Home » Archived » Buckminster » Qualifier replacement when SCM is Git
Qualifier replacement when SCM is Git [message #768667] Tue, 20 December 2011 10:24 Go to next message
Our buckminster properties file specifies
qualifier.replacement.*=generator:lastRevision
This works quite well for components that were checked out from subversion - the jars get build with names like my.plugin_1.0.0.r12345.jar. Here, 12345 is the subversion revision number for the most recent revision for that plugin.
However, it does not work at all for components that were checked out from Git - the jars get build with names like my.plugin_1.0.0.qualifier.jar.
Git of course does not have revision numbers, but I expected that the qualifier would be replaced by the SHA1 hash that Git uses as a sort of revision number equivalent.
Is there a way that I can get that to work? If not, what's the alternative? Does generator.lastModified work for Git?
Re: Qualifier replacement when SCM is Git [message #768669 is a reply to message #768667] Tue, 20 December 2011 10:28 Go to previous messageGo to next message
I just noticed that the BuckyBook implies that generator.lastRevision expects that it is formatting a number. I guess that's the problem, since the Git hash is alphanumeric.
Re: Qualifier replacement when SCM is Git [message #768716 is a reply to message #768669] Tue, 20 December 2011 11:46 Go to previous messageGo to next message
Looking at what we have set for project Geppetto (that lives in git),
and the settings we have are:
qualifier.replacement.*=generator:lastModified
generator.lastModified.format='v'yyyyMMdd-HHmm
- henrik
icon14.gif  Re: Qualifier replacement when SCM is Git [message #768725 is a reply to message #768716] Tue, 20 December 2011 12:02 Go to previous messageGo to next message
Thanks Henrik. I just tried that, and it works fine. Theoretically you could have two commits within 1 minute, so the qualifier does not quite uniquely identify the state of the repository, but it's good enough for us.
Matthew
Re: Qualifier replacement when SCM is Git [message #768755 is a reply to message #768725] Tue, 20 December 2011 13:05 Go to previous messageGo to next message
The qualifier format is a standard SimpleDateFormat so feel free to add
both seconds (and microseconds ;-) ) if you feel that's needed.
- thomas
> Matthew
Re: Qualifier replacement when SCM is Git [message #768758 is a reply to message #768667] Tue, 20 December 2011 13:07 Go to previous messageGo to next message
The SHA1 is useless because it doesn't reflect an increasing magnitude.
Thus, using it you would get versions that are actually less than the
previous one. Hence the need for lastModified rather than lastRevision
when using git.
- thomas
Re: Qualifier replacement when SCM is Git [message #771903 is a reply to message #768758] Wed, 28 December 2011 08:37 Go to previous messageGo to next message
> when using git.
Wouldn't it be possible to implement a qualifier replacement which
extracted the timestamp from the time of the latest commit (in the
plugin/feature)?
/Jesper
Re: Qualifier replacement when SCM is Git [message #771944 is a reply to message #771903] Wed, 28 December 2011 10:56 Go to previous messageGo to next message
>> when using git.
> Wouldn't it be possible to implement a qualifier replacement which extracted the timestamp from the time of the latest
> commit (in the plugin/feature)?
That's exactly what the lastModified does.
- thomas
Re: Qualifier replacement when SCM is Git [message #772221 is a reply to message #771944] Thu, 29 December 2011 04:31 Go to previous message
>>> when using git.
Aha. Cool.
/Jesper
Previous Topic:Can Buckminster build Eclipse RCP Plug-in projects containing jars with dynamic file names?
Next Topic:How do you run findbugs in buckminster build?
Current Time: Sat Jul 26 21:37:27 EDT 2025
Powered by FUDForum. Page generated in 0.05945 seconds
