Home » Eclipse Projects » Remote Application Platform (RAP) » Jmeter | RAP(Create Test Case With Different Scenario)
Jmeter | RAP [message #766409] Thu, 15 December 2011 13:25 Go to next message
I created jMeter test case for a user A which has single menu option .It runs perfectly fine from command line.
Now i run the jMeter test case for a user B which has different menu option. It has all the options for user A + some more options.
Now the test fails when i run this from command line for user B. I get below exception.
This will be difficult to create test cases if you have to make the test case for these kinds of sceanrio.
java.lang.ClassCastException: org.eclipse.swt.widgets.Menu cannot be cast to org.eclipse.swt.widgets.Control
org.eclipse.swt.internal.widgets.shellkit.ShellLCA.setActiveControl(ShellLCA.java:228)
org.eclipse.swt.internal.widgets.shellkit.ShellLCA.processActivate(ShellLCA.java:212)
org.eclipse.swt.internal.widgets.shellkit.ShellLCA.readData(ShellLCA.java:80)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA$1.doVisit(DisplayLCA.java:96)
org.eclipse.swt.internal.widgets.WidgetTreeVisitor$AllWidgetTreeVisitor.visit(WidgetTreeVisitor.java:34)
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(WidgetTreeVisitor.java:48)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.readData(DisplayLCA.java:103)
org.eclipse.rwt.internal.lifecycle.ReadData.execute(ReadData.java:26)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.continueLifeCycle(RWTLifeCycle.java:183)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLifeCycle.java:259)
org.eclipse.swt.widgets.Display.sleep(Display.java:1174)
org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(WorkbenchAdvisor.java:361)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2734)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
org.eclipse.ui.internal.Workbench$5.run(Workbench.java:702)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:685)
How can we overcome this??
Raj
Re: Jmeter | RAP [message #767426 is a reply to message #766409] Sat, 17 December 2011 19:32 Go to previous messageGo to next message
I created work around by creating a super user in the system which has all the options so i do not get this exception any more.
Re: Jmeter | RAP [message #767427 is a reply to message #766409] Sat, 17 December 2011 19:32 Go to previous messageGo to next message
Re: Jmeter | RAP [message #767956 is a reply to message #766409] Mon, 19 December 2011 04:22 Go to previous message
JMeter is a tool to record and replay every single request of a user
session. During the test, the exact same user interaction is being
replayed. If another user has different UI elements, you have to make a
separate test for it.
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Previous Topic:Adding custom scheme for key bindings
Next Topic:Focus events not fired from browsers
Current Time: Sat Jul 19 14:23:04 EDT 2025
Powered by FUDForum. Page generated in 0.03272 seconds
