Home » Archived » BIRT » apply or remove styles dynamically at runtime(apply or remove styles dynamically at runtime)
apply or remove styles dynamically at runtime [message #762143] Wed, 07 December 2011 10:55 Go to next message
We have reports generated in HTML and excel formats, is it possible to remove style for excel version of the reports at runtime.
we are using birt3.7 and native excel emitter to generate excel reports.
KKP
Re: apply or remove styles dynamically at runtime [message #762268 is a reply to message #762143] Wed, 07 December 2011 14:31 Go to previous messageGo to next message
Are you using the /frameset, or the /run, or the /preview mapping to
generate the report?
Jason
On 12/7/2011 10:55 AM, kkp wrote:
> KKP
Re: apply or remove styles dynamically at runtime [message #762430 is a reply to message #762268] Wed, 07 December 2011 22:34 Go to previous messageGo to next message
Jason,
We are using birt tld to view the reports in our jsp below is the code snippet used:
<birt:report id="birtViewer"
reportDocument="<%=docName%>"
format="html"
frameborder="no"
isHostPage="false"
pageNum="<%=pageNum%>"
scrolling="no"
width="950"
reportContainer="div">
</birt:report>
Re: apply or remove styles dynamically at runtime [message #762892 is a reply to message #762430] Thu, 08 December 2011 14:26 Go to previous messageGo to next message
Any thoughts on this?
Re: apply or remove styles dynamically at runtime [message #762896 is a reply to message #762430] Thu, 08 December 2011 14:29 Go to previous messageGo to next message
Can you try the attached report that changes a style when exporting to
pdf. It does not drop it but should be able to change the style.
Look at the onRender script for the detail row of the table.
Jason
On 12/7/2011 10:34 PM, kkp wrote:
> Jason,
> snippet used:
> <birt:report id="birtViewer" reportDocument="<%=docName%>"
> format="html" frameborder="no" isHostPage="false" pageNum="<%=pageNum%>"
> scrolling="no" width="950" reportContainer="div">
> </birt:report>
Re: apply or remove styles dynamically at runtime [message #762897 is a reply to message #762896] Thu, 08 December 2011 14:34 Go to previous messageGo to next message
Jason,
I can try , but is it possible to drop all the styles applied to excel.
Re: apply or remove styles dynamically at runtime [message #762909 is a reply to message #762897] Thu, 08 December 2011 14:54 Go to previous messageGo to next message
You could try the approach in the previous post or create two tables one
with styling and the other without. You can then set the output format
to hide one or the other with the visibility property.
Jason
On 12/8/2011 2:34 PM, kkp wrote:
> Jason,
Re: apply or remove styles dynamically at runtime [message #762915 is a reply to message #762909] Thu, 08 December 2011 15:02 Go to previous messageGo to next message
Jason,
We tied this option, but the size of rptdocument is increasing with two tables wich is causig performance issues.This happens as we are not dropping the table from rptdocumentbut hiding it which will add upto the size of rptdocument.
Is there anyway we can drop the excel table from rptdocument and use only the table with styles for rptdocument.
Is there any wa we can drop the table based on visibility option like, if the table's visibility is set to hide for all but excel then drop the table in rptdocument?
Re: apply or remove styles dynamically at runtime [message #762922 is a reply to message #762915] Thu, 08 December 2011 15:14 Go to previous messageGo to next message
You can only drop tables, styles etc in the beforeFactory or earlier,
which is when the rptdocument is being built. Why will the onRender
script not work for you?
Jason
On 12/8/2011 3:02 PM, kkp wrote:
> Jason,
Re: apply or remove styles dynamically at runtime [message #763211 is a reply to message #762922] Fri, 09 December 2011 06:08 Go to previous messageGo to next message
Jason,
Thanks, we could dynamically remove/add the styles.
-KKP
Re: apply or remove styles dynamically at runtime [message #763318 is a reply to message #763211] Fri, 09 December 2011 09:56 Go to previous messageGo to next message
Which method did you end up going with?
Jason
On 12/9/2011 6:08 AM, kkp wrote:
> Jason,
> -KKP
Re: apply or remove styles dynamically at runtime [message #763597 is a reply to message #763318] Fri, 09 December 2011 23:01 Go to previous message
Jason,
We applied different styles like just adding grid lines to excel file using onrender().
KKP
Previous Topic:Null pointer exception while genrating reports
Next Topic:All in one | Eclipse for Birt
Current Time: Sun Jul 27 13:52:09 EDT 2025
Powered by FUDForum. Page generated in 0.07869 seconds
