Home » Language IDEs » AspectJ » load time weaving and execution time
load time weaving and execution time [message #765198] Tue, 13 December 2011 10:50 Go to next message
I want to know how much time spent to weave two bundles,in other word when i use load
time weaving to add some code (for instance code added as advice to an aspect ) to my
initial code i will have the execution time :
t = t(initial code) + t(code added to aspect) + t(weaving) ,
is t(weaving) significant or no ?
How can i reduce t(weaving) ?
Thanks in advance !
Re: load time weaving and execution time [message #765305 is a reply to message #765198] Tue, 13 December 2011 15:09 Go to previous message
t(weaving) can be significant, but it only happens once, when the target class is loaded. If you are using Equinox weaving, then there is a bit of caching going on that will store the woven class files and use them if nothing has changed in the configuration. This significantly reduces startup time.
Previous Topic:Using and Building AspectJ with Android App on Eclipse and Ant
Next Topic:RCP templates are not available in selection list
Current Time: Sun Jun 01 14:05:53 EDT 2025
Powered by FUDForum. Page generated in 0.02722 seconds
