Home » Eclipse Projects » Rich Client Platform (RCP) » Getting active tableviewer in Handler
Getting active tableviewer in Handler [message #763502] Fri, 09 December 2011 16:45 Go to next message
Yet another question.. I have a menu on my tableviewer so when I do a right click I can choose to delete an object. In the handler I want to know which tableviewer is clicked so I can retrieve the input.. On this input I want to do some modifications. Is this possible?
Thanks in advance.
Ricky de Klerck
Re: Getting active tableviewer in Handler [message #764562 is a reply to message #763502] Mon, 12 December 2011 07:42 Go to previous messageGo to next message
Are you sure that you really need exactly tableviewer? I think it's litle bit wrong from eclipse selection concepts. I mean that you can provide selection exactly from table viever and in this case selection will be element which you want to handle.
Arthur.
Re: Getting active tableviewer in Handler [message #764581 is a reply to message #764562] Mon, 12 December 2011 08:26 Go to previous message
I completely agree with Arthur and therefore recommend to use
HandlerUtil.getCurrentSelection[Checked] or
HandlerUtil.getActiveMenuSelection[Checked], depending on your needs. If
it is important, that you get the control in focus, register your
(table) control via IFocusService, and use the variables
activeFocusControl and activeFocusControlId via HandlerUtil.getVariable
inside your handler.
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:Extension Points: "Second instance" not available
Next Topic:Eclipse gemini integration with eclipse RCP
Current Time: Wed Jul 23 04:15:41 EDT 2025
Powered by FUDForum. Page generated in 0.06362 seconds
