How to embed a link into object? [message #765659] |
Wed, 14 December 2011 08:27  |
I am bringing a value (which is a link to a product on a external web page and it depends on a product user wants to see) from a database. It's presented in a data box on which user can click and open that web location in a new window. That is working fine.
I have a question about one thing. How to make this field to have a "label" saying "Website" but to keep it to be a link to the page depending on a value that comes from database? In a way to embed a value from a db so the user have a nicer text in front of him (saying something like "Product on the Web", but still to have it running as a link.
Thanks!
[Updated on: Wed, 14 December 2011 08:28] by Moderator
Re: How to embed a link into object? [message #766113 is a reply to message #765797] |
Thu, 15 December 2011 03:44   |
Hello Jason,
I was so embarrassed when I figured it out about my question that I put into my comment
Answer was right there in my question, use label Type URI, and put into Location: row["website"] from dataset that contains the link Type: Blank and voila! You click on a label and it opens it new window, exactly what I need!
First I was trying with text object, but that one doesn't have a hyperlink feature, then I jumped on data object skipping label (thinking that it's simpler than text, how can it have a hyperlink if text doesn't have?) but data object would bring a value from db which would work but I couldn't change the name on it(label). Somehow I went back to label and there it was.... So simple.
As I mentioned before, I am just a starter in BIRT so I need to learn more. Any books that can be found online, since here where I am it's hard to buy or order online? For free, of course
Thank you Jason once again for your help.
Re: How to embed a link into object? [message #766342 is a reply to message #766113] |
Thu, 15 December 2011 10:24   |
For online info, check birt-exchange.org. There are a lot of examples
and webinars available in the dev share. In the designer, if you select
help-contents you will see the BIRT Report Developer Guide which should
be very helpful. You also may want to follow on the
birtworld.blogspot.com blog.
Jason
On 12/15/2011 3:45 AM, nlajka wrote:
> Hello Jason,
> :blush: into my comment :)
> I need!
> hard to buy or order online? For free, of course :lol:
FUDForum. Page generated in 0.03022 seconds
