE_ENALBE_LIVE, false);
However, when we navigate to the second page of the wizard; the dialog
is attempting to load the preview data. The data load is failing due to
some class loading issues, causing error messages to be written to the
console as well as in the dialog. Here is the stack trace:
WARNING: Class
com._3esi.manage.report.core.handler.DefaultReportEventHandl er not found.
org.eclipse.birt.report.engine.api.EngineException: Class
at
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.getInstance(ScriptExecutor.java:133)
at
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.getInstance(ScriptExecutor.java:104)
at
org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleInitialize(ReportScriptExecutor.java:43)
at
org.eclipse.birt.report.engine.api.impl.EngineTask.loadDesig n(EngineTask.java:1309)
at
org.eclipse.birt.report.designer.data.ui.util.DummyEngineTas k.run(DummyEngineTask.java:39)
at
org.eclipse.birt.chart.reportitem.ui.ReportDataServiceProvid er.getPreviewRowData(ReportDataServiceProvider.java:340)
at
org.eclipse.birt.chart.reportitem.ui.ReportDataServiceProvid er.getPreviewData(ReportDataServiceProvider.java:244)
at
org.eclipse.birt.chart.reportitem.ui.StandardChartDataSheet$ 4.run(StandardChartDataSheet.java:1040)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at
org.eclipse.birt.report.engine.executor.ApplicationClassLoad er.loadClass(ApplicationClassLoader.java:77)
at
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.getInstance(ScriptExecutor.java:128)
... 8 more
Since we do not require the data preview; we think that disabling the
live preview should have subverted the error messages. Is there another
and/or more effective way to disable the live preview?
regards,
Karl Martens
Re: Custom Chart Wizard previews data despite PREFERENCE_ENALBE_LIVE set to false [message #769574 is a reply to message #365932] Thu, 22 December 2011 06:01 Go to previous messageGo to next message
Hello Karl,
have you solve the issue with the BIRT Chart Wizard ?
How have you set the Datasets ?
Have you an example ?
Re: Custom Chart Wizard previews data despite PREFERENCE_ENALBE_LIVE set to false [message #1073850 is a reply to message #769574] Thu, 25 July 2013 12:07 Go to previous message
bump
Previous Topic:Barcodes? - barcode4j?
Next Topic:Confusion with OSGi distribution
Current Time: Thu Nov 06 17:27:57 EST 2025
Powered by FUDForum. Page generated in 0.04328 seconds
