Home » Eclipse Projects » Rich Client Platform (RCP) » Popup Menu in Tabfolder
Popup Menu in Tabfolder [message #765049] Tue, 13 December 2011 05:22 Go to next message
i have an RCP Application with a CTabFolder in it.
When I make a right-click on it a standard context menu appears. How can I disable this function or make the items of the menu in german?
I would prefer to make my own context menu for the TabFolder...
Re: Popup Menu in Tabfolder [message #765105 is a reply to message #765049] Tue, 13 December 2011 07:38 Go to previous messageGo to next message
You can't make your own menu, that's provided by the presentation. But you can provide German translations for them (and there should be one already). See how http://www.eclipse.org/babel does it.
PW
Re: Popup Menu in Tabfolder [message #765128 is a reply to message #765105] Tue, 13 December 2011 08:23 Go to previous messageGo to next message
Thanks for the reply. The translation worked Smile
But is there a way to remove the context menu form the tabfolder?
Re: Popup Menu in Tabfolder [message #765142 is a reply to message #765128] Tue, 13 December 2011 08:53 Go to previous messageGo to next message
We have written our own presentation which uses our custom menu entries.
Just search in the presentation code for the position where ISystemMenu
is implemented.
Tom
Am 13.12.11 14:23, schrieb jps90:
> Thanks for the reply. The translation worked :)
Re: Popup Menu in Tabfolder [message #765162 is a reply to message #765142] Tue, 13 December 2011 09:38 Go to previous messageGo to next message
I found the class StandardViewSystemMenu which looks like the implementation of the context menu.
But I don't know I have to do to change it...
Thanks for your replies again Smile
Re: Popup Menu in Tabfolder [message #765170 is a reply to message #765162] Tue, 13 December 2011 09:49 Go to previous messageGo to next message
You need to create your own presentation. I googled for it and found
http://book.javanb.com/eclipse-rich-client-platform-designing-coding-and-packaging-java-applications-oct-2005/ch19lev1sec3.html
I'd suggest you start copy WorkbenchPresentationFactoryClassic to your
own package and see what classes you are still missing.
Tom
Am 13.12.11 15:39, schrieb jps90:
> Thanks for your replies again :)
Re: Popup Menu in Tabfolder [message #765314 is a reply to message #765128] Tue, 13 December 2011 15:25 Go to previous messageGo to next message
Hello
A workaround to remove the menu is here: http://www.eclipse.org/forums/index.php/mv/msg/262045/756719/#msg_756719.
But as Tom suggested creating your own presentation is the correct way.
Re: Popup Menu in Tabfolder [message #765556 is a reply to message #765314] Wed, 14 December 2011 04:45 Go to previous message
thanks fpr the clue with the presentation. I think that is what I was searching for.
So I tried to create my own presentation. It looks like it is working because I can use it in the org.ui.example.presentation project. But how can I include it into my project?
I made a presentation.ini file with the content: org.eclipse.ui/presentationFactoryId=my.presentation.factory and added it to the Binary Build.
In my plugin.xml I have:
<extension point="org.eclipse.ui.presentationFactories">
   <factory
         class="de.application.PresentationFactory"
         id="my.presentation.factory"
         name="name">
   </factory>
</extension>
and
<property
      name="preferenceCustomization"
      value="presentation.ini">
</property>
I think it should work with this configuration!? But nothing happens Sad
Found the solution. I just made a clear workspace and clear configuration area in the launch configuration.
Thanks a lot for your help Smile
[Updated on: Wed, 14 December 2011 07:37] by Moderator
Previous Topic:RCP View toolbar automatically shut off the line?
Next Topic:Retrieving of selection
Current Time: Fri Jul 25 08:40:00 EDT 2025
Powered by FUDForum. Page generated in 0.05296 seconds
