Home » Language IDEs » C / C++ IDE (CDT) » Eclipse breakpoint freezes x windows
Eclipse breakpoint freezes x windows [message #764246] |
Sun, 11 December 2011 13:55  |
Would you please provide me some tips to help me figure out why x windows is freezing on me while using eclipse? For example, should I run in "safe mode", should I update to latest, check bug reports, check for buffer overruns, etc.
I'm running on a 64 bit Gentoo system with indigo. The app I am debugging is multithreaded, uses wxwidgets, and autotools.
When a certain breakpoint is reached, x windows freezes. To restore functionality, I use CTRL-ALT-F2 to switch to a console, then "kill -9" my application (which was launched from within Eclipse). X windows once again responds.
When I run the same binary through gdb (outside eclipse) with the same breakpoint, X windows does not freeze!
Thank you for your help,
Chris
Version: Indigo Service Release 1
Build id: 20110916-0149
[Updated on: Fri, 23 December 2011 14:05] by Moderator
Re: Eclipse breakpoint freezes x windows [message #770258 is a reply to message #764246] |
Fri, 23 December 2011 14:04  |
Here is the output from the "gdb traces" console:
901,581 =thread-created,id="2",group-id="i1"
901,582 ~"[New Thread 0x7fffe6e75700 (LWP 18462)]\n"
901,583 *running,thread-id="all"
901,586 ~"[Switching to Thread 0x7fffe6e75700 (LWP 18462)]\n"
901,614 *stopped,reason="breakpoint-hit",disp="keep",bkptno="1",frame={addr="0x00000000004639bd",fun\
c="TCLowSpeed::Process",args=[{name="this",value="0xd213f0"},{name="Can",value="..."},{name="LowSpee\
dReport",value="..."}],file="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/LowSpeed.cpp",f\
ullname="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/LowSpeed.cpp",line="511"},thread-id\
="2",stopped-threads="all",core="3"
901,615 (gdb)
901,629 15^done,groups=[{id="1",type="process",description="init [3]",user="root"},{id="1246",type="\
process",description="/sbin/udevd --daemon",user="root"},{id="2774",type="process",description="/usr\
/bin/dbus-daemon --system",user="messagebus"},{id="2791",type="process",description="/usr/bin/python\
2 -O /usr/share/wicd/daemon/wicd-daemon.py",user="root"},{id="2806",type="process",description="/usr\
/bin/python2 -O /usr/share/wicd/daemon/monitor.py",user="root"},{id="2810",type="process",descriptio\
n="supervising syslog-ng",user="root"},{id="2811",type="process",description="/usr/sbin/syslog-ng",u\
ser="root"},{id="2824",type="process",description="/usr/sbin/console-kit-daemon",user="root"},{id="2\
895",type="process",description="/usr/libexec/polkitd",user="root"},{id="3022",type="process",descri\
ption="dhcpcd -m 2 eth0",user="root"},{id="3061",type="process",description="/usr/sbin/cupsd -C /etc\
/cups/cupsd.conf",user="root"},{id="3074",type="process",description="/usr/sbin/gpm -m /dev/input/mi\
ce -t ps2",user="root"},{id="3121",type="process",description="/usr/sbin/sshd",user="root"},{id="314\
6",type="process",description="/bin/login --",user="root"},{id="3147",type="process",description="/b\
in/login --",user="root"},{id="3148",type="process",description="/sbin/agetty 38400 tty3 linux",user\
="root"},{id="3149",type="process",description="/sbin/agetty 38400 tty4 linux",user="root"},{id="315\
0",type="process",description="/sbin/agetty 38400 tty5 linux",user="root"},{id="3151",type="process"\
,description="/sbin/agetty 38400 tty6 linux",user="root"},{id="3169",type="process",description="/us\
r/bin/gnome-keyring-daemon --daemonize --login",user="cstankevitz"},{id="3171",type="process",descri\
ption="-bash",user="cstankevitz"},{id="3179",type="process",description="/bin/sh /usr/bin/startx",us\
er="cstankevitz"},{id="3195",type="process",description="xinit /home/cstankevitz/.xinitrc -- /etc/X1\
1/xinit/xserverrc :0 -auth /home/cstankevitz/.serverauth.3179",user="cstankevitz"},{id="3196",type="\
process",description="/usr/bin/X -nolisten tcp :0 -auth /home/cstankevitz/.serverauth.3179",user="ro\
ot"},{id="3203",type="process",description="ck-launch-session gnome-session",user="cstankevitz"},{id\
="3212",type="process",description="gnome-session",user="cstankevitz"},{id="3215",type="process",des\
cription="dbus-launch --exit-with-session gnome-session",user="cstankevitz"},{id="3216",type="proces\
s",description="/usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session",user="cstanke\
vitz"},{id="3221",type="process",description="/usr/libexec/gconfd-2",user="cstankevitz"},{id="3233",\
type="process",description="/usr/libexec/gnome-settings-daemon",user="cstankevitz"},{id="3236",type=\
"process",description="/usr/libexec/gvfsd",user="cstankevitz"},{id="3241",type="process",description\
="/usr/bin/metacity",user="cstankevitz"},{id="3250",type="process",description="/usr/libexec/gvfs-gd\
u-volume-monitor",user="cstankevitz"},{id="3252",type="process",description="/usr/libexec/udisks-dae\
mon",user="root"},{id="3253",type="process",description="udisks-daemon: polling /dev/sr0",user="root\
"},{id="3259",type="process",description="gnome-panel",user="cstankevitz"},{id="3261",type="process"\
,description="nautilus",user="cstankevitz"},{id="3263",type="process",description="/usr/libexec/bono\
bo-activation-server --ac-activate --ior-output-fd=23",user="cstankevitz"},{id="3269",type="process"\
,description="/usr/libexec/wnck-applet",user="cstankevitz"},{id="3270",type="process",description="/\
usr/libexec/polkit-gnome-authentication-agent-1",user="cstankevitz"},{id="3271",type="process",descr\
iption="/usr/bin/python2.7 /usr/share/system-config-printer/applet.py",user="cstankevitz"},{id="3273\
",type="process",description="/usr/libexec/gdu-notification-daemon",user="cstankevitz"},{id="3274",t\
ype="process",description="/usr/bin/python2 -O /usr/share/wicd/gtk/wicd-client.py",user="cstankevitz\
"},{id="3276",type="process",description="/usr/libexec/cpufreq-applet",user="cstankevitz"},{id="3280\
",type="process",description="/usr/libexec/notification-area-applet",user="cstankevitz"},{id="3281",\
type="process",description="/usr/libexec/clock-applet",user="cstankevitz"},{id="3282",type="process"\
,description="/usr/libexec/multiload-applet-2",user="cstankevitz"},{id="3283",type="process",descrip\
tion="/usr/libexec/evolution/2.32/evolution-alarm-notify",user="cstankevitz"},{id="3289",type="proce\
ss",description="gnome-power-manager",user="cstankevitz"},{id="3305",type="process",description="/us\
r/libexec/gvfsd-trash --spawner :1.11 /org/gtk/gvfs/exec_spaw/0",user="cstankevitz"},{id="3306",type\
="process",description="/usr/libexec/upowerd",user="root"},{id="3308",type="process",description="gn\
ome-screensaver",user="cstankevitz"},{id="3311",type="process",description="/usr/libexec/e-calendar-\
factory",user="cstankevitz"},{id="3386",type="process",description="/usr/libexec/gvfsd-metadata",use\
r="cstankevitz"},{id="3392",type="process",description="/usr/lib64/thunderbird/thunderbird-bin",user\
="cstankevitz"},{id="3475",type="process",description="/home/cstankevitz/Work/2000-00-00_Eclipse/ecl\
ipse/eclipse",user="cstankevitz"},{id="3687",type="process",description="/usr/lib64/virtualbox/Virtu\
alBox",user="cstankevitz"},{id="3702",type="process",description="/usr/lib64/virtualbox/VBoxXPCOMIPC\
D",user="cstankevitz"},{id="3707",type="process",description="/usr/lib64/virtualbox/VBoxSVC --auto-s\
hutdown",user="cstankevitz"},{id="3720",type="process",description="/usr/lib64/virtualbox/VirtualBox\
--comment Ubuntu 32 bit --startvm be417000-44a1-45f7-9273-2fea8363cc0e --no-startvm-errormsgbox",us\
er="cstankevitz"},{id="4083",type="process",description="gnome-terminal",user="cstankevitz"},{id="40\
86",type="process",description="-bash",user="cstankevitz"},{id="10487",type="process",description="/\
usr/sbin/ntpd -p /var/run/ntpd.pid",user="root"},{id="11961",type="process",description="/usr/lib64/\
chromium-browser/chrome --extra-plugin-dir=/usr/lib/nsbrowser/plugins",user="cstankevitz"},{id="1196\
4",type="process",description="/usr/lib64/chromium-browser/chrome --extra-plugin-dir=/usr/lib/nsbrow\
ser/plugins",user="cstankevitz"},{id="11966",type="process",description="/usr/lib64/chromium-browser\
/chrome --type=zygote",user="cstankevitz"},{id="11968",type="process",description="/usr/lib64/chromi\
um-browser/nacl_helper_bootstrap /usr/lib64/chromium-browser/nacl_helper --at-zero",user="cstankevit\
z"},{id="12067",type="process",description="-bash",user="cstankevitz"},{id="12076",type="process",de\
scription="su -",user="root"},{id="12079",type="process",description="-su",user="root"},{id="16103",\
type="process",description="/usr/bin/gnome-keyring-daemon --daemonize --login",user="cstankevitz"},{\
id="16105",type="process",description="-bash",user="cstankevitz"},{id="16147",type="process",descrip\
tion="/usr/lib64/chromium-browser/chrome --type=gpu-process --channel=11961.0x7f0757800000.141001011\
6",user="cstankevitz"},{id="16469",type="process",description="/usr/lib/jvm/icedtea6-bin/bin/java -D\
osgi.requiredJavaVersion=1.5 -XX:MaxPermSize=256m -Xms40m -Xmx384m -jar /home/cstankevitz/Work/2000-\
00-00_Eclipse/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -os linux -ws gtk -a\
rch x86_64 -showsplash -launcher /home/cstankevitz/Work/2000-00-00_Eclipse/eclipse/eclipse -name Ecl\
ipse --launcher.library /home/cstankevitz/Work/2000-00-00_Eclipse/eclipse//plugins/org.eclipse.equin\
ox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so -startup /home/cstankevitz/Work/2000-\
00-00_Eclipse/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar --launcher.overrideV\
margs -exitdata 48009 -product org.eclipse.epp.package.cpp.product -vm /usr/bin/java -vmargs -Dosgi.\
requiredJavaVersion=1.5 -XX:MaxPermSize=256m -Xms40m -Xmx384m -jar /home/cstankevitz/Work/2000-00-00\
_Eclipse/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar",user="cstankevitz"},{id=\
"16565",type="process",description="/usr/lib64/chromium-browser/chrome --type=renderer --lang=en-US \
--force-fieldtest=CacheListSize/CacheListSize_14/ConnCountImpact/conn_count_6/ConnnectBackupJobs/Con\
nectBackupJobsEnabled/DnsImpact/default_enabled_prefetch/DnsParallelism/parallel_default/GlobalSdch/\
global_enable_sdch/IdleSktToImpact/idle_timeout_10/Instant/Inactive/Prefetch/ContentPrefetchPrerende\
rControl2/PrerenderFromOmniboxHeuristic/OriginalAlgorithm/ProxyConnectionImpact/proxy_connections_32\
/SpdyCwnd/cwnd16/SpdyImpact/npn_with_spdy/WarmSocketImpact/warmest_socket/ --channel=11961.0x7f07577\
d8200.667278422",user="cstankevitz"},{id="17646",type="process",description="/sbin/udevd --daemon",u\
ser="root"},{id="17647",type="process",description="/sbin/udevd --daemon",user="root"},{id="17755",t\
ype="process",description="wpa_supplicant -B -i wlan0 -c /var/lib/wicd/configurations/0013106a5e0b -\
D wext",user="root"},{id="17797",type="process",description="/sbin/dhcpcd wlan0 -h crs-m6600",user="\
root"},{id="18440",type="process",description="gdb --interpreter mi2 --nx",user="cstankevitz"},{id="\
18453",type="process",description="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/Build/Debug/s\
rc/Drg2Tool",user="cstankevitz"}]
901,640 (gdb)
901,670 16-list-thread-groups
901,670 16^done,groups=[{id="i1",type="process",pid="18453",executable="/home/cstankevitz/Work/2011-\
11-27_DRG2Tool/Drg2Tool/Build/Debug/src/Drg2Tool",cores=["2","3"]}]
901,671 (gdb)
901,700 17-list-thread-groups i1
901,713 18-list-thread-groups
901,744 17^done,threads=[{id="2",target-id="Thread 0x7fffe6e75700 (LWP 18462)",frame={level="0",addr\
="0x00000000004639bd",func="TCLowSpeed::Process",args=[{name="this",value="0xd213f0"},{name="Can",va\
lue="..."},{name="LowSpeedReport",value="..."}],file="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg\
2Tool/src/LowSpeed.cpp",fullname="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/LowSpeed.c\
pp",line="511"},state="stopped",core="3"},{id="1",target-id="Thread 0x7ffff7fb5a40 (LWP 18453)",fram\
e={level="0",addr="0x00007ffff19016f3",func="poll",args=[],from="/lib64/libc.so.6"},state="stopped",\
core="2"}]
901,745 (gdb)
901,745 18^done,groups=[{id="i1",type="process",pid="18453",executable="/home/cstankevitz/Work/2011-\
901,746 (gdb)
901,763 19-stack-info-depth --thread 2 11
901,949 19^done,depth="11"
901,949 (gdb)
901,980 20-thread-info 2
901,981 20^done,threads=[{id="2",target-id="Thread 0x7fffe6e75700 (LWP 18462)",frame={level="0",addr\
pp",line="511"},state="stopped",core="3"}]
901,982 (gdb)
902,006 21-stack-list-frames --thread 2 0 9
902,007 21^done,stack=[frame={level="0",addr="0x00000000004639bd",func="TCLowSpeed::Process",file="/\
home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/LowSpeed.cpp",fullname="/home/cstankevitz/Wor\
k/2011-11-27_DRG2Tool/Drg2Tool/src/LowSpeed.cpp",line="511"},frame={level="1",addr="0x0000000000429c\
8e",func="TCDrg::ParserCanArrived",file="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/Drg\
.cpp",fullname="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/Drg.cpp",line="764"},frame={\
level="2",addr="0x000000000048d6cd",func="TCParser::ParseMessage",file="/home/cstankevitz/Work/2011-\
11-27_DRG2Tool/Drg2Tool/src/Msg/Parser.cpp",fullname="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg\
2Tool/src/Msg/Parser.cpp",line="194"},frame={level="3",addr="0x000000000048d51a",func="TCParser::Par\
sePacket",file="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/Msg/Parser.cpp",fullname="/h\
ome/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/Msg/Parser.cpp",line="169"},frame={level="4",a\
ddr="0x000000000048d25c",func="TCParser::ParseBuffer",file="/home/cstankevitz/Work/2011-11-27_DRG2To\
ol/Drg2Tool/src/Msg/Parser.cpp",fullname="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/Ms\
g/Parser.cpp",line="103"},frame={level="5",addr="0x000000000048d18f",func="TCParser::AddBytes",file=\
"/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/Msg/Parser.cpp",fullname="/home/cstankevitz\
/Work/2011-11-27_DRG2Tool/Drg2Tool/src/Msg/Parser.cpp",line="64"},frame={level="6",addr="0x000000000\
0429ad6",func="TCDrg::HighSpeedInterfaceObserverBytesArrived",file="/home/cstankevitz/Work/2011-11-2\
7_DRG2Tool/Drg2Tool/src/Drg.cpp",fullname="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/D\
rg.cpp",line="729"},frame={level="7",addr="0x000000000045ffb0",func="TCHighSpeedInterface::NotifyByt\
esArrived",file="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/HighSpeedInterface.cpp",ful\
lname="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/HighSpeedInterface.cpp",line="42"},fr\
ame={level="8",addr="0x0000000000460f0b",func="TCHighSpeedInterfaceSimulated::Work",file="/home/csta\
nkevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/HighSpeedInterfaceSimulated.cpp",fullname="/home/cstan\
kevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/HighSpeedInterfaceSimulated.cpp",line="147"},frame={lev\
el="9",addr="0x000000000048854e",func="TCWorkerThread::Entry",file="/home/cstankevitz/Work/2011-11-2\
7_DRG2Tool/Drg2Tool/src/WorkerThread.cpp",fullname="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2T\
ool/src/WorkerThread.cpp",line="127"}]
902,008 (gdb)
902,030 22-stack-list-frames --thread 2
902,037 22^done,stack=[frame={level="0",addr="0x00000000004639bd",func="TCLowSpeed::Process",file="/\
ool/src/WorkerThread.cpp",line="127"},frame={level="10",addr="0x0000000000762b66",func="wxThreadInte\
rnal::PthreadStart",file="../../wxWidgets/src/unix/threadpsx.cpp",fullname="/home/cstankevitz/Work/2\
000-00-00_Wx/Trunk/wxWidgets/src/unix/threadpsx.cpp",line="854"},frame={level="11",addr="0x000000000\
076270e",func="wxPthreadStart",file="../../wxWidgets/src/unix/threadpsx.cpp",fullname="/home/cstanke\
vitz/Work/2000-00-00_Wx/Trunk/wxWidgets/src/unix/threadpsx.cpp",line="804"},frame={level="12",addr="\
0x00007ffff1404c6c",func="start_thread",from="/lib64/libpthread.so.0"},frame={level="13",addr="0x000\
07ffff190a4bd",func="clone",from="/lib64/libc.so.6"}]
902,039 (gdb)
912,646 23-exec-step --thread 2 1
912,646 23^running
912,647 *running,thread-id="2"
912,649 (gdb)
912,649 *running,thread-id="all"
912,649 *stopped,reason="end-stepping-range",frame={addr="0x00000000004639cf",func="TCLowSpeed::Proc\
ess",args=[{name="this",value="0xd213f0"},{name="Can",value="..."},{name="LowSpeedReport",value="...\
"}],file="/home/cstankevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/LowSpeed.cpp",fullname="/home/csta\
nkevitz/Work/2011-11-27_DRG2Tool/Drg2Tool/src/LowSpeed.cpp",line="513"},thread-id="2",stopped-thread\
s="all",core="0"
912,650 (gdb)
917,183 24-stack-info-depth --thread 2 11
917,184 24^error,msg="Cannot access memory at address 0x7fffe6e73f38"
917,184 (gdb)
917,185 25-stack-info-depth --thread 2 1
917,186 25^done,depth="1"
917,186 (gdb)
917,233 26-stack-info-depth --thread 2 2
917,234 26^error,msg="Cannot access memory at address 0x7fffe6e73f38"
917,234 (gdb)
917,271 27-list-thread-groups
917,271 27^error,msg="Cannot find new threads: generic error"
917,271 28-thread-info 2
917,272 (gdb)
917,272 28^error,msg="Cannot find new threads: generic error"
917,272 (gdb)
917,315 29-thread-info 1
917,315 29^error,msg="Cannot find new threads: generic error"
917,315 (gdb)
Current Time: Wed Jul 30 13:14:45 EDT 2025
Powered by FUDForum. Page generated in 0.05816 seconds
