[Xpand] import issue [message #765725] |
Wed, 14 December 2011 10:29  |
i'm trying to export my ecore to a .csv file but i've a issue with the import:
when i try to import my ecore model with «IMPORT mindmap» an error appear
Quote:Description Resource Path Location Type
"stringLiteralExpCS"is invalid(generator:1:9:1:16: ) generator.xpt /org.eclipse.dsl.project/templates line: 1 (8 .. 16) Xpand Problem
what can i do to resolve this kind of problem?
this is my .xpt
Quote:«IMPORT mindmap»
«DEFINE Main FOR Map»
«FILE title + ".csv"-»
«FOREACH elements.typeSelect(Topic) AS topic-»
«topic.name»,«topic.start»,«topic.end»
«ENDFOREACH»
«ENDFILE»
«ENDDEFINE»
tis is my .mwe
Quote:<?xml version="1.0"?>
<workflow>
<property name="model"
value="platform:/resource/org.eclipse.dsl.mindmap/model/Mindmap.xmi"/>
<property name="out" value="out" />
<!-- set up EMF for standalone execution -->
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value="../" />
</bean>
<component class="org.eclipse.emf.mwe.utils.Reader">
<uri value="${model}" />
<modelSlot value="model" />
</component>
<!-- generate code -->
<component class="org.eclipse.xpand2.Generator">
<metaModel id="mm"
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
<expand value="mindmap2csv::Main FOR model" />
<outlet path="${out}"/>
</component>
</workflow>
edit
i've try some change on the .mwe that now is
<workflow>
<property name="model" value="platform:/resource/org.eclipse.dsl.mindmap/model/mindmap.xmi" />
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" >
<platformUri value=".."/>
<registerEcoreFile value="platform:/resource/org.eclipse.dsl.mindmap/model/mindmap.ecore" />
</bean>
</bean>
<bean id="mm_emf" class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
</component>
<metaModel idRef="mm_emf"/>
<expand
value="template::Template::main FOR model" />
<outlet path="${src-gen}" >
<postprocessor class="org.eclipse.xpand2.output.JavaBeautifier" />
</outlet>
</component>
</workflow>
[Updated on: Wed, 14 December 2011 11:55] by Moderator
FUDForum. Page generated in 0.05556 seconds
