Home » Language IDEs » PHP Development Tools (PDT) » pdt 1.1 freezes eclipse
pdt 1.1 freezes eclipse [message #74990] Sat, 05 July 2008 14:55 Go to next message
Hi all,
i'm having an issue here with PDT 1.1.0 and eclipse 3.4.0 on Windows Vista.
In some cases eclipse totally freezes for 10-15 seconds when moving
the cursor over a method call on an object, ie someobject->foo().
I've already turned off Occurence Marking, and taken out any additional
libraries in the project preferences, restarted eclipse using the -clean
flag.
Anyone has an idea what might going on during those 10 seconds, or how to
track this problem down ?
Thanks!
Robert Gruendler
Re: pdt 1.1 freezes eclipse [message #75001 is a reply to message #74990] Sun, 06 July 2008 01:22 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
You could try starting Eclipse with these flags to debug things:
-console (to enable the osgi console)
-noexit (so that the osgi console won't exit if Eclipse exists, in case
you want to close Eclipse and keep console-debugging -- exit by typing
"exit" or CTRL-C)
-consolelog (to dump the same info to the local console as in
workspace/.metadata/.log)
-debug (more verbose console output)
Robert Gruendler wrote:
> I'm having an issue here with PDT 1.1.0 and eclipse 3.4.0 on Windows Vista.
> flag.
> to track this problem down ?
> Thanks!
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: pdt 1.1 freezes eclipse [message #75005 is a reply to message #74990] Sun, 06 July 2008 06:23 Go to previous messageGo to next message
Can you share with us a specific case where this happens? Code snippet is
welcome!
Thanks for reporting,
Re: pdt 1.1 freezes eclipse [message #75013 is a reply to message #75005] Sun, 06 July 2008 07:19 Go to previous messageGo to next message
I've been having the same issue. I'll try to get a full report tomorrow.
Is there a bug already open for this issue? I've looked a couple of times
this past week, but couldn't find anything. Also, when will the first
milestone be out? The wiki says today, but the front page says 2 months
ago...
Re: pdt 1.1 freezes eclipse [message #75057 is a reply to message #75013] Mon, 07 July 2008 06:01 Go to previous messageGo to next message
Here's the complete log output when starting eclipse with the following
flags:
-console -noexit -consolelog -debug
************************ START LOG ***********************************
Start VM: -Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Users\sobert\Desktop\eclipse\plugins\or g.eclipse.equinox.launcher_1.0.100.v20080509-1800.jar
-os win32
-ws win32
-arch x86
-showsplash
C:\Users\sobert\Desktop\eclipse\\plugins\org.eclipse.platfor m_3.3.100.v200806172000\splash.bmp
-launcher C:\Users\sobert\Desktop\eclipse\eclipse.exe
-name Eclipse
--launcher.library
C:\Users\sobert\Desktop\eclipse\plugins\org.eclipse.equinox. launcher.win32.win32.x86_1.0.100.v20080509-1800\eclipse_1114 .dll
-startup
C:\Users\sobert\Desktop\eclipse\plugins\org.eclipse.equinox. launcher_1.0.100.v20080509-1800.jar
-console
-noexit
-consolelog
-debug
-vm C:\Program Files\Java\jre1.6.0_06\bin\client\jvm.dll
-vmargs
-Xms40m
-Xmx256m
Install location:
file:/c:/Users/sobert/Desktop/eclipse/
Configuration file:
file:/c:/Users/sobert/Desktop/eclipse/configuration/config.i ni loaded
Configuration location:
Framework located:
file:/c:/Users/sobert/Desktop/eclipse/plugins/org.eclipse.os gi_3.4.0.v20080605-1900.jar
Framework classpath:
Splash location:
Debug options:
file:/C:/Users/sobert/Desktop/eclipse/.options not found
osgi> Time to load bundles: 16
Starting application: 1872
!SESSION 2008-07-07 11:51:27.447
eclipse.buildId=I20080617-2000
java.version=1.6.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_AT
Command-line arguments: -os win32 -ws win32 -arch x86 -console
-consolelog -debug
!ENTRY org.eclipse.ui 2 0 2008-07-07 11:51:31.472
!MESSAGE Warnings while parsing the key bindings from the
'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.488
!MESSAGE Cannot bind to an undefined command:
plug-in='org.eclipse.tm.terminal', id='org.eclipse.tm.terminal.command1'
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.503
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.534
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.550
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.581
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.597
!SUBENTRY 1 org.eclipse.ui 2 0 2008-07-07 11:51:31.628
!ENTRY org.eclipse.jface 2 0 2008-07-07 11:51:44.888
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:44.919
!MESSAGE A conflict occurred for CTRL+I:
Binding(CTRL+I,
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.format.a ctive.elements,Format
Active Elements,
Format active elements,
Category(org.eclipse.ui.category.edit,Edit,null,true),
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.ui.texteditor.TextOperationAction@e6f8d7)),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.php.ui.phpEditorScope,,,system)
Binding(CTRL+I,
Active Elements,
,,true),null),
org.eclipse.wst.sse.ui.structuredTextEditorScope,,,system)
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.106
!MESSAGE A conflict occurred for CTRL+SHIFT+F:
Binding(CTRL+SHIFT+F,
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.format.d ocument,Format,
Format selection,
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.ui.texteditor.TextOperationAction@1db2215)),
,,true),null),
Format selection,
,,true),null),
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.278
!MESSAGE A conflict occurred for CTRL+SHIFT+P:
Binding(CTRL+SHIFT+P,
ParameterizedCommand(Command(org.eclipse.php.ui.editor.goto. matching.bracket,Go
to Matching Bracket,
Moves the cursor to the matching bracket,
Category(org.eclipse.ui.category.navigate,Navigate,null,true ),
LegacyHandlerWrapper(ActionHandler(action= org.eclipse.php.internal.ui.actions.GotoMatchingBracketActio n @19ac2e3)),
,,true),null),
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.goto.mat ching.bracket,Matching
Bracket,
Go to Matching Bracket,
org.eclipse.wst.sse.ui.StructuredTextEditor$GotoMatchingBracketHandler@1710374,
,,true),null),
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.465
!MESSAGE A conflict occurred for CTRL+SHIFT+/:
Binding(CTRL+SHIFT+/,
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.ad d.block.comment,Add
Block Comment,
Enclose the selection with a block comment,
Category(org.eclipse.php.ui.category.source,Source,PHP
Source Actions,true),
LegacyHandlerWrapper(ActionHandler(action= org.eclipse.php.internal.ui.actions.AddBlockCommentActionDel egate @99c4cc)),
,,true),null),
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.add.bloc k.comment,Add
Block Comment,
Add Block Comment,
,,true),null),
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.637
!MESSAGE A conflict occurred for F3:
Binding(F3,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.ja va.open.editor,Open
Declaration,
Open an editor on the selected element,
,,true),null),
org.eclipse.ui.contexts.window,,,system)
Binding(F3,
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.Op enDeclaration,Open
Declaration,
Open the declaration of the selected element,
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.php.internal.ui.actions.OpenDeclarationAction@147480e)),
,,true),null),
Binding(F3,
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.open.fil e.from.source,Open
Selection,
Open an editor on the selected link,
LegacyHandlerWrapper(ActionHandler(action= org.eclipse.wst.sse.ui.internal.hyperlink.OpenHyperlinkActio n @cbbdf3)),
,,true),null),
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-07 11:51:45.902
!MESSAGE A conflict occurred for CTRL+SHIFT+\:
Binding(CTRL+SHIFT+\,
ParameterizedCommand(Command(org.eclipse.php.ui.edit.text.re move.block.comment,Remove
Block Comment,
Remove the block comment enclosing the selection,
LegacyHandlerWrapper(ActionHandler(action= org.eclipse.php.internal.ui.actions.RemoveBlockCommentAction Delegate @23af64)),
,,true),null),
ParameterizedCommand(Command(org.eclipse.wst.sse.ui.remove.b lock.comment,Remove
Block Comment,
Remove Block Comment,
,,true),null),
Application Started: 19141
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2008-07-07 11:51:48.367
!MESSAGE Project facet jst.web has not been defined. It is used in
plugin org.eclipse.wst.jsdt.web.core.
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2008-07-07 11:51:48.507
*************************** END LOG ***********************************
This is the output of eclipse during startup, without any interaction.
There is no more output when moving the cursor over a method call,
resulting in the already mentioned freeze. The freeze only occurs upon
certain method calls of external library objects, in my case falls
to objects of the Doctrine ORM library, or calls to objects of the
symfony library.
Eclipse recovers from the freeze after about 10-15 seconds, there is
no more debug output afterwards.
Again, my system specs:
Windows Vista Ultimate SP1 32 bit
Eclipse 3.4.0
PDT 1.1.0
I hope this is somewhat useful.
best
-robert
> times this past week, but couldn't find anything. Also, when will the
> first milestone be out? The wiki says today, but the front page says 2
> months ago...
Re: pdt 1.1 freezes eclipse [message #75110 is a reply to message #75005] Mon, 07 July 2008 17:37 Go to previous messageGo to next message
> is welcome!
I'm having similar problems
Eclipse just halts for 10 seconds or so at a time
It happens at various points
* selecting text
* while typing
* while deleting
I haven't noticed a problem with hovering...
Sadly it's making eclipse pretty much unusable :-(
Also auto-complete is only picking up about half the functions available
(and open declaration doesn't work on the missing functions)
I'm working on a large Drupal project, running on Ubuntu Linux (Sun Java 6)
Sean
Re: pdt 1.1 freezes eclipse [message #75195 is a reply to message #74990] Tue, 08 July 2008 04:50 Go to previous messageGo to next message
I think I've fixed this bug in CVS.
Please use the next nightly build, and tell us whether the problem still
exists.
> Hi all,
> flag.
> Thanks!
> Robert Gruendler
Re: pdt 1.1 freezes eclipse [message #75356 is a reply to message #75195] Tue, 08 July 2008 19:04 Go to previous messageGo to next message
hi,
i tried the latest nightly build, unfortunately the problem remains the
same. any more info i could provide to help to debug?
> exists.
>> Hi all,
>> Vista.
>> additional libraries in the project preferences, restarted eclipse
>> using the -clean flag.
>> Thanks!
>> Robert Gruendler
Re: pdt 1.1 freezes eclipse [message #75496 is a reply to message #75356] Wed, 09 July 2008 03:11 Go to previous messageGo to next message
well, the last nightly is identical to the integration build so the
problem was not fixed there. For some reason the nightly was not produced
(try the next nightly).
Re: pdt 1.1 freezes eclipse [message #75561 is a reply to message #75496] Thu, 10 July 2008 05:34 Go to previous messageGo to next message
Tried it with the new nightly (org.eclipse.php_feature-N20080709), still
the same problem.
Here's a code snippet where the bug occurs:
$q = Doctrine_Query::create()
->from('User u' )
->where ('u.id >=20000');
$this->user = $q->fetchArray();
If the cursor is put in any of these lines, it freezes for a couple of
seconds.
> produced (try the next nightly).
Re: pdt 1.1 freezes eclipse [message #75577 is a reply to message #75561] Thu, 10 July 2008 06:38 Go to previous messageGo to next message
One important fix is still not committed to the CVS, since it's waiting
for the next integration release of DLTK (otherwise nightly build will
not succeed). I'm sure fixed version will be built in a couple of days.
> the same problem.
> ->from('User u' )
> seconds.
Re: pdt 1.1 freezes eclipse [message #76070 is a reply to message #75577] Wed, 16 July 2008 11:09 Go to previous messageGo to next message
New DTLK Integration build is released. Don't know if the issue is fixed,
but it's worth a shot.
>> the same problem.
>> ->from('User u' )
>> seconds.
Re: pdt 1.1 freezes eclipse [message #76086 is a reply to message #76070] Wed, 16 July 2008 11:22 Go to previous messageGo to next message
You are absolutely right! New PDT build, which is based on new DLTK
integration build is here:
http://download.eclipse.org/tools/pdt/downloads/release.php? release=N20080716
> fixed, but it's worth a shot.
>> waiting for the next integration release of DLTK (otherwise nightly
>> build will not succeed). I'm sure fixed version will be built in a
>> couple of days.
>>> still the same problem.
>>> ->from('User u' )
>>> of seconds.
Re: pdt 1.1 freezes eclipse [message #76504 is a reply to message #76086] Sun, 20 July 2008 09:25 Go to previous messageGo to next message
I've tested the latest integration build, but the bug is still there.
Somehow i have the feeling that it might have to do something with my
setup here, as this bug pretty much makes pdt unusable and no one else
seems to have this problem.
I'll try it on a Win XP machine as ASAP, maybe it has something to do
with vista.
>>> couple of days.
>>>> ->from('User u' )
>>>> of seconds.
Re: pdt 1.1 freezes eclipse [message #76595 is a reply to message #76504] Mon, 21 July 2008 02:47 Go to previous messageGo to next message
Yeah, it's still there in the latest nightly as well (N20080720).
I was really hoping this would have been fixed by now.
Re: pdt 1.1 freezes eclipse [message #76691 is a reply to message #76595] Mon, 21 July 2008 16:24 Go to previous messageGo to next message
I've tested it on an ubuntu 8.04 box, same behaviour there.
Re: pdt 1.1 freezes eclipse [message #76737 is a reply to message #76691] Mon, 21 July 2008 22:42 Go to previous messageGo to next message
Well, I downloaded the latest nightly, and the latest integration build of
DLTK.
It looks like the freezing issue has been fixed (or at least vastly
improved). However, now I keep getting errors while I'm typing:
An internal error occurred during: "Processing Dirty Regions".
org.eclipse.dltk.compiler.problem.IProblemReporter.reportPro blem(Lorg/eclipse/dltk/compiler/problem/IProblem;)Lorg/eclip se/core/resources/IMarker;
An internal error occurred during: "Computing additional info".
An error has occurred. See error log for more details.
It's really annoying. Am I doing something wrong, or is this what other
people are getting with the latest PDT together with the new DLTK build?
Here's what I get in the error log:
java.lang.NoSuchMethodError:
at
org.eclipse.php.internal.core.compiler.ast.parser.AbstractAS TParser.reportError(Unknown
Source)
at
org.eclipse.php.internal.core.compiler.ast.parser.AbstractAS TParser.syntax_error(Unknown
Source)
at java_cup.runtime.lr_parser.parse(lr_parser.java:595)
at
org.eclipse.php.internal.core.compiler.ast.parser.AbstractPH PSourceParser.parse(Unknown
Source)
at
org.eclipse.php.internal.core.compiler.ast.parser.php5.Php5S ourceParser.parse(Unknown
Source)
at
Source)
at
org.eclipse.php.internal.core.compiler.ast.parser.PHPSourceP arserFactory.parse(Unknown
Source)
at
org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration( SourceParserUtil.java:106)
at
org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration( SourceParserUtil.java:52)
at
org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration( SourceParserUtil.java:28)
at
org.eclipse.dltk.core.search.matching.MatchLocatorParser.par se(MatchLocatorParser.java:27)
at
org.eclipse.dltk.core.search.matching.MatchLocator.parse(Mat chLocator.java:632)
at
org.eclipse.dltk.core.search.matching.MatchLocator.locateMat ches(MatchLocator.java:603)
at
org.eclipse.dltk.core.search.matching.MatchLocator.locateMat ches(MatchLocator.java:676)
at
org.eclipse.dltk.core.search.matching.MatchLocator.locateMat ches(MatchLocator.java:805)
at
org.eclipse.dltk.core.search.DLTKSearchParticipant.locateMat ches(DLTKSearchParticipant.java:124)
at
org.eclipse.dltk.core.search.BasicSearchEngine.findMatches(B asicSearchEngine.java:325)
at
org.eclipse.dltk.core.search.BasicSearchEngine.search(BasicS earchEngine.java:699)
at org.eclipse.dltk.core.search.SearchEngine.search(SearchEngin e.java:352)
at
org.eclipse.dltk.internal.core.hierarchy.HierarchyResolver.c omputeSubtypes(HierarchyResolver.java:86)
at
org.eclipse.dltk.internal.core.hierarchy.HierarchyResolver.r esolve(HierarchyResolver.java:53)
at
org.eclipse.dltk.internal.core.hierarchy.HierarchyResolver.r esolve(HierarchyResolver.java:237)
at
org.eclipse.dltk.internal.core.hierarchy.IndexBasedHierarchy Builder.buildForProject(IndexBasedHierarchyBuilder.java:278)
at
org.eclipse.dltk.internal.core.hierarchy.IndexBasedHierarchy Builder.buildFromPotentialSubtypes(IndexBasedHierarchyBuilde r.java:394)
at
org.eclipse.dltk.internal.core.hierarchy.IndexBasedHierarchy Builder.build(IndexBasedHierarchyBuilder.java:163)
at
org.eclipse.dltk.internal.core.hierarchy.TypeHierarchy.compu te(TypeHierarchy.java:338)
at
org.eclipse.dltk.internal.core.hierarchy.TypeHierarchy.refre sh(TypeHierarchy.java:1203)
at
org.eclipse.dltk.internal.core.CreateTypeHierarchyOperation. executeOperation(CreateTypeHierarchyOperation.java:89)
at
org.eclipse.dltk.internal.core.ModelOperation.run(ModelOpera tion.java:698)
at
org.eclipse.dltk.internal.core.ModelOperation.runOperation(M odelOperation.java:772)
at
org.eclipse.dltk.internal.core.SourceType.newTypeHierarchy(S ourceType.java:433)
at
org.eclipse.dltk.internal.core.search.HierarchyScope.createH ierarchy(HierarchyScope.java:396)
at
org.eclipse.dltk.internal.core.search.HierarchyScope.initial ize(HierarchyScope.java:405)
at
org.eclipse.dltk.internal.core.search.HierarchyScope.refresh (HierarchyScope.java:428)
at
org.eclipse.dltk.internal.core.search.HierarchyScope.enclosi ngProjectsAndZips(HierarchyScope.java:372)
at
org.eclipse.dltk.internal.core.search.IndexSelector.initiali zeIndexLocations(IndexSelector.java:143)
at
org.eclipse.dltk.internal.core.search.IndexSelector.getIndex Locations(IndexSelector.java:332)
at
org.eclipse.dltk.core.search.DLTKSearchParticipant.selectInd exes(DLTKSearchParticipant.java:166)
at
org.eclipse.dltk.internal.core.search.PatternSearchJob.getIn dexes(PatternSearchJob.java:95)
at
org.eclipse.dltk.internal.core.search.PatternSearchJob.ensur eReadyToRun(PatternSearchJob.java:62)
at
org.eclipse.dltk.internal.core.search.processing.JobManager. performConcurrentJob(JobManager.java:179)
at
org.eclipse.dltk.core.search.BasicSearchEngine.findMatches(B asicSearchEngine.java:288)
at
at
org.eclipse.php.internal.core.typeinference.PHPModelUtils.ge tClassMethodDoc(Unknown
Source)
at
org.eclipse.php.internal.core.typeinference.evaluators.phpdo c.PHPDocMethodReturnTypeEvaluator.init(Unknown
Source)
at org.eclipse.dltk.ti.GoalEngine.evaluateGoal(GoalEngine.java: 219)
at
org.eclipse.dltk.ti.DefaultTypeInferencer.evaluateType(Defau ltTypeInferencer.java:223)
at
org.eclipse.dltk.ti.DefaultTypeInferencer.evaluateType(Defau ltTypeInferencer.java:213)
at
org.eclipse.php.internal.core.typeinference.BindingUtility.g etType(Unknown
Source)
at
Source)
at
Source)
at
org.eclipse.php.internal.core.ast.nodes.DefaultBindingResolv er.getEvaluatedType(Unknown
Source)
at
org.eclipse.php.internal.core.ast.nodes.DefaultBindingResolv er.resolveExpressionType(Unknown
Source)
at
org.eclipse.php.internal.core.ast.nodes.DefaultBindingResolv er.resolveName(Unknown
Source)
at
org.eclipse.php.internal.core.ast.nodes.Identifier.resolveBi nding(Unknown
Source)
at
org.eclipse.php.internal.ui.actions.OpenTypeHierarchyAction. getSelectionModelElement(Unknown
Source)
at
org.eclipse.php.internal.ui.actions.OpenTypeHierarchyAction. isEnabled(Unknown
Source)
at
org.eclipse.php.internal.ui.actions.OpenTypeHierarchyAction. update(Unknown
Source)
at
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.updat eAction(Unknown
Source)
at
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.updat eCursorDependentActions(Unknown
Source)
at
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.handl eCursorPositionChanged(Unknown
Source)
at
org.eclipse.ui.texteditor.AbstractTextEditor$18.keyPressed(A bstractTextEditor.java:2981)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:155)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1182)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1167)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1194 )
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:698)
at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2761)
at
org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:702)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1543)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4502 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4099 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:57 83)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1177)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1541)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3031)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Re: pdt 1.1 freezes eclipse [message #76886 is a reply to message #76737] Wed, 23 July 2008 22:10 Go to previous messageGo to next message
Looks like the issue has been fixed with the latest integration build.
I might have also goofed before by installing the DLTK runtime, but not
the SDK.
Anyway, looks like the crazy annoying 10 second wait has now been reduced
to a 1-2 second wait for content assist, and it no longer locks up when
you mouse-over a object method. Would be nice if it was still faster with
the content assist, but it's good enough to work with. Good job guys! :-)
Re: pdt 1.1 freezes eclipse [message #76918 is a reply to message #76886] Thu, 24 July 2008 05:58 Go to previous messageGo to next message
Originally posted by: kkunjas.gmail.com
Na Thu, 24 Jul 2008 02:10:41 +0000, David Muir napisao:
> Looks like the issue has been fixed with the latest integration build. I
> the SDK.
> reduced to a 1-2 second wait for content assist, and it no longer locks
> up when you mouse-over a object method. Would be nice if it was still
> faster with the content assist, but it's good enough to work with. Good
> job guys! :-)
hm, i'm still having the same problem, even worse now. I have tried
several clean installs with latest integration and nightlies, and still no
luck.
for me, eclipse freezes on selecting with mouse on php code...
btw. how do you install on ganyamede?
i took latest j2ee 34.4 build, and just added latest dltk and pdt ( as
stated on integration build page)
Re: pdt 1.1 freezes eclipse [message #77124 is a reply to message #76918] Thu, 24 July 2008 19:11 Go to previous messageGo to next message
I installed:
GEF 3.4 SDK version from Ganymede update site.
WTP 3.0 SDK version from Ganymede update site.
I then downloaded:
The latest DLTK Core Frameworks Integration 1.0 SDK version from DLTK
download page.
The latest PDT Integration build from PDT download page.
To install DLTK and PDT, unzip the packages into a folder, and add this as
a local update site in the update manager.
I installed DLTK first and then PDT (not sure if it matters though).
Once installed, make sure you do a clean rebuild of your projects.
(Projects->Clean...)
Re: pdt 1.1 freezes eclipse [message #77155 is a reply to message #77124] Fri, 25 July 2008 07:37 Go to previous messageGo to next message
Na Thu, 24 Jul 2008 23:11:47 +0000, David Muir napisao:
> I installed:
> GEF 3.4 SDK version from Ganymede update site. WTP 3.0 SDK version from
> I then downloaded:
> download page.
> as a local update site in the update manager. I installed DLTK first and
done exactly that several times, and it's still the same ( a tried a amd64
build of eclipse at home, and same problems occure)
i did a clean build now and now i get "only" about 5 sec freeze when
typing $, >, and selecting text in editor with mouse.
a bit better, but still far from expected...
Thanks for Projects->clean, i didn't know that i must do this on every
upgrade...
Re: pdt 1.1 freezes eclipse [message #77200 is a reply to message #77155] Sat, 26 July 2008 07:28 Go to previous messageGo to next message
Yeah, it's not mentioned anywhere in the installation docs. I should
probably add that in a bug report. Maybe it's something you need to do in
general with any Eclipse update, but I'd never come across it in the two
years that I've been using it. I only stumbled across it when I was trying
to get "open declaration" working.
Re: pdt 1.1 freezes eclipse [message #77216 is a reply to message #77155] Sun, 27 July 2008 03:36 Go to previous messageGo to next message
Can you tell how many open projects do you have in your workspace, and
what is the estimation of how many PHP line numbers are there?
Do you use some known PHP framework?
Thanks!
>> I installed:
>> I then downloaded:
>> download page.
> upgrade...
Re: pdt 1.1 freezes eclipse [message #77264 is a reply to message #77216] Sun, 27 July 2008 19:18 Go to previous messageGo to next message
I am experiencing the same issue, my stats follow:
Ganymede amd64 build with machine of 2gb ram and 512M for eclipse (Heap
manager rarely shows the program exceeding 400mb).
I have 55591 total PHP lines, 3085 files, ~100 php5 classess, and it takes
8-15 seconds for the autocomplete to show.
For the record, aptana, Zend 5.5 and Zend 6.01 are all ~.5-1.5 seconds.
Re: pdt 1.1 freezes eclipse [message #77297 is a reply to message #77264] Mon, 28 July 2008 03:47 Go to previous messageGo to next message
Is your code placed locally or is it accessed via network?
Thanks!
> takes 8-15 seconds for the autocomplete to show.
Re: pdt 1.1 freezes eclipse [message #78493 is a reply to message #77216] Mon, 18 August 2008 07:23 Go to previous message
Na Sun, 27 Jul 2008 10:36:14 +0300, Michael Spector napisao:
it ranges from 50 - 2000 or even more, depends on the file opened.
I have only one php project open at the time ( but the effect is the same
even if several are opened)
yep, i'm using symfony, propel, doctrine
> Thanks!
np
btw. with latest dltk ( 1.0m1) and latest nightly the freezes are minimal
( around 1 sec, or less) so thing are looking better now, and i can finaly
actualy use PDT ;)
Previous Topic:java.lang.NullPointerException in PDT
Next Topic:Filtering Directories
Current Time: Thu Jul 24 21:45:27 EDT 2025
Powered by FUDForum. Page generated in 0.29672 seconds
