Home » Eclipse Projects » Eclipse Platform » [PDE] How to load external Jars ?
[PDE] How to load external Jars ? [message #76438] Tue, 17 June 2003 11:18 Go to next message
Originally posted by: joaocm.ideais.com.br
How can I load an external Jar when developing a plugin with PDE. I've tried
to put the jar in the root folder of the plugin and write in th manifest :
<library name="xxx.jar" />
But it doesn't work.
If i put it in the build class path, it doesn't wotk too.
Thanks in advance,
Joao
Re: [PDE] How to load external Jars ? [message #76594 is a reply to message #76438] Tue, 17 June 2003 13:34 Go to previous messageGo to next message
Originally posted by: bluecoder.elivefree.net
Try right click on root of project and "properties" -> Java Build Path
-> "Add External Jars" and add it from there.
> Thanks in advance,
> Joao
Re: [PDE] How to load external Jars ? [message #76661 is a reply to message #76438] Tue, 17 June 2003 14:50 Go to previous messageGo to next message
Joao,
If you are getting a "ClassNotFoundException", it could be due to the class
loading enhancements.
Try running eclipse with the "-noPackagePrefixes" option or try declaring
all the package prefixes (for your library) in the plugin manifest file
using the <packages> element
Example:
<library name="runtime.jar">
<export name="*"/>
<packages prefixes="org.eclipse.core"/>
</library>
Sudarshan
www.spectrumscm.com
"Joao Machado" <joaocm@ideais.com.br> wrote in message
news:bcnbf2$idt$1@rogue.oti.com...
tried
> Thanks in advance,
> Joao
Re: [PDE] How to load external Jars ? [message #76755 is a reply to message #76661] Tue, 17 June 2003 15:01 Go to previous messageGo to next message
Yes, I'm getting ClassNotFoundException. I put the Jar in my PDE Project
root folder and in my plugin manifest file I wrote:
<library name="test.jar" />
When I try to instanciate a class that is inside this Jar the exception
occurs.
Looking at the Eclipse Wiki I've found that I must use a command line
option -dev teste.jar
but if I use this, eclipse doesn't found my Plugin.
Thanks again,
Joao
"Sudarshan Raghavan" <bali_n@yahoo.com> wrote in message
news:bcnkd2$s6n$1@rogue.oti.com...
> Joao,
class
> Example:
> <export name="*"/>
> </library>
> Sudarshan
> www.spectrumscm.com
> tried
> > Thanks in advance,
> > Joao
Re: [PDE] How to load external Jars ? [message #76835 is a reply to message #76594] Tue, 17 June 2003 15:36 Go to previous messageGo to next message
This is only for commom Java Projects. For plugins it only works at compile
time. At run-time it doesn't.
"B.C." <bluecoder@elivefree.net> wrote in message
news:bcnjg0$r5b$1@rogue.oti.com...
tried
> > Thanks in advance,
> > Joao
Re: [PDE] How to load external Jars ? [message #76897 is a reply to message #76438] Tue, 17 June 2003 16:26 Go to previous messageGo to next message
I found the problem. My problem was bacause I was trying to instanciate a
JNDI Initial Context.
My Code is something like :
Properties prop = new Properties();
prop.setProperty(Context.INITIAL_CONTEXT_FACTORY,
"org.jnp.interfaces.NamingContextFactory");
prop.setProperty(Context.PROVIDER_URL, "jnp://localhost:1099");
prop.setProperty(Context.URL_PKG_PREFIXES, "org.jboss.naming");
Context ctx = new InitialContext(prop);
My Jar that contains org.jnp.interfaces.NamingContextFactory is
jnp-client.jar (JBOSS jnp implementation).
If I just put :
<library name="jnp-client.jar" />
at plugin manifest file it doesn't work. I have to change my classloader
using something like this :
Thread.currentThread().setContextClassLoader(MyPlugin.class. getClassLoader()
And finally it works as expected.
Anyone knows any other way to do that ?
Thanks again,
Joao
tried
> Thanks in advance,
> Joao
Re: [PDE] How to load external Jars ? [message #76943 is a reply to message #76835] Tue, 17 June 2003 17:10 Go to previous message
Originally posted by: bhaskar_26.rediffmail.com
Joao,
First copy the jar file in the root directory (folder) of plugin.
Add the entry into runtime section of plugin.xml file ( I guess u r
already doing it). Also add it to the Project Properties(right click)>Java
Build path>Add External Jars.
Then it should work.
Bhaskar
> time. At run-time it doesn\'t.
> \"B.C.\" <bluecoder@elivefree.net> wrote in message
> > Hi,
> > Try right click on root of project and \"properties\" -> Java Build Path
> > -> \"Add External Jars\" and add it from there.
> > Joao Machado wrote:
> > > How can I load an external Jar when developing a plugin with PDE. I\'ve
> tried
> > > <library name=\"xxx.jar\" />
> > > But it doesn\'t work.
> > > If i put it in the build class path, it doesn\'t wotk too.
> > > Thanks in advance,
> > > Joao
Previous Topic:problem with IResource delete() method
Next Topic:Accesing version info
Current Time: Sat Nov 08 11:58:00 EST 2025
Powered by FUDForum. Page generated in 0.03772 seconds
