Home » Archived » XML Schema Definition (XSD) » Only relative path is accepted by XSD Validator
Only relative path is accepted by XSD Validator [message #76600] Wed, 24 December 2008 01:29 Go to next message
Hello Ed,
When i validate an XSD schema it doesnt accept the project relative paths
at all and i always have to give a relative path to the file being
validated in the import which is kind of not uderstandable directly when i
look at it.
Can you please tell if there is any way i could tell the validator to
accept project relative paths or the rational behind this.
Thanks and regards,
Keshav Veerapaneni.
Re: Only relative path is accepted by XSD Validator [message #76651 is a reply to message #76600] Wed, 24 December 2008 04:40 Go to previous message
Keshavrao,
Comments below.
Keshavrao wrote:
> Hello Ed,
What's that?
Relative to what?
> being validated in the import which is kind of not uderstandable
> directly when i look at it.
I've not understood so far either. :-P
I'm not quite sure what you mean. You can use
URI.createPlatformResourceURI("/project1/my.xsd", true) to create a
proper absolute URI that addresses the workspace and then any relative
references within my.xsd, e.g., ../project2/other.xsd will also resolve
to a proper absolute URI that addresses the workspace...
> Thanks and regards,
> Keshav Veerapaneni.
Re: Only relative path is accepted by XSD Validator [message #603560 is a reply to message #76600] Wed, 24 December 2008 04:40 Go to previous message
Keshavrao,
Comments below.
Keshavrao wrote:
> Hello Ed,
What's that?
Relative to what?
> Thanks and regards,
> Keshav Veerapaneni.
Previous Topic:Only relative path is accepted by XSD Validator
Next Topic:EMF model from XML Schema fails if duration has default value
Current Time: Fri Jul 18 17:21:04 EDT 2025
Powered by FUDForum. Page generated in 0.03505 seconds
