Home » Modeling » TMF (Xtext) » Generator Problems with xtext 2.1.1
Generator Problems with xtext 2.1.1 [message #762914] Thu, 08 December 2011 15:01 Go to next message
Hello everyone,
i have some problems with the code generation. when i run my project as an eclipse application, add the src-gen folder - there is no code generate at all. I have generatet a new xtext project, added code to the .xtext file and also to the StatemachineGenerator.xtend. I don't know where to start to find out the problem? Every hint would be appreciated. i have also added a copy of my project-folders (wsp_sn2.zip).
thanks and best regards
My Files
My Statemaschine.xtext
grammar at.xne.sn.Statemachine with org.eclipse.xtext.common.Terminals
 //no link restriction of the forum
generate statemachine "http ://www.xne.at/sn/Statemachine"
Model:
	modules+= Modul+
Modul:
	'modul' name= ID ';'
	actions+= Action*
	states+= State*
	transitionconditions+= Transitioncondition*
	transitions += Transition*
Action:
	'action' name= ID ';'
State:
	'state' name= ID '['
	action=[Action] '];'
Transition:
	start=[State] '-(' transitCondition=[Transitioncondition]')->' ende=[State] ';'
Transitioncondition:
	'transitioncondition' name= ID ';'
My StatemachineGenerator.xtend
 * generated by Xtext
package at.xne.sn.generator
import at.xne.sn.statemachine.Modul
import com.google.inject.Inject
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.generator.IFileSystemAccess
import org.eclipse.xtext.generator.IGenerator
import org.eclipse.xtext.naming.IQualifiedNameProvider
import static extension org.eclipse.xtext.xtend2.lib.ResourceExtensions.*
class StatemachineGenerator implements IGenerator {
	@Inject extension IQualifiedNameProvider nameProvider
	override void doGenerate(Resource resource, IFileSystemAccess fsa) {
		    for(e: resource.allContentsIterable.filter(typeof(Modul))) {
		        fsa.generateFile(
		            e.fullyQualifiedName.toString.replace(".", "/") + ".java",
		            e.compile)
  	def compile(Modul e) '''
        public class «e.name» {
In my eclipse environment i have installed the following:
Eclipse 3.7.1
  xtext: 2.1.1.v201111141332
  Eclipse SDK	3.7.1.M20110909-1335	org.eclipse.sdk.ide	null
  Xbase	2.1.1.v201111141332	org.eclipse.xtext.xbase.feature.group	Eclipse Modeling Project
  Xtend2 SDK	2.1.1.v201111141332	org.eclipse.xtext.xtend2.sdk.feature.group	Eclipse Modeling Project
  Xtext Documentation	2.1.1.v201111141332	org.eclipse.xtext.docs.feature.group	Eclipse.org
  Xtext Examples	2.1.1.v201111141332	org.eclipse.xtext.examples.feature.group	Eclipse Modeling Project
  Xtext Runtime	2.1.1.v201111141332	org.eclipse.xtext.runtime.feature.group	Eclipse Modeling Project
  Xtext SDK	2.1.1.v201111141332	org.eclipse.xtext.sdk.feature.group	Eclipse Modeling Project
  Xtext UI	2.1.1.v201111141332	org.eclipse.xtext.ui.feature.group	Eclipse Modeling Project
  • Attachment: wsp_sn2.zip
    (Size: 1.54MB, Downloaded 165 times)
Re: Generator Problems with xtext 2.1.1 [message #762926 is a reply to message #762914] Thu, 08 December 2011 15:22 Go to previous messageGo to next message
works for me. how does your test project + model file look like
P.S: i had to recompile the generator.xtend
~Christian
[Updated on: Thu, 08 December 2011 15:25] by Moderator
Re: Generator Problems with xtext 2.1.1 [message #762930 is a reply to message #762926] Thu, 08 December 2011 15:33 Go to previous messageGo to next message
Hi Christian,
attached you find the test project.
Re: Generator Problems with xtext 2.1.1 [message #762931 is a reply to message #762930] Thu, 08 December 2011 15:34 Go to previous messageGo to next message
Hi Christian,
how have you recompiled which file?
best regards
Re: Generator Problems with xtext 2.1.1 [message #762933 is a reply to message #762930] Thu, 08 December 2011 15:37 Go to previous messageGo to next message
hmmm i get a prozess.java. did you deactivate the compiler in your runtime workspace
window -> prefs -> statemachine -> compiler?
do you have build automatically on in your runtime workspace?
do you get any error messages in your host eclipse console?
~Christian
Re: Generator Problems with xtext 2.1.1 [message #762940 is a reply to message #762933] Thu, 08 December 2011 15:55 Go to previous message
OMG, now it works Smile thanks christian for your hint.
in the meantime i did two steps:
1. i setup a clean eclipse 3.7.1 ide + xtext (described at: http ://www.eclipse.org/Xtext/documentation/2_1_0/005-installation.php). this time i only ticked the Xtext SDK check box, before i had installed the whole package.
2. i did a clean up in my project Wink and the generated file appeared
thanks again and best regard
Previous Topic:Column oriented editors
Next Topic:Define own scope: Reference C methods
Current Time: Sat Jul 19 02:40:25 EDT 2025
Powered by FUDForum. Page generated in 0.05380 seconds
