Home » Archived » EGL Development Tools » Installing EDT into Eclipse
Installing EDT into Eclipse [message #759784] Tue, 29 November 2011 23:07 Go to next message
Help needed as a newbie!
I have problem installing EDT into my Eclipse IDE.
The following are the steps I did:
- Help > Install New Software >
EDT http: // download.eclipse.org /edt/updates/0.7.0/M3
Problem Occurred:
Unable to connect to repository
--http: // download.eclipse.org/edt/updates/0.7.0/M3/content.xml
org.eclipse.equinox.p2.core.ProvisionException
Thank you in advance!!
Re: Installing EDT into Eclipse [message #759788 is a reply to message #759784] Tue, 29 November 2011 23:57 Go to previous messageGo to next message
I believe you are using the correct install steps. Maybe there's a network problem.
Can you try the nightly build? The nightly build has more features and is also quite stable at the moment. You can get the link to the nightly build link in the same page you get the M3 build link.
Re: Installing EDT into Eclipse [message #759790 is a reply to message #759784] Wed, 30 November 2011 00:08 Go to previous messageGo to next message
Looks like a network error but you might also be running afoul of a web blocker on your network. What happens when you paste the install link into the URL line on your browser? You should see a simple summary of the artifacts on the build. If you receive a network error or a web blocker message then this will confirm that the issue is external to Eclipse and the EDT build.
--Dan
Re: Installing EDT into Eclipse [message #759793 is a reply to message #759784] Wed, 30 November 2011 00:16 Go to previous messageGo to next message
It looks like there's several spaces in your posted URL. You can take a look at your URL typed in Eclipse, and make sure no spaces.
Also, I would suggest you to install below latest build.
download.eclipse.org/edt/updates/1.0
Re: Installing EDT into Eclipse [message #759794 is a reply to message #759784] Wed, 30 November 2011 00:20 Go to previous messageGo to next message
Thanks all for your kind reply!!
The spaces for the weblink is due to the restriction from this eclipse forum. The actual implementation is without the spaces for the http:/ link
You guys are right! It might be due to my company network. How do I enable it? Any tips on doing so for Eclipse? By the way I am trying out the nightly link download.
Re: Installing EDT into Eclipse [message #759795 is a reply to message #759794] Wed, 30 November 2011 00:45 Go to previous messageGo to next message
You may try to specify a proxy in Windows > Preference > Network Connection, and then supply the Host & Port information in by clicking the Edit button for HTTP.
Re: Installing EDT into Eclipse [message #760064 is a reply to message #759795] Thu, 01 December 2011 02:24 Go to previous messageGo to next message
Sorry how do I find my company host & port?
Re: Installing EDT into Eclipse [message #760094 is a reply to message #760064] Thu, 01 December 2011 04:51 Go to previous messageGo to next message
Can anyone please tell me whether my content.xml is correct? Thanks in advance!
<?xml version='1.0' encoding='UTF-8'?>
<?metadataRepository version='1.1.0'?>
<repository name='update site: file:/C:/_SPH/Projects/MBO/eclipse-jee-indigo-SR1-win32/eclipse/configuration/org.eclipse.osgi/bundles/290/data/listener_1925729951/' type='org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository' version='1'>
<properties size='2'>
<property name='p2.timestamp' value='1322616609346'/>
<property name='site.checksum' value='0'/>
</properties>
</repository>
Re: Installing EDT into Eclipse [message #760271 is a reply to message #760064] Thu, 01 December 2011 12:49 Go to previous messageGo to next message
Proxy information would have to come from someone in your company...a network or security administrator.
Also, did you try the thing I suggested...pasting the URL for EDT into your browser? What was the result?
--Dan
Re: Installing EDT into Eclipse [message #760404 is a reply to message #760271] Fri, 02 December 2011 05:05 Go to previous messageGo to next message
Hi Dan,
I have copied and paste the URL intow my brower. It works. I am able to see those jars and other files inside. So I guess this is not due to my network problem. The error comes from
Unable to connect to repository http://download.eclipse.org/edt/updates/nightly/content.xml
Connection refused: connect
When I copy and paste http://download.eclipse.org/edt/updates/nightly/content.xml, this is not found.
So where can I download the correct copies of EDT??
Please help!!
Re: Installing EDT into Eclipse [message #760490 is a reply to message #760404] Fri, 02 December 2011 09:39 Go to previous messageGo to next message
Hi Jan,
In which version of Eclipse are you trying to install EDT (for example, "Eclipse IDE for Java EE Developers 3.7.1", "Eclipse Classic 3.6.2")? There is no content.xml and I do not believe there ever was (there's just site.xml, content.jar, artifacts.jar).
-Justin
Re: Installing EDT into Eclipse [message #760739 is a reply to message #760490] Sun, 04 December 2011 19:39 Go to previous messageGo to next message
I save eclipse-jee-indigo-SR1-win32, extract all and double click on eclipse.exe to run the program. Did I install anything wrong? Please do help!
Greatly appreciate in advance!
Re: Installing EDT into Eclipse [message #762954 is a reply to message #760739] Thu, 08 December 2011 16:29 Go to previous messageGo to next message
Hi Jan,
There are a few ways to get EDT, as described on the EDT Download page. http://eclipse.org/edt/#download
For folks that don't already have Eclipse, we recommend the All-in-one package which includes the Eclipse IDE for Java EE Developers 3.7 and the EDT plugins.
For folks that have Eclipse for Java EE Developers 3.6 or 3.7 (note, the Java EE package of Eclipse is required), you can use "Install New Software" option from the Help menu to add the EDT update site
http://download.eclipse.org/edt/updates/1.0.
Nightly builds are intended for contributors and extenders (and other people on the bleeding edge of EDT) more than users. The update site for the nightly builds is
http://download.eclipse.org/edt/updates/nightly.
Theresa
[Updated on: Thu, 08 December 2011 16:29] by Moderator
Re: Installing EDT into Eclipse [message #766301 is a reply to message #762954] Thu, 15 December 2011 09:23 Go to previous messageGo to next message
error message from eclipse help/install new software widget:
Cannot complete the install because one or more required items could not be found.
Software being installed: EGL Web Developer Tools 0.7.0.v201111291320-1CT-Fiv5_LLLMCVMu5Y (org.eclipse.edt.feature.feature.group 0.7.0.v201111291320-1CT-Fiv5_LLLMCVMu5Y)
Missing requirement: EGL deployment IDE 0.7.0.v201111291320 (org.eclipse.edt.ide.deployment 0.7.0.v201111291320) requires 'bundle org.eclipse.jst.j2ee.core 1.2.4' but it could not be found
Cannot satisfy dependency:
From: EGL Web Developer Tools 0.7.0.v201111291320-1CT-Fiv5_LLLMCVMu5Y (org.eclipse.edt.feature.feature.group 0.7.0.v201111291320-1CT-Fiv5_LLLMCVMu5Y)
To: org.eclipse.edt.ide.deployment [0.7.0.v201111291320]
i have eclipse indigo.
just for giggles i downloaded the java ee version and reinstalled and tried again.
no go.
so i downloaded the java ee sdk and installed it and tried again.
nada.
what's wrong?
does it not work on win7-64bit?
Sad
Re: Installing EDT into Eclipse [message #766354 is a reply to message #766301] Thu, 15 December 2011 10:51 Go to previous message
Hi Joe,
You need the Eclipse IDE for Java EE Developers. Seems you may be using a different package, since the message says "org.eclipse.jst.j2ee.core" is missing.
Another idea is to get the All in one build from the EDT downloads page, which includes Eclipse 3.7 Java EE and EDT packages in a single zip. There is an All in one build for Windows 64 bit.
Good luck!
Theresa
Previous Topic:Silly qn: how to enable the 'event' in my IDE?
Next Topic:Lesson 4 - bug in design view of TitlePane
Current Time: Sat Jul 26 17:01:57 EDT 2025
Powered by FUDForum. Page generated in 0.06548 seconds
