separate console view for each run configuration [message #764549] |
Mon, 12 December 2011 07:16  |
Hi all,
I am new to Eclipse and have a beginners question: I am running several programmes at the same time (i.e. developing a client/server style programme) and would like to automatically show the output of each programme in a separate console. Currently I have managed to open multiple console views, but I always have to assign which console shows which output *after* the programmes have been launched. Currently if I launch the first programme, all console views show its output simultaneously.
Many TIA,
-- Jan
Re: separate console view for each run configuration [message #764666 is a reply to message #764635] |
Mon, 12 December 2011 11:13  |
Many thanks for your answer.
Michael Rennie wrote on Mon, 12 December 2011 10:10Currently there is only the notion of 'allocating a console' for a launch - which as you already found out does not tie a specific console to a specific launch.
Bummer )-:
Michael Rennie wrote on Mon, 12 December 2011 10:10 If you are concerned about capturing the output for each launch, you could have each launch write to a file.
No, I just want to see all the output of all running programmes at the same time. Also I do not like mousing around to select the programme for each of the console views.
-- Jan
FUDForum. Page generated in 0.09545 seconds
