Re: includes and unresolved symbols problem on ubuntu [message #768849 is a reply to message #759241] |
Tue, 20 December 2011 18:21  |
I just tried to reproduce this as follows:
1) install eclipse indigo sr1 with cdt from
eclipse.org/downloads/packages/eclipse-ide-cc-developers-includes-incubating-components/indigosr1
2) start eclipse, do New / C++ Project / Hello World Project
3) do Window / Show View / C++
4) Hello should be showing in the project explorer; open it and look at hello.cpp
5) check whether there is a bug mark next to the #include <iostream>
When I do this in a fresh workspace, it works fine.
I do have a simple C/C++ project that has the problem you describe, so try creating a fresh workspace and see if a fresh hello project in there works ok.
In the good hello project, the properties of the hello project, under C/C++ Build,
show
Build Variables
Discovery Options
In the bad project, the properties of the hello project do not have
a C/C++ Build folder; instead, it has top level folders C/C++ General,
C/C++ Include Paths, C/C++ Make Project, and C/C++ Project Paths.
I can't quite figure out why they're different. (Hmm. It's possible
the bad project was generated with cmake.)
[Updated on: Tue, 20 December 2011 18:30] by Moderator
FUDForum. Page generated in 0.06827 seconds
