Home » Archived » BIRT » 'birtutility' is undefined
'birtutility' is undefined [message #730291] Wed, 28 September 2011 01:27 Go to next message
I am using BIRT ECLIPSE VERSION 2010 in windows 7 (with 1GB RAM) with IE8 in
compatible mode as my project doesn't support IE8.
Few days back the report tool was working fine.
However, I am getting some error from the last two days
The error shown by the Browser is:
Webpage error details
Message: 'Constants' is undefined
Line: 1958
Char: 2
Code: 0
Line: 1980
Char: 5
Code: 0
Message: Object expected
Line: 2024
Char: 3
Code: 0
Message: 'birtUtility' is undefined
Line: 2048
Char: 4
Code: 0
But I didn't made any changes in the birtutility.js or any other file.
I am attaching the screen shot foe reference.
  • Attachment: birtError.PNG
    (Size: 11.89KB, Downloaded 267 times)
Re: 'birtutility' is undefined [message #730549 is a reply to message #730291] Wed, 28 September 2011 11:30 Go to previous messageGo to next message
How do you have the viewer deployed? Are you getting this error in the
designer?
Jason
On 9/28/2011 1:27 AM, Vivek wrote:
> Line: 1958
> Char: 2
> Code: 0
> Line: 1980
> Char: 5
> Code: 0
> Line: 2024
> Char: 3
> Code: 0
> Line: 2048
> Char: 4
> Code: 0
Re: 'birtutility' is undefined [message #730748 is a reply to message #730549] Thu, 29 September 2011 00:10 Go to previous messageGo to next message
Hi Jason Weathersby,
No I am not getting this error in the designer but I am getting this error when i deployed it on local server using the JBOSS server.
Re: 'birtutility' is undefined [message #730939 is a reply to message #730748] Thu, 29 September 2011 10:49 Go to previous messageGo to next message
What version of BIRT and JBOSS are you using? How did you deploy it?
Jason
Re: 'birtutility' is undefined [message #765372 is a reply to message #730291] Tue, 13 December 2011 18:24 Go to previous messageGo to next message
Hi Jason I have the same problem
Could you tell me how didi you solve this problem????
Re: 'birtutility' is undefined [message #765750 is a reply to message #765372] Wed, 14 December 2011 10:54 Go to previous messageGo to next message
I did not get the error. Vivek did. Is yours happening in JBoss as
well? If so what version and how did you deploy?
Jason
> Thanks
Re: 'birtutility' is undefined [message #768011 is a reply to message #765750] Mon, 19 December 2011 06:39 Go to previous messageGo to next message
Is there any solution to this issue ?
I am getting the same error and same screen like originally posted by Vivek (birtError.png)
My environment:
Application server is JBoss 5.1-GA,
Fronted by an Apache httpd server (using mod_jk)
BIRT report viewer: I think the same as what has been mentioned by others in this post. (I do not how to find that out, please explain)
Further to this, my reports work fine when viewed with a local I.P address, eg. 10.0.1.9 (that is inside the local network), but when viewed using the registered domain (e.g. https://www.mydomain.com/reports) , it shows up as originally described by Vivek.
I did a bit of debugging and found,
the URL of the image, is something like
https://online.sai.org.in/frameset?__id=birtViewer&__report=%2FWEB-INF%2Freport%2FOnline_Transaction_History.rptdesign&__masterpage=true&__format=html
Using developer tools (firebug) found the element to be:
<input name="parameter" title="Run report" class="birtviewer_clickable" type="image" alt="Run report" src="birt/images/Report_parameters.gif"/>
if I replace the src parameter with the fully qualified path;
meaning src='https://online.sai.org.in/webcontent/birt/images/Report_parameters.gif'
the image is displayed.
Can somebody shed some light on this/ give me a few pointers ?
thank you,
Jeevan
Re: 'birtutility' is undefined [message #768139 is a reply to message #768011] Mon, 19 December 2011 11:39 Go to previous message
Jeevan,
Look over this thread.
http://www.birt-exchange.org/org/forum/index.php/topic/21462-networking-problem-with-birt-generated-resource-urls/
Jason
On 12/19/2011 6:40 AM, Jeevan Sunkersett wrote:
> My environment:
> Application server is JBoss 5.1-GA, Fronted by an Apache httpd server
> (using mod_jk)
> by Vivek.
> if I replace the src parameter with the fully qualified path; meaning
> thank you,
> Jeevan
Previous Topic:Drill through to javascript function instead of URL
Next Topic:How to create IReportDocument from stream
Current Time: Sun Jul 27 10:06:21 EDT 2025
Powered by FUDForum. Page generated in 0.05737 seconds
