Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Lazy loading problem
Lazy loading problem [message #763150] Fri, 09 December 2011 04:05 Go to next message
following problem is given:
I want to show a table with X rows. I know X, but I have already only Y object from X objects in memory.
For example, I know my table should show 10000 rows, but I have only 100 of them in memory, because the came via a webservice very slow.
So, if I use a Table or TableViewer with SWT.VIRTUAL, I can say
table.setItemCount(10000);
So if I scroll to a position in the table, where the data is not already in memory, i can set the text to "loading...".
But the ILazyContentProvider updateElement(int index) method, is only called once, so if the data is loaded, the method to update the cells, is never
called.
How can I handle this?
Should I set table.setItemCount only to the value of the elements I already have in memory?
Markus
Re: Lazy loading problem [message #764649 is a reply to message #763150] Mon, 12 December 2011 10:36 Go to previous message
See this useful article on Virtual Tree & Table --> http://eclipse.org/articles/Article-SWT-Virtual/Virtual-in-SWT.html
After an item has been initialized, the SWT.SetData listener is not called to set its data again. But when the item is cleared with Table.clear() the listener will be called to set its data again as necessary.
Previous Topic:Not able to paste Ms-Excel column into SWT's Text widget
Next Topic:Eclipse taking breaks under Mac OS 10.7 Lion
Current Time: Sat Jul 26 07:56:12 EDT 2025
Powered by FUDForum. Page generated in 0.06859 seconds
