Unable to Create Servlet Because of Getting Error While Creating Servlet in Eclipse for Java EE [message #768732] |
Tue, 20 December 2011 12:13  |
I am getting error every time creating a new servlet inside eclipse Java EE IDE.
A new dialogue box with the following message is coming.
"An error has occurred when create Servlet finished"
Following is the detail.-
java.lang.Error: Unresolved compilation problems:
The import org.eclipse.jst.j2ee.internal.common cannot be resolved
CreateServletTemplateModel cannot be resolved to a type
CreateJavaEEArtifactTemplateModel cannot be resolved to a variable
CreateServletTemplateModel cannot be resolved to a variable
Constructor cannot be resolved to a type
Method cannot be resolved to a type
at org.eclipse.jst.j2ee.internal.web.operations.ServletTemplate_.<init>(ServletTemplate_.java:4)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.emf.codegen.jet.JETEmitter.setMethod(JETEmitter.java:291)
at org.eclipse.jst.j2ee.internal.project.WTPJETEmitter.loadClass(WTPJETEmitter.java:388)
at org.eclipse.jst.j2ee.internal.project.WTPJETEmitter.initialize(WTPJETEmitter.java:235)
at org.eclipse.jst.j2ee.internal.project.WTPJETEmitter.<init>(WTPJETEmitter.java:114)
at org.eclipse.jst.j2ee.internal.common.operations.NewJavaEEArtifactClassOperation.generateTemplateSource(NewJavaEEArtifactClassOperation.java:243)
at org.eclipse.jst.j2ee.internal.common.operations.NewJavaEEArtifactClassOperation.generateTemplateSource(NewJavaEEArtifactClassOperation.java:182)
at org.eclipse.jst.j2ee.internal.web.operations.NewWebClassOperation.generateUsingTemplates(NewWebClassOperation.java:130)
at org.eclipse.jst.j2ee.internal.common.operations.NewJavaEEArtifactClassOperation.doExecute(NewJavaEEArtifactClassOperation.java:99)
at org.eclipse.jst.j2ee.internal.common.operations.NewJavaEEArtifactClassOperation.execute(NewJavaEEArtifactClassOperation.java:69)
at org.eclipse.jst.j2ee.internal.common.operations.AddJavaEEArtifactOperation.createClass(AddJavaEEArtifactOperation.java:70)
at org.eclipse.jst.j2ee.internal.web.operations.AddWebClassOperation.doExecute(AddWebClassOperation.java:70)
at org.eclipse.jst.j2ee.internal.common.operations.AddJavaEEArtifactOperation$1.run(AddJavaEEArtifactOperation.java:47)
at org.eclipse.jst.jee.model.internal.JEE5ModelProvider.modify(JEE5ModelProvider.java:257)
at org.eclipse.jst.jee.model.internal.Web25MergedModelProvider.modify(Web25MergedModelProvider.java:92)
at org.eclipse.jst.j2ee.internal.common.operations.AddJavaEEArtifactOperation.execute(AddJavaEEArtifactOperation.java:53)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataModelPausibleOperationImpl$1.run(DataModelPausibleOperationImpl.java:385)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataModelPausibleOperationImpl.runOperation(DataModelPausibleOperationImpl.java:410)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataModelPausibleOperationImpl.runOperation(DataModelPausibleOperationImpl.java:360)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataModelPausibleOperationImpl.doExecute(DataModelPausibleOperationImpl.java:247)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataModelPausibleOperationImpl.executeImpl(DataModelPausibleOperationImpl.java:219)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataModelPausibleOperationImpl.cacheThreadAndContinue(DataModelPausibleOperationImpl.java:89)
at org.eclipse.wst.common.frameworks.internal.datamodel.DataModelPausibleOperationImpl.execute(DataModelPausibleOperationImpl.java:207)
at org.eclipse.wst.common.frameworks.internal.datamodel.ui.DataModelWizard$1CatchThrowableRunnableWithProgress.run(DataModelWizard.java:225)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
at org.eclipse.wst.common.frameworks.internal.datamodel.ui.DataModelWizard.runOperations(DataModelWizard.java:234)
at org.eclipse.wst.common.frameworks.internal.datamodel.ui.DataModelWizard.performFinish(DataModelWizard.java:191)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:135)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
I am using
Version: Indigo Service Release 1
Build id: 20110916-0149
FUDForum. Page generated in 0.08713 seconds
