Home » Archived » BIRT » Missing jars for BIRT build
Missing jars for BIRT build [message #7650] Wed, 09 February 2005 17:37 Go to next message
I get the following errors:
Project org.eclipse.birt.report.engine is missing required library:
'org.eclipse.birt.report.engine/lib/Tidy.jar'
Project org.eclipse.birt.report.designer.ui is missing required library:
'org.eclipse.birt.report.designer.ui/lib/jseditor.jar'
Where can I find these jars?
Re: Missing jars for BIRT build [message #7694 is a reply to message #7650] Wed, 09 February 2005 22:44 Go to previous messageGo to next message
Originally posted by: rajeev.bigfoot.com
Is it available for download already? don't see it on esclipse.org. where
did you get it from?
"Thierry Lach" <thierry.lach@bbdodetroit.com> wrote in message
news:cue3b7$r50$1@www.eclipse.org...
Re: Missing jars for BIRT build [message #7716 is a reply to message #7650] Thu, 10 February 2005 00:30 Go to previous messageGo to next message
Thierry,
These libraries are open source developed outside of Eclipse. They are still
undergoing review by Eclipse and are not yet in CVS. You can, however,
download these from their respective project sites (don't know them off
hand.) Or, you can wait a few days; Eclipse is about done reviewing them,
and we'll then put them into CVS.
- Paul
Paul Rogers
Eclipse BIRT PMC
Re: Missing jars for BIRT build [message #7737 is a reply to message #7694] Thu, 10 February 2005 09:48 Go to previous messageGo to next message
I've checked it out of CVS. I've attached a Team Project Set of what I've
got.
"Rajeev Madnawat" <rajeev@bigfoot.com> wrote in message
news:cuelct$tbs$1@www.eclipse.org...
  • Attachment: birt.psf
    (Size: 3.20KB, Downloaded 145 times)
Re: Missing jars for BIRT build [message #7756 is a reply to message #7737] Thu, 10 February 2005 09:57 Go to previous message
Apparently my attachment was dropped.
Take the lines between ---clip--- and put them into a file called birt.psf.
You can use that as a team project set.
---clip---
<psf version="2.0">
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/birt,org.eclipse.birt.cha rt/or
g.eclipse.birt.chart.device.extension,org.eclipse.birt.chart .device.extensio
n"/>
<project
g.eclipse.birt.chart.engine,org.eclipse.birt.chart.engine"/ >
<project
g.eclipse.birt.chart.engine.extension,org.eclipse.birt.chart .engine.extensio
n"/>
<project
g.eclipse.birt.chart.reportitem,org.eclipse.birt.chart.repor titem "/>
<project
g.eclipse.birt.chart.shared,org.eclipse.birt.chart.shared"/ >
<project
g.eclipse.birt.chart.ui,org.eclipse.birt.chart.ui"/>
<project
g.eclipse.birt.chart.ui.extension,org.eclipse.birt.chart.ui. extension "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/birt,org.eclipse.birt.cor e/org
..eclipse.birt.core,org.eclipse.birt.core"/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/birt,org.eclipse.birt.dat a/org
..eclipse.birt.data,org.eclipse.birt.data"/>
<project
..eclipse.birt.report.data.oda.jdbc,org.eclipse.birt.report. data.oda.jdbc "/>
<project
..eclipse.birt.report.data.oda.jdbc.ui,org.eclipse.birt.repo rt.data.oda.jdbc.
ui"/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/birt,org.eclipse.birt.rep ort/o
rg.eclipse.birt.report.designer.core,org.eclipse.birt.report .designer.core "/
<project
rg.eclipse.birt.report.designer.tests,org.eclipse.birt.repor t.designer.tests
<project
rg.eclipse.birt.report.designer.ui,org.eclipse.birt.report.d esigner.ui "/>
<project
rg.eclipse.birt.report.engine,org.eclipse.birt.report.engine "/>
<project
rg.eclipse.birt.report.engine.emitter.fo,org.eclipse.birt.re port.engine.emit
ter.fo"/>
<project
rg.eclipse.birt.report.engine.emitter.html,org.eclipse.birt. report.engine.em
itter.html"/>
<project
rg.eclipse.birt.report.model,org.eclipse.birt.report.model"/ >
<project
rg.eclipse.birt.report.viewer,org.eclipse.birt.report.viewer "/>
<project
rg.eclipse.birt-feature,org.eclipse.birt-feature"/>
</provider>
</psf>---clip---
news:cufs8q$2nm$1@www.eclipse.org...
> got.
where
library:
Previous Topic:Getting BIRT source
Next Topic:Graphing in BIRT
Current Time: Tue Nov 04 19:24:10 EST 2025
Powered by FUDForum. Page generated in 0.03915 seconds
