Mapping / history table with active entry marked [message #760903] |
Mon, 05 December 2011 09:46  |
I am just starting to get into JPA using EclipseLink. I have the following (legacy) data model:
Table A
m_id PK
Table AB
m_id PK, FK
n_id PK
s_id FK
active BOOL
Table B
s_id PK
value
(A has a "history" of B's where the active entry ist marked by AB.active.)
Now I want to define a mapping for attribute "activeB" in class A which should reference the active entry.
[SQL:
select
b.s_id, b.value
from
A a
join AB ab on a.m_id = ab.m_id and ab.active = true
join B b on b.s_id = ab.s_id
I have tried different approaches but couldn't find a solution. So I would be very happy if someone could give me a hint.
Thanks for your help
Thomas
Re: Mapping / history table with active entry marked [message #761498 is a reply to message #761035] |
Tue, 06 December 2011 09:52   |
Hi all,
after playing around some more I got the following "solution"
Entities (excerpt):
@Entity
@Table(name="A")
@Customizer(ActStateFilter.class)
public class A{
@JoinTable(name = "AB", joinColumns = @JoinColumn(name = "m_id", referencedColumnName = "m_id"), inverseJoinColumns = @JoinColumn(name = "s_id", referencedColumnName = "s_id"))
private B activeB;
@Entity
@Table(name="B")
public class B{
@Id
@Column(name="s_id", unique=true, nullable=false)
private Integer sID;
@Column(name="value", length=60)
private String value;
DescriptorCustomizer:
public class ActStateFilter implements DescriptorCustomizer {
public void customize(ClassDescriptor descriptor) throws Exception {
OneToOneMapping mapping = (OneToOneMapping) descriptor.getMappingForAttributeName("activeB");
ExpressionBuilder eb = new ExpressionBuilder(mapping.getReferenceClass());
Expression exp = eb.getTable("A").getField("m_id").equal(eb.getParameter("M_ID")).
and(eb.getTable("AB").getField("m_id").equal(eb.getTable("A").getField("m_id"))).
and(eb.getTable("AB").getField("s_id").equal(eb.getTable("B").getField("s_id")).
and(eb.getTable("AB").getField("active").equal(true)));
mapping.setSelectionCriteria(exp);
[BTW: Don't ask how long it took me to figure out that parameter M_ID is expected to be written in uppercase letters...]
Now if I execute the following query:
TypedQuery<A> q = em.createQuery("select a from A a where a.activeB.s_id=10", A.class);
I get all A where the active B's s_id is 10 as expected (hoped for).
But if instead I execute the following query:
TypedQuery<A> q = em.createQuery("select a from A a where a.activeB=:state", A.class);
B state = em.find(B.class, 10);
q.setParameter("state", state);
I get "wrong" results (sorry - didn't yet find out a "pattern" for the wrong results).
[EDIT: I get all A for which there is a B in history with s_id = 10 - regardeless of the active s_id]
Could anybody confirm that the entities and the desriptor customizer shown above are correct?
Could anybody explain why the second query yields wrong results?
Thanks again
Thomas
[Updated on: Tue, 06 December 2011 10:00] by Moderator
Re: Mapping / history table with active entry marked [message #761503 is a reply to message #761033] |
Hi all,
Entities (excerpt):
@Entity
@Table(name="A")
public class A{
private B activeB;
@Entity
@Table(name="B")
public class B{
@Id
Thanks again
Thomas
FUDForum. Page generated in 0.06450 seconds
