Home » Modeling » Graphiti » Graphiti as Multiple Xml Editor(How to use Graphiti as a Editor for multiple Xml editors)
Graphiti as Multiple Xml Editor [message #760438] Fri, 02 December 2011 06:30 Go to next message
Hello!
Im working on an Eclipse plugin. What I want to do is making a custom editor that can open xml files. I want to show a Flow diagram based on that file and I want to allow changes in the diagram. After saving the file I want to save back to Xml. Is it possible to do that?
If not, I have already parsed the Xml files and I have a EMF model that contains everything that the Xml files contains. Can I load a EMF object into Graphiti?
Re: Graphiti as Multiple Xml Editor [message #760775 is a reply to message #760438] Mon, 05 December 2011 04:09 Go to previous messageGo to next message
I not sure what you exactly mean with "loading"...
I would simply write a Graphiti editor that works with the EMF model you
already have. By adding graphitical representations of your model objects
you will create links to these objects and they will get loaded inside your
diagram editor.
HTH,
Michael
Re: Graphiti as Multiple Xml Editor [message #761163 is a reply to message #760775] Mon, 05 December 2011 21:22 Go to previous messageGo to next message
Load means that I have a custom Xml file format that I want to parse and show as an editable diagram.
What I want to do is a graphical Xml editor with diagrams.
I already wrote the Xml to EMF and EMF to Xml functions, but I want to know that Graphiti can show the EMF object as a diagram.
If so, then can I capture the "Save" editor event to use my custom EMF to Xml implementation?
Re: Graphiti as Multiple Xml Editor [message #762619 is a reply to message #761163] Thu, 08 December 2011 06:54 Go to previous messageGo to next message
Graphiti can surely be used to create visual representations of any EMF
objects you have.
You can also capture the save event, but that will mean for now you have to
override the method doSave of the currently internal class
DiagramEditorInternal. For the next release we are working on making the
editor public API.
Michael
Re: Graphiti as Multiple Xml Editor [message #762652 is a reply to message #762619] Thu, 08 December 2011 07:59 Go to previous messageGo to next message
Sounds very promising
Can you give me a hint about how I can feed my EMF object to the GMF editor?
Re: Graphiti as Multiple Xml Editor [message #763137 is a reply to message #762652] Fri, 09 December 2011 03:40 Go to previous messageGo to next message
Sorry? I thought you wanted to build a Graphiti editor?
Michael
Re: Graphiti as Multiple Xml Editor [message #763330 is a reply to message #763137] Fri, 09 December 2011 10:25 Go to previous messageGo to next message
I want to do an Eclipse graphical editor with Graphiti. What i want to do is to feed the editor with xml files and let the user edit (save, load, view) the xml file with a graphical tool.
And is it possible to feed the graphical editor from multiple xml files and save the graphical editor changes to multiple xml files?
The xml files has a predefined syntax.
I have already did a parser that parses all the xml files, and make an EMF Object (!).
[Updated on: Fri, 09 December 2011 10:27] by Moderator
Re: Graphiti as Multiple Xml Editor [message #764461 is a reply to message #763330] Mon, 12 December 2011 03:19 Go to previous message
this posting might help:
http://www.eclipse.org/forums/index.php/t/261941/
Best, Tim
Previous Topic:Export as gif file failing
Next Topic:Direct Editing with TYPE_MULTILINETEXT
Current Time: Sat Jul 26 02:05:08 EDT 2025
Powered by FUDForum. Page generated in 0.06376 seconds
