Home » Eclipse Projects » Eclipse Platform » CVS update problem on Eclipe 3.0 M1. --C invalid option ?
CVS update problem on Eclipe 3.0 M1. --C invalid option ? [message #76500] Tue, 17 June 2003 12:40 Go to next message
Originally posted by: odwl.skynet.be
On Eclise 3.0 M1.
When I try to cvs update it works if and only if there is no new files added
to the CVS repository.
If I need to download a file, I receive a :
The server reported an error while performing the cvs update command.
Details >>
invalid option --C.
My CVS repository resides on a OSX.
The bug appear both from an osX and a WIn clients
Re: CVS update problem on Eclipe 3.0 M1. --C invalid option ? [message #76547 is a reply to message #76500] Tue, 17 June 2003 13:24 Go to previous messageGo to next message
> Details >>
> invalid option --C.
See the FAQ:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -vcm-home/docs/online/cvs_features2.0/cvs-faq.html?rev=1.35& amp;content-type=text/html#server_6
"This error indicates that your server version is CVS 1.10 or before.
The -C option was introduced in version 1.11. See above for supported
CVS versions."
I seem to recall that OSX has CVS 1.10 installed by default. You
probably need to upgrade.
Andrew Jr.
IBM Phoenix Labs (OTI)
11811 North Tatum Boulevard, Suite 2400
Phoenix, Arizona, USA 85028-1614
Re: CVS update problem on Eclipe 3.0 M1. --C invalid option ? [message #76578 is a reply to message #76547] Tue, 17 June 2003 13:32 Go to previous messageGo to next message
That is, upgrade your version of CVS, not your OS!
Disambiguation R Us...
Andrew Jr.
Re: CVS update problem on Eclipse 3.0 M1. --C invalid option ? [message #85668 is a reply to message #76578] Mon, 30 June 2003 13:23 Go to previous message
Originally posted by: Andre_Weinand.oti.com
On 17.6.2003 19:32 Uhr, in article bcnjb7$qgi$2@rogue.oti.com, "Andrew
which is most easily done by using fink (and/or the FinkCommander on MacOS
X)
--andre
Previous Topic:Code formatter: how to insert line between methods?
Next Topic:Ant Error
Current Time: Fri Jul 25 21:21:10 EDT 2025
Powered by FUDForum. Page generated in 0.03903 seconds
