Qualifier replacement when SCM is Git [message #768667] |
Tue, 20 December 2011 10:24  |
Our buckminster properties file specifies
qualifier.replacement.*=generator:lastRevision
This works quite well for components that were checked out from subversion - the jars get build with names like my.plugin_1.0.0.r12345.jar. Here, 12345 is the subversion revision number for the most recent revision for that plugin.
However, it does not work at all for components that were checked out from Git - the jars get build with names like my.plugin_1.0.0.qualifier.jar.
Git of course does not have revision numbers, but I expected that the qualifier would be replaced by the SHA1 hash that Git uses as a sort of revision number equivalent.
Is there a way that I can get that to work? If not, what's the alternative? Does generator.lastModified work for Git?
Re: Qualifier replacement when SCM is Git [message #772221 is a reply to message #771944] |
Thu, 29 December 2011 04:31  |
On 12/28/2011 04:56 PM, Thomas Hallgren wrote:
>>> The SHA1 is useless because it doesn't reflect an increasing magnitude.
>>> Thus, using it you would get versions that are actually less than the
>>> previous one. Hence the need for lastModified rather than lastRevision
>>> when using git.
>> Wouldn't it be possible to implement a qualifier replacement which
>> extracted the timestamp from the time of the latest
>> commit (in the plugin/feature)?
> That's exactly what the lastModified does.
Aha. Cool.
/Jesper
FUDForum. Page generated in 0.21267 seconds
