[CDO]Exception in Creating Folder in "CDO Sessions" [message #764120] |
Sun, 11 December 2011 07:16  |
I have installed emf-cdo-R20110913-0010-Site.zip.And using Eclipse 3.7SR1.
When i wan to create a folder in "CDO Sessions" i got the following exception(I also attach a screen shot and log of exceptions) :
org.eclipse.emf.cdo.util.InvalidURIException: Invalid URI "cdo://423b1786-ad90-4174-97be-42c7ee950627/sys": java.lang.IllegalStateException: Different object was registered for OID2
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerProxyResource(AbstractCDOView.java:1053)
at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.registerProxy(CDOResourceImpl.java:902)
at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.load(CDOResourceImpl.java:826)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.emf.cdo.internal.ui.editor.CDOEditor.createModel(CDOEditor.java:1145)
at org.eclipse.emf.cdo.internal.ui.editor.CDOEditor.createPages(CDOEditor.java:1263)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at org.eclipse.emf.cdo.ui.CDOEditorUtil$1.run(CDOEditorUtil.java:79)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.IllegalStateException: Different object was registered for OID2
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerObject(AbstractCDOView.java:1069)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerProxyResource(AbstractCDOView.java:1044)
... 63 more
Khosro.
Re: [CDO]Exception in Creating Folder in "CDO Sessions& [message #764937 is a reply to message #764930] |
Tue, 13 December 2011 00:52   |
Hold on, this is a pure UI bug! CreateResourceNodeAction.doRun() should not attempt to open a resource editor for new
folders. A simple if statement fixes this:
if (!createFolder)
String resourcePath = node.getPath();
CDOEditorUtil.openEditor(getPage(), transaction, resourcePath);
Please submit the bugzilla against EMF/cdo.ui
Cheers
/Eike
http://www.esc-net.de
Am 13.12.2011 06:37, schrieb Eike Stepper:
> Am 13.12.2011 06:30, schrieb Khosro Asgharifard Sharabiani:
>> Hi Eike,
>> I did not write a test case to produce the problem,because the problem occurred in Eclipse and in "CDO Sessions" view.
>> After installing latest buildhttps://hudson.eclipse.org/hudson/job/emf-cdo-maintenance/lastSuccessfulBuild/artifact/
>> my problem did not solved.
>> The way that you can reproduce my problem is very easy and is as follow :
>> I have attached my CDO Server.You must first install MYSQL(I use version 5.1) on port 3306 and then import it to your
>> Eclipse and then open "CDOServer.product" and in "Overview" tab click on "Launch An Eclipse Application".And also
>> "cdo-server.xml" locates in "/CDOServer/rootfiles/configuration".
>> Then follow these steps :
>> Select "Windows->ShowView->CDO Sessions" view ,then click on plus sign("Open a new CDO Session") and connect to CDO
>> Server that has been started as described in above(For "Server Description" enter "tcp://localhost:2036" and for
>> "Repository Name" enter "demo" and also check "Automatic Package Registry" checkbox).
>> Then right click on opened session(Session1) on "CDO Sessions" view and select "Open Transaction",and then right
>> click on opened transaction(Transaction1) and then select "Create Folder" ,for example name it "sys1",and then a new
>> tab open and the exception occurred.
>> I use "eclipse-modeling-indigo-SR1-linux-gtk-x86_64" in Ubuntu 11.10 and JDK 1.6.0_25.
>> That's all that i did.
>> I hope that you can reproduce it for yourself.
> Okay, I could reproduce the problem (even with H2). Please submit a bugzilla against EMF/cdo.core so that we can track
> the progress.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
FUDForum. Page generated in 0.04559 seconds
