Home » Modeling » Graphiti » Recent addIfPossible
Recent addIfPossible [message #768299] Mon, 19 December 2011 16:54 Go to next message
After my recent upgrade to 0.9+ Graphiti I've noted an issue with a method call implemented by AbstractFeatureProvider's addIfPossible() method. Specifically, it always returns null. The local variable used as the return value is initialized to null and no other assignment is ever made to it.
In the Chess example, the CreateChessMoveFeature's create() method has a nearly identical line to the one I use.
  // Add the connection to the diagram
  newConnection = (Connection) getFeatureProvider().addIfPossible(addContext);
It returns the value without dereferencing it directly. My codes does, which is why I got an immediate NullPointerException.
Is this expected behavior? Or should I log a bug against it?
Re: Recent addIfPossible [message #768635 is a reply to message #768299] Tue, 20 December 2011 09:06 Go to previous messageGo to next message
Rhett,
this appears to be a bug. Would you please open a bugzilla?
Michael
Re: Recent addIfPossible [message #768686 is a reply to message #768635] Tue, 20 December 2011 10:55 Go to previous message
Bug 367204
Previous Topic:Difference between Add and Create Feature
Next Topic:Collapse Feature: how to hide an element?
Current Time: Fri Jul 25 23:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.45450 seconds
