Home » Newcomers » Newcomers » I get this and stopped when went install some js/jquery plugins(how proceed)
I get this and stopped when went install some js/jquery plugins [message #763824] Sat, 10 December 2011 12:17 Go to next message
this posted by error here:
http://www.eclipse.org/forums/index.php/m/763487/#msg_763487
I get this and stopped when went install some js/jquery plugins...
how proceed???
Cannot complete the install because one or more required items could not be found.
Software being installed: JSDT jQuery Integration 1.3.0 (org.eclipselabs.jsdt.jquery_feature.feature.group 1.3.0)
Missing requirement: JSDT jQuery UI 1.3.0 (org.eclipselabs.jsdt.jquery.ui 1.3.0) requires 'bundle org.eclipse.core.runtime [3.7.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: JSDT jQuery Integration 1.3.0 (org.eclipselabs.jsdt.jquery_feature.feature.group 1.3.0)
To: org.eclipselabs.jsdt.jquery.ui [1.3.0]
I have:
Eclipse Java EE IDE for Web Developers.
Version: Helios Service Release 1
Build id: 20100917-0705
Is it needed install ECLIPSE-JAVASCRIPT,...? Any way how install this in current install, not separate install???
Re: I get this and stopped when went install some js/jquery plugins [message #764053 is a reply to message #763824] Sun, 11 December 2011 02:54 Go to previous messageGo to next message
> ... requires 'bundle org.eclipse.core.runtime [3.7.0,4.0.0)'
> I have:
> ... Version: Helios Service Release 1
Helios is Eclipse 3.6 and the dependency requires 3.7 (Indigo).
BTW, the developer clearly says that 3.7 is required on the market place
[1] and again in this bug report [2] which is similar to your
question.
[1] http://marketplace.eclipse.org/content/jsdt-jquery
[2]
https://code.google.com/a/eclipselabs.org/p/jsdt-jquery/issues/detail?id=1
Michael
Re: I get this and stopped when went install some js/jquery plugins [message #764115 is a reply to message #764053] Sun, 11 December 2011 06:57 Go to previous messageGo to next message
THERE IS NO EQUIVALENT PLUG IN FOR MY VERSION?
OR
ECLIPSE-JAVASCRIPT,...? how install this in current install TO MY HELIOS JAVA EE IDE, not separate install???
Re: I get this and stopped when went install some js/jquery plugins [message #764203 is a reply to message #764115] Sun, 11 December 2011 11:45 Go to previous messageGo to next message
In short: no.
Re: I get this and stopped when went install some js/jquery plugins [message #764214 is a reply to message #764203] Sun, 11 December 2011 12:16 Go to previous messageGo to next message
ok, so how about installing JavaScript(Eclipse) IDE in current installation...in my Helios... what steps follow...? again not new eclipse install...
Re: I get this and stopped when went install some js/jquery plugins [message #764269 is a reply to message #764214] Sun, 11 December 2011 15:10 Go to previous messageGo to next message
It does not work.
If the requirement is org.eclipse.core.runtime [3.7.0,4.0.0) it really
_is_ Eclipse 3.7.0 up to and not including 4.0.0.
Michael
Re: I get this and stopped when went install some js/jquery plugins [message #764284 is a reply to message #764269] Sun, 11 December 2011 15:51 Go to previous messageGo to next message
Michael Pellaton wrote on Sun, 11 December 2011 15:10
It does not work.
Michael
You haven't old ECLIPSE javascript ide [NOT STAND ALONE] downloads for HELIOS?
I mean IDE and Not plugins...
Re: I get this and stopped when went install some js/jquery plugins [message #764391 is a reply to message #764284] Sun, 11 December 2011 23:40 Go to previous messageGo to next message
>> It does not work.
>> Michael
> HELIOS?
You really need to take this up with the developer of the plugin you are
trying to install. It is from a third party and not affiliated with
Eclipse.
Re: I get this and stopped when went install some js/jquery plugins [message #764440 is a reply to message #764391] Mon, 12 December 2011 02:22 Go to previous messageGo to next message
> Eclipse.
Well, I don't think so. The final answer is here and has been since my
first reply to this thread.
I know the guy - Philippe - providing the JSDT JQuery extension
personally as we both work for the same company and we both form the
"Eclipse crew" providing our inhouse Eclipse distribution. He even
mentioned that people keep bugging him about this despite his clear
statements on the issue.
On the marketplace [1] he states: "If you have trouble installing this
plugin it's likely that you don't have Eclipse 3.7." Besides that,
there is a bug report [2] about the exact issue discussed here and in
this case, he again clearly states "Helios / Eclipse 3.6 is not
supported. You need at least Indigo / 3.7.".
So, I'd like to end this thread with two conclusions:
a) JSDT JQuery requires Eclipse 3.7 or greater
b) Philippe is sure about this issue and he has discussed it over and
over again and he is no likely to change that.
Sorry, no luck - update to Indigo.
[2]
Michael
Re: I get this and stopped when went install some js/jquery plugins [message #764505 is a reply to message #764391] Mon, 12 December 2011 05:15 Go to previous messageGo to next message
"dpwegener: You really need to take this up with the developer of the plugin you are
Eclipse."
I do not speak for the 3rd party plug-in anymore, but for the original
like the
ECLIPSE java ee ide [NOT STAND ALONE]
<> // I have this [STAND ALONE] so need install ECLIPSE javascript ide [NOT STAND ALONE] over it, this from which come from Eclipse meant...
Re: I get this and stopped when went install some js/jquery plugins [message #764794 is a reply to message #764214] Mon, 12 December 2011 16:21 Go to previous messageGo to next message
> eclipse install...
Open Help > Install New Software...
Select the Helios update site from the drop-down list at the top.
Search the list of available features for JavaScript.
Install what you want.
Eric
Re: I get this and stopped when went install some js/jquery plugins [message #764809 is a reply to message #764794] Mon, 12 December 2011 17:14 Go to previous messageGo to next message
I mean in the menu choice [upper/right corner] choose IDE:
JAVA, JAVA EE, ANDROID DDMS, JAVA BROWSING
Can Appear Javascript choice? how? I guest by installing Eclipse Javascript IDE [like the java ide, the whole Eclipse ide soft i have], NOT PLUGINS... I INSTALLED JAVASCRIPT choices like "JAVASCRIPT dev tools" but not appeared, well is any way install Eclipse Javascript IDE upon this installation NOT stand alone ver but install over this installation [so not need open new IDE to work purely with javascript but from same ide] or there isn't?
Re: I get this and stopped when went install some js/jquery plugins [message #764932 is a reply to message #764809] Tue, 13 December 2011 00:47 Go to previous messageGo to next message
It sounds like it's not properly installed, then.
To put it simply, you have Helios. You need Indigo. There's no getting around that for using the plug-ins you mentioned at the start of this thread.
The menu you're referring to is just listing the predefined Perspectives. There's nothing special about a Perspective, it's just a set of views, in a layout, with specific menu and toolbar contributions enabled. Nothing prevents you from working with JavaScript files in any Perspective you choose, even in Perspectives you create yourself. You should have one for JavaScript if that's been installed properly. Regardless, you'll have to move up to Indigo for the plug-ins you want. You can get the JavaScript tools as part of Indigo's "Eclipse IDE for JavaScript Web Developers". It's listed right on http://download.eclipse.org .
Re: I get this and stopped when went install some js/jquery plugins [message #765144 is a reply to message #764932] Tue, 13 December 2011 08:58 Go to previous messageGo to next message
Eclipse IDE for JavaScript Web Developers,
if install this stand alone, I should install indigo even Java ide is Helios?
This (Eclipse IDE for JavaScript Web Developers) what server languages any support? PHP, java? color coding, or/and code completion...
If want include to Eclipse IDE for JavaScript Web Developers, and Eclipse php ide both indigo what to do(both in one)?
[Updated on: Tue, 13 December 2011 09:01] by Moderator
Re: I get this and stopped when went install some js/jquery plugins [message #765216 is a reply to message #765144] Tue, 13 December 2011 11:34 Go to previous messageGo to next message
> Helios?
The Indigo download would serve as a fresh start. DO NOT simply unpack
it over an existing copy of Eclipse. If you want both Java and
JavaScript support, you can get the Java EE package, or get either of
the Java or JavaScript Web packages and install the Indigo version of
the other feature from there.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: I get this and stopped when went install some js/jquery plugins [message #765251 is a reply to message #765216] Tue, 13 December 2011 12:41 Go to previous messageGo to next message
what if I want leave Java/ee with Helios and, want install stand alone, PHP and javascript IDEs INDIGO in one, then I must download both or download one then use help menu to get the other...in this case what first install PHP or javascript?
Re: I get this and stopped when went install some js/jquery plugins [message #765351 is a reply to message #765251] Tue, 13 December 2011 17:23 Go to previous messageGo to next message
Pick one to install. Go to Help->Install New Software to add the additional features you need.
Re: I get this and stopped when went install some js/jquery plugins [message #765513 is a reply to message #765351] Wed, 14 December 2011 03:24 Go to previous message
Eclipse IDE for JavaScript Web Developers this includes jQuery color coding & code completion? when indigo came out? next version when will be?
Previous Topic:workspace or project? 3-mercurials + n-parts inside
Next Topic:Java Formatter settings for casts
Current Time: Thu Sep 25 11:26:32 EDT 2025
Powered by FUDForum. Page generated in 0.13745 seconds
