"File Search" hangs or crashes [message #762562] |
Thu, 08 December 2011 04:59  |
I don't want to seem like I'm just flaming Eclipse here, because I quite like it and I certainly appreciate its diverseness and power, but the phantom errors, lib i386 warnings (I move between 32-bit and 64-bit interfaces) and other errors that randomly appear until I "clean" and rebuild my project is just too much. On top of that Eclipse indigo is now hanging whenever I use the search->file option to search through my files.
I was thinking of leaving Eclipse (from installing it on ubuntu to setting up basic settings has been more of an uphill battle than it should be), but would first like to give an older more stable version a try, because despite the struggles I've become quite accustomed to and fond of the Eclipse interface. I'm currently using Eclipse Indigo Service Release 1 on Ubuntu 11.10 32-bit.
So what is the most stable, reliable C++ ready version of Eclipse that I might be able to try before returning to the murky depths of makefiles and vim (or possibly netbeans)?
[Updated on: Thu, 08 December 2011 05:16] by Moderator
Re: "File Search" hangs or crashes [message #763262 is a reply to message #763192] |
Fri, 09 December 2011 07:58   |
I currently don't have the search problem; it disappeared after I stopped linking directories that weren't physically in the workspace. After my folders disappeared I tried to delete my project and start again; now I'm getting this error on compile:
Quote:/usr/bin/ld: cannot open output file test_proj: Is a directory
These errors typically vanish, although I've never seen this one before; I suspect this might be something I've done wrong in the settings somewhere. I find it hard to believe that others don't have these problems - I've tried running Eclipse on fresh installs on my 32-bit Ubuntu machine, my 64-bit ubuntu i7 at work, and on my girlfriend's Windows Vista 64-bit setup. With both my Ubuntu installs I have constant problems, mostly arising from the fact that deleting the build directory and "cleaning" the project don't seem to reset everything (rebuilding/cleaning/deleting Debug repeatedly eventually gets rid of the errors), on the Vista setup Eclipse didn't realise that the binary was being built in the Debug directory, and just reported "Binary not found" after compiling. I ended up just running the execs from a command prompt, which sort of worked.
So either I have terrible luck, or I'm just all thumbs...
[Updated on: Fri, 09 December 2011 07:58] by Moderator
Re: "File Search" hangs or crashes [message #976599 is a reply to message #763262] |
Thu, 08 November 2012 13:03  |
Greetings,
I too am now getting the hanging on "file search" after processing a certain percent of the workspace has been completed (13%). I'm using eclipse 3.7.2 (Eclipse Platform 3.7.2.M20120208-0800) on an Win7(64) enterprise system.
All had been working well previous to this state. Is this a known problem or is it user induced. I have to shutdown eclipse and start it back up to clear the hanging state for the search (progress tab show search just hanging even if I try to stop the search command).
Any help is apprecaited!
Mike W.
FUDForum. Page generated in 0.23962 seconds
