Home » Eclipse Projects » Eclipse Scout » RemoteFileService (RemoteFileService with large directories)
RemoteFileService [message #766498] Thu, 15 December 2011 17:18 Go to next message
I am using RemoteFileService. In some directories we have over a 1000 mp3 files. This does not work (Out of memory) because contents of the file is loaded as well.
What I need is that I can only load the headers of the files and that I can specify the maximum number of headers returned.
Is there already some other way available in Scout to do this?
Re: RemoteFileService [message #767906 is a reply to message #766498] Mon, 19 December 2011 02:31 Go to previous messageGo to next message
I never used RemoteFiles but as I understood it, they can be resolved (with content) or just holders (without content). In the second case, they are just references on some content and they are resolve when they are consumed.
org.eclipse.scout.rt.server.services.common.file.RemoteFileService.getRemoteFiles(String, FilenameFilter, RemoteFile[], String, long)
the last long parameter is called maxBlockSize.
The default value is defined in RemoteFile:
  public static final long DEFAULT_MAX_BLOCK_SIZE = 20000000; // 20MB
Maybe you can try it with 0.
Have a look at the other getRemoteFiles(..) in the service in order to have an idea on the default values for the other parameters.
Re: RemoteFileService [message #767988 is a reply to message #767906] Mon, 19 December 2011 05:22 Go to previous messageGo to next message
Just tested with
and that works.
This method is not available in the interface so to use it I extended the interface like this:
public interface IExtRemoteFileService extends IRemoteFileService {
  RemoteFile[] getRemoteFiles(String folderPath, FilenameFilter filter, RemoteFile[] existingFileInfoOnClient, String charsetName, long maxBlockSize) throws ProcessingException;
  RemoteFile[] getRemoteFileHeaders(String folderPath, FilenameFilter filter, RemoteFile[] existingFileInfoOnClient, int maxCount) throws ProcessingException;
The first method in the interface makes the call available to the client. The second method I added to test another way to do the same. I noticed that in RemoteFileService internally there is a boolean "includeContent" but it is not available in any public method.
So I also extended RemoteFileServices and implemented the second method on it that makes use of this internal boolean.
There is a difference in performance if I run the following test code
System.out.println("get sounds with getRemoteFileHeaders");
Calendar cal = Calendar.getInstance();
Date startTime = cal.getTime();
files = SERVICES.getService(IExtRemoteFileService.class).getRemoteFileHeaders("gramma6/sounds", new NoFilenameFilter(), null, -1);
Date endTime = cal.getTime();
System.out.println("time = " + (endTime.getTime() - startTime.getTime()) + " milleseconds");
System.out.println("get sounds with getRemoteFiles , blocksize = 0");
files = SERVICES.getService(IExtRemoteFileService.class).getRemoteFiles("gramma6/sounds", new NoFilenameFilter(), null, "UTF-8", 0);
System.out.println("Total " + files.length + " files");
Output:
Total 4057 files
time = 582 milleseconds
Total 4057 files
time = 2162 milleseconds
Re: RemoteFileService [message #768051 is a reply to message #767988] Mon, 19 December 2011 08:44 Go to previous message
The time difference probably comes from this block: (RemoteFileService:114 - RemoteFileService:118)
      if (maxBlockSize > -1 && partLength > maxBlockSize) {
        partLength = partLength - startPosition;
        if (partLength > maxBlockSize) partLength = maxBlockSize;
        if (partLength <= 0) partLength = 0;
From the internal function: org.eclipse.scout.rt.server.services.common.file.RemoteFileService.getRemoteFileInternal(RemoteFile, Boolean, long, long)
In the second case, the block is skipped, because maxBlockSize = -1.
PS: I do not know why all methods are not available on the interface. This could probably be changed...
PS2: You could copy or extend this service to a ExtRemoteFileService. If you do so, do not forget to register your service in plugin.xml (client and server).
[Updated on: Mon, 19 December 2011 08:48] by Moderator
Previous Topic:External Component
Next Topic:AbstractCalendarField
Current Time: Wed Jul 23 07:48:56 EDT 2025
Powered by FUDForum. Page generated in 0.06786 seconds
