More context menus for editor [message #765728] |
Wed, 14 December 2011 10:32  |
how can I have more context menus in my editor? I have a TableViewer and a ListViewer side by side in the editor part and I would like to contribute the theirs context menus independently. Both viewers show same model elements.
getSite().setSelectionProvider(tableViewer);
MenuManager menuMgr = new MenuManager();
menuMgr.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
Menu menu = menuMgr.createContextMenu(tableViewer.getControl());
tableViewer.getControl().setMenu(menu);
getSite().registerContextMenu(menuMgr, tableViewer);
Menu menu = menuMgr.createContextMenu(listViewer.getControl());
listViewer.getControl().setMenu(menu);
getSite().registerContextMenu("secondMenu", menuMgr, listViewer);
when I contribute a menu like this:
<menuContribution locationURI="popup:org.eclipse.ui.popup.any?after=additions">
<command commandId="myCommandId" style="push">
<visibleWhen checkEnabled="false">
<and>
<count value="1"></count>
<iterate>
<instanceof value="myModelObject"></instanceof>
</iterate>
</and>
</visibleWhen>
</command>
</menuContribution>
in the table's context menu the contribution shows up correctly. But the list's menu is empty. I guess its because of the line
Which selectionProvider to register with the site when I have more of them by the way?
Re: More context menus for editor [message #765748 is a reply to message #765728] |
Wed, 14 December 2011 10:51   |
On 2011-12-14 16:32, Behnil wrote:
> <menuContribution
> <and>
> <iterate>
> </iterate>
> </and>
> </visibleWhen>
> </command> </menuContribution>
> them by the way?
If you have more than one context menu per view you should assign
different menu ids to *both*, i.e. use
MenuManager menuMgr = new MenuManager(null, "firstMenuId");
getSite().registerContextMenu("firstMenuId", menuMgr, tableViewer);
and
MenuManager menuMgr = new MenuManager(null, "secondMenuId");
getSite().registerContextMenu("secondMenuId", menuMgr, listViewer);
HTH & Greetings from Bremen,
Daniel Krügler
Re: More context menus for editor [message #766763 is a reply to message #766104] |
Fri, 16 December 2011 06:34   |
Well, I have still a problem with this.
I have this menu contribution:
<command commandId="myCommand" style="push">
<with variable="activeMenuSelection">
<and>
<iterate>
<instanceof value="myModel"></instanceof>
</iterate>
</and>
</with>
</visibleWhen>
</command>
</menuContribution>
Let's say my editor contains a TableViewer. This TableViewer is registered as selection provider to the editor's site.
It has also a context menu which is registered to the site so it can be contributed by other plugins.
MenuManager menuMgr = new MenuManager(null, "editor.mainContextMenu");
getSite().registerContextMenu("editor.mainContextMenu", menuMgr, tableViewer);
Context menu is shown properly.
Now let's say that I can open a non modal dialog from this editor. In the dialog is a ListViewer containing the same model as the editor's TableViewer.
And would like to get context menu on that ListViewer also extended by other plugins. So I pass the editor's IWorkbenchPartSite to the dialog when is opened
and register ListViewer's context menu:
MenuManager menuMgr = new MenuManager(null, "editor.dialogContextMenu");
editorSite.registerContextMenu("editor.dialogContextMenu", menuMgr, listViewer);
Now when the dialog is open, context menu show properly. That's amazing.
But, when I left click on the editor and then I click back to the dialog and pres right click on the listViewer, listViewer's context menu isn't shown at all.
When I after that right click on the tableViewer and then again right click on the listViewer, context menu shows up properly.
I really don't understand what is happening here.
After some debugging I found the MenuManager on the listViewer handleAboutToShow() and immediately after that handleAboutToHide() called.
So the context menu can't be shown I guess. but why is the handleAboutToHide() called and why right click on the tableViewer fixes that, is a mystery.
FUDForum. Page generated in 0.29360 seconds
