Home » Archived » BIRT » Subtotal before page break
Subtotal before page break [message #765116] Tue, 13 December 2011 07:58 Go to next message
Hi, how can I display a subtotal before a page break? I have a large table that spans over more than one sheet of paper (PDF). We would like to show a subtotal at the bottom of every page and a total at the end of the table.
Thanks for any pointers
Peter
Re: Subtotal before page break [message #765258 is a reply to message #765116] Tue, 13 December 2011 12:50 Go to previous messageGo to next message
Peter,
I am not sure how you are running the reports, but if you are using two
task run task and then a render task (/frameset servlet mapping on
viewer) you should be able to do this with a page variable and some
script. Look at the attached example. The page variable is used in the
page header and totals the quantity field for each page.
Jason
> the table.
> Peter
Re: Subtotal before page break [message #765705 is a reply to message #765258] Wed, 14 December 2011 09:53 Go to previous messageGo to next message
Thanks Jason,
I have a IRunAndRenderTask and assume that this is not going to work then (I tried your example in "View Report as PDF" where the totals are shown but are one page off). I probably will try to change to a 2 task rendering and will then be able to use this.
Best Regards
Peter
Re: Subtotal before page break [message #765803 is a reply to message #765705] Wed, 14 December 2011 12:43 Go to previous message
Peter,
Currently page variables and pagination manipulation are only supported
with two phase operation,
Jason
On 12/14/2011 9:53 AM, Peter Kullmann wrote:
> Thanks Jason,
> Best Regards
> Peter
Previous Topic:WSDL datasource-birt report generation
Next Topic:setting resource folder for getReport.bat
Current Time: Sat Jul 26 11:06:43 EDT 2025
Powered by FUDForum. Page generated in 0.25951 seconds
