Home » Archived » BIRT » Problem with date params(start/end date params are one hour off)
Problem with date params [message #762889] |
Thu, 08 December 2011 14:21  |
When I run a report through the BIRT report designer (2.3.2), there is a discrepancy between the date parameters that I put in for the start and end date, and the start and end dates that are actually displayed if I try to output them to a log file.
The problem seems to only occur for dates between October 10, 2011 to October 16, 2011.
For instance, if I set my start date parameter to 10/10/2011 and my end date parameter to 10/16/2011, I receive the following log output:
Fri Nov 18 15:31:27 BRST 2011 DEBUG startdate: Sun Oct 09 23:00:00 BRT 2011
Fri Nov 18 15:31:27 BRST 2011 DEBUG enddate: Sat Oct 15 23:00:00 BRT 2011
What I expected was:
Fri Nov 18 15:31:27 BRST 2011 DEBUG startdate: Sun Oct 10 00:00:00 BRT 2011
Fri Nov 18 15:31:27 BRST 2011 DEBUG enddate: Sat Oct 16 00:00:00 BRT 2011
If I were to choose 10/10/2011 to 10/11/2011, I would receive the following output:
enddate: Mon Oct 10 23:00:00 BRT 2011
enddate: Mon Oct 11 00:00:00 BRT 2011
Notice the difference in timezone (BRST on the system and BRT when logged). Brazil changed their timezone to BRST on October 16th of 2011. It appears as if BIRT is taking the start/end date parameters as BRST (midnight) and then converting them to BRT (one hour before midnight), thus the hour being pushed back by one, which does not seem practical.
Any ideas?
Thanks.
Re: Problem with date params [message #762920 is a reply to message #762889] |
Thu, 08 December 2011 15:11   |
BIRT does have a timezone parameter that can be passed in the url.
__timezone=value
Not sure this will help in this situation but may be worth a try.
Jason
> October 16, 2011.
> following output:
> Any ideas?
> Thanks.
Re: Problem with date params [message #763101 is a reply to message #762889] |
Fri, 09 December 2011 02:07   |
The Brazil change in tzdata2011m, which can be installed with tzupdater
1.3.44 or later, is not in the latest JREs 5u31 or 6u26.
See www.oracle.com/technetwork/java/javase/tzdata-versions-138805.html Or
wait for the next JRE Update.
Colin
> Any ideas?
> Thanks.
Re: Problem with date params [message #763415 is a reply to message #763101] |
Fri, 09 December 2011 13:18   |
Jason,
Thanks for the suggestion. I am not sure what value to specify for the parameter, do i just input GMT-2? Or do I need some sort of location code like America/Brazil? Is there any sort of documentation for this?
Colin,
Thanks for the link. I read the change log for version tzdata2011m, and it seems that the update is only for a very specific part of Brazil, namely Bahia, Brazil. However, the problem I described uses a different timezone, Brasilia, which is in BRST right now, so I am not sure if the update will impact the results.
Any other thoughts?
Thanks.
Re: Problem with date params [message #764644 is a reply to message #763415] |
Mon, 12 December 2011 10:28   |
Use the timezone id like:
&__timezone=Pacific/Midway
Take a look at the bottom of this post for available timezones in the
time zone class:
http://tutorials.jenkov.com/java-date-time/java-util-timezone.html
Jason
On 12/9/2011 1:18 PM, birtforums7 wrote:
> Jason,
> Colin,
> Any other thoughts?
> Thanks.
Re: Problem with date params [message #764908 is a reply to message #764644] |
Mon, 12 December 2011 23:32   |
Thanks for the reply Jason. I looked at the link you posted, but I am not sure if it will address the problem I have. That is, the logs show the timezone as correct already, it just seems that BIRT is not passing the parameter correctly.
For instance, suppose I input a start and end date range of 10/10/11 to 10/15/11. The header on the report displays correctly:
Start Date: 10/10/11
End Date: 10/15/11
The information for the start date in the header was retrieved as follows:
<structure>
<property name="name">startdate</property>
<expression name="expression">params["startdate"]</expression>
<property name="dataType">date-time</property>
</structure>
The header takes the time from startdate, which is from params["startdate"]. However, when I output the contents of params["startdate"] to a log, I receive this:
Fri Oct 14 23:00:00 BRT 2011
The code for outputting to the log was:
out = new PrintWriter(new FileWriter("c:/temp/out.txt", true));
out.println(params["startdate"]);
out.println(params["enddate"]);
out.close();
It is important for params["startdate"] to be exactly what the user inputs, since the parameter will be formatted for use in an SQL query. The same issue applies to params["enddate"] as well. It seems there is some sort of date conversion from the range of 10/10/2011 to 10/16/2011.
If I use any other time range that does not fall within these two dates, I receive the expected output. For instance:
Header:
Start Date: 10/5/11
End Date: 10/8/11
Log output:
Wed Oct 05 00:00:00 BRT 2011
Sat Oct 08 00:00:00 BRT 2011
Is it possible that this is a bug in BIRT?
Re: Problem with date params [message #765228 is a reply to message #764908] |
Tue, 13 December 2011 11:59   |
This may be a bug. Can you log a bugzilla request to investigate?
Jason
> End Date: 10/15/11
> <structure>
> </structure>
> out.close();
> Header:
> Start Date: 10/5/11
> End Date: 10/8/11
> Log output:
Current Time: Wed Jul 23 10:18:37 EDT 2025
Powered by FUDForum. Page generated in 0.33014 seconds
