Home » Eclipse Projects » Remote Application Platform (RAP) » java.lang.NoSuchMethodError: org.eclipse.swt.widgets.Display.sleep()Z
| java.lang.NoSuchMethodError: org.eclipse.swt.widgets.Display.sleep()Z [message #76546] |
Tue, 04 March 2008 15:57   |
Eclipse User  |
I'm attempting to deploy my application to Tomcat 6 and receiving the
following error when I hit the application:
osgi> [2008-03-04T14:31:47] [ERROR] [UIThread
[52537386199960BFD3A4F7311DEAB8F9]]
[com.cerner.system.preferences.explorer.platform.A
pplication]
  + Message: An application error has occurred.
  + Throwable: java.lang.NoSuchMethodError:
        at
 com.cerner.system.preferences.explorer.authentication.ml.Log inDialog.open(LoginDialog.java:184)
        at
 com.cerner.system.preferences.explorer.authentication.ml.Pre ferencesExplAuthenticator.authenticate(PreferencesExplAuthen t
icator.java:98)
        at
 com.cerner.system.preferences.explorer.platform.authenticati on.AuthenticatorManager.login(AuthenticatorManager.java:64)
        at
 com.cerner.system.preferences.explorer.platform.Application. createUI(Application.java:40)
        at
 org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
        at
 org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:212)
        at
 org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:109)
The code is attempting to open a login dialog.  The application works just
great when running in the IDE, but the deployed version on Tomcat does not.
I'm using the M2 version which now supports the readAndDispatch.  I believe
I'm packaging all the correct versions of rwt as shown in my osgi status:
 64      ACTIVE      org.eclipse.rap.rwt_1.1.0.20080220-1610
65      ACTIVE      org.eclipse.rap.ui.forms_1.1.0.20080220-1610
66      <<LAZY>>    org.eclipse.rap.ui.views_1.1.0.20080220-1610
67      ACTIVE      org.eclipse.rap.ui.workbench_1.1.0.20080220-1610
68      RESOLVED    org.eclipse.rap.ui_1.1.0.20080220-1610
70      RESOLVED    org.restlet_1.0.0
                    Fragments=14
71      RESOLVED    slf4j.api_1.4.3
72      RESOLVED    slf4j.log4j12_1.4.3
73      ACTIVE      com.cerner.system.preferences.explorer_1.0.0.SNAPSHOT
                    Fragments=74
74      RESOLVED
 com.cerner.system.preferences.explorer.authentication.ml_1.0 .0.SNAPSHOT
                    Master=73
75      <<LAZY>>
com.cerner.system.preferences.explorer.biz_1.0.0.SNAPSHOT
                    Fragments=76
76      RESOLVED
 com.cerner.system.preferences.explorer.biz.mock_1.0.0.SNAPSH OT
                    Master=75
77      INSTALLED
 com.cerner.system.preferences.explorer.history_1.0.0.SNAPSHO T
78      <<LAZY>>
 com.cerner.system.preferences.explorer.millenniumdomain_1.0. 0.SNAPSHOT
79      <<LAZY>>
 com.cerner.system.preferences.explorer.ui.navigation_1.0.0.S NAPSHOT
80      <<LAZY>>
 com.cerner.system.preferences.explorer.search.view_1.0.0.SNA PSHOT
81      <<LAZY>>
 com.cerner.system.preferences.explorer.swt.utils_1.0.0.SNAPS HOT
Does anyone have ideas on where I might be going wrong.
Thanks!
| Re: java.lang.NoSuchMethodError: org.eclipse.swt.widgets.Display.sleep()Z [message #77184 is a reply to message #76931] |
Thu, 06 March 2008 16:40    |
Eclipse User  |
	Coincidentally, I actually saw the same thing today (including the "Z",
which I don't understand).  We have an application originally written
against SWT that we are porting to RWT.  We are able to leave a majority
of our classes in their original projects, which have SWT in the project
compile-time classpath, and simply run against RWT (comment/criticism on
this strategy is welcome).  As long as we don't use methods that are not
implemented in RWT this strategy generally works.  However for some
classes, we need to compile against RWT as well.  This was the case with
the class I was porting today with a read and dispatch loop:
	if (!display.readAndDispatch())
		display.sleep();
	It is not clear to me why this caused the NoSuchMethodError where many
other similar cases don't.  In fact, a call to Display.readAndDispatch()
in the same class, compiled against SWT but run against RWT, ran fine,
correctly entering into the RWT method, but the next line, the call to
Display.sleep(), gave the NoSuchMethodError.
	Changing this class to compile against RWT solved this problem.
	Frank, can you shed any light on this?
Ryan
Frank Appel wrote:
> really strange. Your using obviously the latest and greatest of RAP, but
> Display#sleep should be available. I'm wondering about the Z behind the
> message, any ideas? Did you have a previous version of the application
> deployed on the same tomcat? I mean maybe the working directory wasn't
> cleaned up properly or something like that - just a weak guess...
> Ciao
> Frank
> -----Ursprüngliche Nachricht-----
> Von: Dan Stocksick [mailto:dstocksick@cerner.com]
> Bereitgestellt: Dienstag, 4. März 2008 21:57
> Bereitgestellt in: eclipse.technology.rap
> Unterhaltung: java.lang.NoSuchMethodError:
> Betreff: java.lang.NoSuchMethodError:
> pplication]
>         at
>         at
> Authenticator.authenticate(PreferencesExplAuthent
> icator.java:98)
>         at
>         at
> lication.java:40)
>         at
> Manager.java:92)
>         at
> va:212)
>         at
> just great when running in the IDE, but the deployed version on Tomcat
> does not.
> believe I'm packaging all the correct versions of rwt as shown in my
> osgi status:
>                     Fragments=14
> 73      ACTIVE
>                     Fragments=74
> 74      RESOLVED
>                     Master=73
> 75      <<LAZY>>
>                     Fragments=76
> 76      RESOLVED
>                     Master=75
> 77      INSTALLED
> 78      <<LAZY>>
> 79      <<LAZY>>
> 80      <<LAZY>>
> 81      <<LAZY>>
> Thanks!
| Re: java.lang.NoSuchMethodError: org.eclipse.swt.widgets.Display.sleep()Z [message #77201 is a reply to message #77184] |
Thu, 06 March 2008 16:54    |
Eclipse User  |
Originally posted by: b.muskalla.gmx.net
the Z means "return type of type boolean" which is correct for SWT but
not for RWT. Without checking the return type of sleep the code is still
source compatible but not binary compatible as the return parameters are
different (void for RWT, boolean for SWT). Maybe Frank can clarify if we
we have time and way to be compatible. In the meantime you should
compile your code against RWT instead of SWT.
Greets
   Benny
Ryan Donnelly wrote:
> "Z", which I don't understand).  We have an application originally
> written against SWT that we are porting to RWT.  We are able to leave a
> majority of our classes in their original projects, which have SWT in
> the project compile-time classpath, and simply run against RWT
> (comment/criticism on this strategy is welcome).  As long as we don't
> use methods that are not implemented in RWT this strategy generally
> works.  However for some classes, we need to compile against RWT as
> well.  This was the case with the class I was porting today with a read
> and dispatch loop:
>         display.sleep();
> many other similar cases don't.  In fact, a call to
> Display.readAndDispatch() in the same class, compiled against SWT but
> run against RWT, ran fine, correctly entering into the RWT method, but
> the next line, the call to Display.sleep(), gave the NoSuchMethodError.
> Ryan
> Frank Appel wrote:
>> Hi,
>> Ciao
>> Frank
>> pplication]
>>         at
>>         at
>> icator.java:98)
>>         at
>>         at
>> lication.java:40)
>>         at
>> Manager.java:92)
>>         at
>> va:212)
>>         at
>> does not.
>> osgi status:
>>                     Fragments=14
>> 73      ACTIVE
>>                     Fragments=74
>> 74      RESOLVED
>>                     Master=73
>> 75      <<LAZY>>
>>                     Fragments=76
>> 76      RESOLVED
>>                     Master=75
>> 77      INSTALLED
>> 78      <<LAZY>>
>> 79      <<LAZY>>
>> 80      <<LAZY>>
>> 81      <<LAZY>>
>> Thanks!
| Re: java.lang.NoSuchMethodError: org.eclipse.swt.widgets.Display.sleep()Z [message #77268 is a reply to message #77201] |
Fri, 07 March 2008 00:21    |
Eclipse User  |
Originally posted by: fappel.innoopract.com
thanks Benny. I added this to bug #219789 regarding the finalization of
the read and dispatch implementation.
Ciao
Frank
Von: Benjamin Muskalla [mailto:b.muskalla@gmx.net]
Bereitgestellt: Donnerstag, 6. März 2008 22:54
Betreff: Re: java.lang.NoSuchMethodError:
Greets
   Benny
> a majority of our classes in their original projects, which have SWT
> in the project compile-time classpath, and simply run against RWT
>         display.sleep();
NoSuchMethodError.
> Ryan
> Frank Appel wrote:
>> Hi,
>> but Display#sleep should be available. I'm wondering about the Z
>> behind the message, any ideas? Did you have a previous version of the
>> application deployed on the same tomcat? I mean maybe the working
>> directory wasn't cleaned up properly or something like that - just a
weak guess...
>> Ciao
>> Frank
>> Bereitgestellt: Dienstag, 4. März 2008 21:57 Bereitgestellt in:
>> pplication]
>>         at
>> ope
>>         at
>> xpl Authenticator.authenticate(PreferencesExplAuthent
>> icator.java:98)
>>         at
>> tic
>>         at
>> App
>> lication.java:40)
>>         at
>> int
>> Manager.java:92)
>>         at
>> .ja
>> va:212)
>>         at
>> n(R
>> Tomcat does not.
>> osgi status:
>>                     Fragments=14
>> 73      ACTIVE
>>                     Fragments=74
>> 74      RESOLVED
>>                     Master=73
>> 75      <<LAZY>>
>>                     Fragments=76
>> 76      RESOLVED
>>                     Master=75
>> 77      INSTALLED
>> 78      <<LAZY>>
>> 79      <<LAZY>>
>> 80      <<LAZY>>
>> 81      <<LAZY>>
>> Thanks!
 Current Time: Mon Nov 03 22:01:20 EST 2025
 Powered by  FUDForum. Page generated in 0.03858 seconds
