Home » Archived » BIRT » vector rendering of svg in pdf
vector rendering of svg in pdf [message #367764] Tue, 07 April 2009 04:33 Go to next message
Originally posted by: piebe.de.vries.geodan.nl
hi,
Is any work being done on vector based rendering of svg in de pdf emitter?
If not, could anybody point me in the right direction of how to do it myself. I know how to get svg
into pdf using batik/itext. I had a quick look at the pdfemitter. But by the time the image data
arrives at PDFPage.drawImage(...) it is already transformed to a png image. So the svg data is not
available there. I am looking for an easy way to get the svg data available in the pdftransmitter
plugin, any hints?
greetings,
Piebe
Re: vector rendering of svg in pdf [message #367774 is a reply to message #367764] Tue, 07 April 2009 12:29 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Piebe,
Are you referring to charts?
Look at PageDeviceRender.drawImage
Also look at SvgFile.transSvgToArray
Jason
piebe wrote:
> hi,
> myself. I know how to get svg into pdf using batik/itext. I had a quick
> look at the pdfemitter. But by the time the image data arrives at
> svg data is not available there. I am looking for an easy way to get the
> svg data available in the pdftransmitter plugin, any hints?
> greetings,
> Piebe
Re: vector rendering of svg in pdf [message #367780 is a reply to message #367774] Wed, 08 April 2009 03:33 Go to previous messageGo to next message
No I need to include a svg image, I do not need to render a chart (actually I assumed that the chart
would use the pdfemitter aswell to render its svg, in which case changing the emitter would solve
two things at the same time, but appearantly I was wrong there :( ) Anyway at the moment I am just
interested in an image not the chart.
Piebe
Jason Weathersby wrote:
> Piebe,
> Jason
> piebe wrote:
>> hi,
>> emitter?
>> quick look at the pdfemitter. But by the time the image data arrives
>> the svg data is not available there. I am looking for an easy way to
>> get the svg data available in the pdftransmitter plugin, any hints?
>> greetings,
>> Piebe
Re: vector rendering of svg in pdf [message #367790 is a reply to message #367780] Wed, 08 April 2009 11:21 Go to previous messageGo to next message
Piebe,
Are you wanting a new report item that contains svg data instead of
normal image data? An SVG report item would be a good report item
extension.
If you are wanting to go this route take a look at:
rotated text example in the source code &
http://www.birt-exchange.com/devshare/designing-birt-reports /537-birt-extension-mechanism/
Jason
> (actually I assumed that the chart would use the pdfemitter aswell to
> render its svg, in which case changing the emitter would solve two
> at the moment I am just interested in an image not the chart.
> Piebe
>> Piebe,
>> Jason
>> piebe wrote:
>>> hi,
>>> emitter?
>>> So the svg data is not available there. I am looking for an easy way
>>> to get the svg data available in the pdftransmitter plugin, any hints?
>>> greetings,
>>> Piebe
Re: vector rendering of svg in pdf [message #367812 is a reply to message #367790] Thu, 09 April 2009 05:14 Go to previous messageGo to next message
No I do not want to define a new report item.
I put standard image reportitem in my report which refers to a SVG image.
When I look at the report as html, this image is displayed as a svg image and therefore drawn using
vectors.
When I look at the same report as pdf, this image is displayed as a png image and therefore drawn as
a bitmap and not using vectors. This does not look very nice, does not print very well, and it is
not a very efficient way of storage for the large pictures I want to use...
Therefore I want to change the pdf emitter so that it functions the same way as the html emitter
currently works, that is let it draw a svg image using vectors and not as a bitmap.
> Piebe,
> extension.
> Jason
>> Anyway at the moment I am just interested in an image not the chart.
>> Piebe
>>> Piebe,
>>> Jason
>>> piebe wrote:
>>>> hi,
>>>> emitter?
>>>> it myself. I know how to get svg into pdf using batik/itext. I had a
>>>> greetings,
>>>> Piebe
Re: vector rendering of svg in pdf [message #367819 is a reply to message #367812] Thu, 09 April 2009 10:53 Go to previous messageGo to next message
Piebe,
Understood.
You need to look at
ImageLayout.java and SvgFile.java
ImgaeLayout.getIntrinsicDimension calls SvgFile.transSvgToArry which
converts svg to image for pdf.
Jason
> image and therefore drawn using vectors.
> image and therefore drawn as a bitmap and not using vectors. This does
> not look very nice, does not print very well, and it is not a very
> way as the html emitter currently works, that is let it draw a svg image
>> Piebe,
>> extension.
>> Jason
>>> Piebe
>>>> Piebe,
>>>> Jason
>>>> piebe wrote:
>>>>> hi,
>>>>> emitter?
>>>>> png image. So the svg data is not available there. I am looking for
>>>>> plugin, any hints?
>>>>> greetings,
>>>>> Piebe
Re: vector rendering of svg in pdf [message #762841 is a reply to message #367819] Thu, 08 December 2011 12:37 Go to previous message
Piebe,
Have you made any progress? Could you please share what you've achieved so far?
I'm also very interested in proper SVG image rendering in PDF files.
Thanks in advance
Previous Topic:ClassLoader Problem in Event Handler
Next Topic:Warnings when rendering chart to svg
Current Time: Sun Jul 27 10:05:42 EDT 2025
Powered by FUDForum. Page generated in 0.16768 seconds
