Home » Archived » BIRT » How to calculate SUM cumulative times type of string?(How to calculate SUM cumulative times type of string in format HH:mm:ss)
How to calculate SUM cumulative times type of string? [message #768509] Tue, 20 December 2011 04:34 Go to next message
index.php/fa/6503/0/
I have cumulative times in format HH:mm:ss and they display how much time did some record been in specific status. In database they are all STRING values.
How to calculate SUM of that times? should I use some sql expression or some BIRT function for this?
This is the example with statuses.
For this example I must exclude from result statuses CLOSED and ADDINFNDD.
So the final result should be : 00:01:59+00:00:05+34:20:58+00:00:07 = 34:23:09
Thanks for help!!
[Updated on: Tue, 20 December 2011 04:45] by Moderator
Re: How to calculate SUM cumulative times type of string? [message #768729 is a reply to message #768509] Tue, 20 December 2011 12:03 Go to previous messageGo to next message
Take a look at this example:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1450-time-string-sum/
I would just use a dataset filter to remove the sums you do not want.
Jason
On 12/20/2011 4:34 AM, cankovicv wrote:
> I have cumulative times in format HH:mm:ss and they display how much time did some record been in specific status. In database it is all STRING values.
> Thanks for help!!
Re: How to calculate SUM cumulative times type of string? [message #769233 is a reply to message #768729] Wed, 21 December 2011 11:10 Go to previous messageGo to next message
Thank you Jason you are legend!!!
Can I ask you one more question which is not so related with this topic?
I use parameter in some data set which asks for the name of the COMPANY and result is some graphic (not list table result).
When I use only one company graphic is correct.
But when I use % for displaying all companies the result is blank graphic. Does this cant be done through the parameters - for graphic results?
Parameter is defined as required and string text box, and data set is calling parameter COMPANY like ?
index.php/fa/6524/0/
Thanks again
  • Attachment: parameter.jpg
    (Size: 46.55KB, Downloaded 2193 times)
Re: How to calculate SUM cumulative times type of string? [message #769764 is a reply to message #769233] Thu, 22 December 2011 11:38 Go to previous messageGo to next message
Can you post the report? You may want to add a table for testing to see
if the dataset is returning values. I am attaching an example that
uses a like query.
Jason
> Thanks again
Re: How to calculate SUM cumulative times type of string? [message #772693 is a reply to message #768509] Fri, 30 December 2011 06:23 Go to previous messageGo to next message
Hi Jason,
sorry I can not open your example. Here is my report if you can find the problem. When I use ? to select all companies I am getting blank result.
I think that data set is OK in general, probably it is the problem with like query.
Thanks for help
[Updated on: Fri, 30 December 2011 06:24] by Moderator
Re: How to calculate SUM cumulative times type of string? [message #774248 is a reply to message #772693] Tue, 03 January 2012 10:28 Go to previous message
I did not see any like clauses in your query. In my example I use:
select *
from products
where productname like ?
You may also want to verify that you have the string quoted like:
select *
from products where productcode like'%'
Jason
On 12/30/2011 6:23 AM, cankovicv wrote:
> Hi Jason,
> Thanks for help
Previous Topic:Column sum based on another column
Next Topic:MySQL JDBC Driver 5.5 troubleshooting
Current Time: Wed Jul 23 05:51:54 EDT 2025
Powered by FUDForum. Page generated in 0.05976 seconds
