Home » Archived » EGL Development Tools » EGL Development Tools (EDT) v0.7 is available
EGL Development Tools (EDT) v0.7 is available [message #762956] Thu, 08 December 2011 16:33 Go to next message
In case you missed it - EGL Development Tools (EDT) v0.7 is now available! See the Download section of the EDT site for download and installation instructions.
If you were using the .7 M3 build, you'll need to add or edit the update site to
http://download.eclipse.org/edt/updates/1.0
You should be able to use the Check for Updates menu option from the Help menu.
We've also updated the EDT website and wiki with additional information. Let us know what you think!
Theresa
Re: EGL Development Tools (EDT) v0.7 is available [message #762971 is a reply to message #762956] Thu, 08 December 2011 17:19 Go to previous messageGo to next message
Slashdot:
http://developers.slashdot.org/story/11/12/08/228224/ibm-releases-open-source-egl-development-tools
Re: EGL Development Tools (EDT) v0.7 is available [message #762983 is a reply to message #762971] Thu, 08 December 2011 17:57 Go to previous messageGo to next message
Thanks for sharing Dan!
We're happy to see the word spread about EGL being open and EDT.
Re: EGL Development Tools (EDT) v0.7 is available [message #763434 is a reply to message #762983] Fri, 09 December 2011 13:59 Go to previous messageGo to next message
The predominantly negative comments on /. do point out the uphill battle that EDT faces. It's people speaking from ignorance but I think that the /. audience IS your target audience (the developer community in general rather than just the segment of the developer community that has already been successfully using IBM solutions for the last umpteen years).
[Updated on: Fri, 09 December 2011 14:04] by Moderator
Re: EGL Development Tools (EDT) v0.7 is available [message #763463 is a reply to message #763434] Fri, 09 December 2011 15:27 Go to previous messageGo to next message
As I said on the RBD forum - read the comments and see if you can find which one is mine. Two points for the first correct answer. Cool
Re: EGL Development Tools (EDT) v0.7 is available [message #763468 is a reply to message #763463] Fri, 09 December 2011 15:35 Go to previous messageGo to next message
This one?
"That's one of the primary values of EGL - it extends Java and JavaScript. ..."
Re: EGL Development Tools (EDT) v0.7 is available [message #763478 is a reply to message #763468] Fri, 09 December 2011 15:59 Go to previous messageGo to next message
Hee heeee! Ding ding ding ding! Give the man a cigar and two Pluta Points, redeemable at hundreds of locations across the country!
Re: EGL Development Tools (EDT) v0.7 is available [message #763485 is a reply to message #763478] Fri, 09 December 2011 16:15 Go to previous message
YES!!! <fist pump>
Previous Topic:Am I in the right track?
Next Topic:What is the target runtime to use for RBD
Current Time: Sat Jul 26 02:41:40 EDT 2025
Powered by FUDForum. Page generated in 0.07288 seconds
